Better Email Q&A
Mon Jan 15, 2018 4:04 pm
Re: Better Email Q&A
ghenne wrote:
I see Email Scanned messages.
Jan 15, 2018 at 5:20:05 AM
  Email Scanned                   from "service@intl.paypal.com"; subject "Payment Skipped"
That's from the Indigo built-in email scanner, not from BetterEmail. If you want to use the BetterEmail triggers, you need to turn off the built-in scanner and configure a BetterEmail POP or IMAP device.
Mon Jan 15, 2018 5:37 pm
ghenne offline
I have IMAP configured in Preferences in the Mail tab. Does BetterMail have its own configuration? Where?
(Is there documentation I should have found?)
Mon Jan 15, 2018 5:40 pm
Like I said, BetterEmail is totally independent of the Indigo built-in email system. BetterEmail uses Indigo devices to represent each server you want to use. If you want to handle mail on an IMAP server, you create a BetterEmail device of type "IMAP Server".
This thread, and the thread for the Indigo 6 version, are the best resource: viewtopic.php?f=211&t=14411
Sat Mar 17, 2018 12:28 pm
Just released version 7.2.0, available from the Plugin Store or GitHub.
https://github.com/FlyingDiver/Indigo-B ... /tag/7.2.0
Added timeout code to restart IDLE connections
New MessageTo states in IMAP and POP devices
Removed GHPU entirely
Log messages updated
Mon Oct 22, 2018 12:26 pm
Release 7.2.4 is now available.
Handle null flags (Gmail)
Allow message search for HTML-only emails (no plain text alternative).
Thu Dec 06, 2018 11:48 pm
Gangotti offline
First, let me say this is a great plugin. I am wondering if there is a way to do a partial string match. I am using alarm.com currently and I have it sending notifications to Indigo. In Indigo I have the better email plugin triggering indigo with a string match in email event. The email is coming has a subject of " Vegas Home: The Kitchen Door was Opened at 11:02 am" With the time in the subject and the message body it makes it so the trigger will not work. Is there a way for the event to trigger if a section of the string is in the subject? I.e. "Vegas Home: The Kitchen Door was Opened at"
Thanks again and keep up the great work!
Fri Dec 07, 2018 12:16 am
Use the regex match for partial matches. Lots of examples for regex on the net.
Thu Dec 13, 2018 7:38 am
pgershon offline
I am just trying to set-up Better Email since my FIOS email on the regular client stopped working. Using MacMini running 10.13. When I install Better Email, I get errors in the log rapid-fire and need to deactivate. Any ideas?
Reloading plugin "Better Email 7.2.4"
Starting plugin "Better Email 7.2.4" (pid 85010)
Error receive socket select() 22 error
Thu Dec 13, 2018 3:45 pm
Is that before you created any devices? If not, what devices have you created? Show the device configuration.
