Dimming System Attachment Script
Mon Nov 06, 2006 8:20 pm
gregss offline
The attached script was originally posted in the Software Help forum. Now that I've updated it, I felt that it was more appropriate to post here.
This Attachment Script will allow you to set up soft-fade dimming scenes with just a few simple AppleScript commands. Using the methods in the attachment script, you can easily start dimming:
InitializeDim of "1st Floor - Family Room - Track Lights" to 0 given steps:30, rate:1, completionAction:"Dim Completion"
InitializeDim of "1st Floor - Family Room - Front Soffit Lights" to 0 given steps:10, rate:2, completionAction:""
ExecuteDimming()
Or, stop dimming for a device:
CancelDim for "1st Floor - Family Room - Track Lights"
Using script commands, you control how fast dimming should take place. You can event specify that an action group should be automatically executed when dimming is complete (if, for example, you want to take some sort of clean-up action or start up another dimmer).
And, because you would expect a dimmer to stop dimming if you tap the switch, this script also monitors INSTEON and X10 commands. If someone pushes the switch, dimming for all devices in the scene will stop. (Unfortunately, you may encounter a brief flicker as the levels update; due to queuing of commands by the interface controller, there isn't a whole lot you can do if a dimming command has already been readied for transmission.)
Follow the comments at the top of the script for set-up instructions.
Disclaimer: I've tested it with several dimmers in my INSTEON-enabled house with good results. I'll probably make a few changes here and there, and will be happy to re-post if there is any interest. I don't have any X10 devices to work with, though in theory, there is nothing to prevent this from working for X10.
The script is in the file library.
Fri Feb 02, 2007 10:55 am
Re: Dimming System Attachment Script
Greg --
Thanks for the terrific script.
Everyone else --
Be sure and check this one out of if you have any need for slow (over several seconds, minutes, or hours) dimming or brightening.
Regards,
Matt
Sun Oct 21, 2007 3:27 pm
echiehackett offline
error in dimming script
  Dimming System     Beginning to adjust on level of device 'Office-Desk Lamp 1' from 100 to 20.
  Sent INSTEON       "Office-Desk Lamp 1" on to 96
  Error              FindElem() failed to find action group elem
  Time/Date Action   _delayed_action_2
running 10.4.10 - go to run script and get the following error - and it just pauses at that point - it does the first "step" but doesn't repeat - when i go to run it again, i have to cancel it first then can run it again to get the second step
main file is in attachments and is set to run on startup - running indigo 2.0.9
thanks for any insight :)
Sun Oct 21, 2007 3:36 pm
gregss offline
(No subject)
Echiehackett,
Have you manually modified the script? FindElem() isn't a function used in the original version of the script.
A couple more questions for you: Is your device INSTEON or X10? And can you post the code snippet you're using to initialize the dimming operation?
-Greg
Sun Oct 21, 2007 4:12 pm
(No subject)
gregss wrote:
Echiehackett,
-Greg
haven't modified the script other than to set the delay between repeats from 2 seconds to 1 second (just downloaded a fresh script from the site) and left all as defaults
Insteon only is running on the network
Create a new trigger action or action group with the following code
InitializeDim of "Office-Desk Lamp 1" to 20 given steps:5, rate:4, completionAction:""
ExecuteDimming()
Sun Oct 21, 2007 4:15 pm
(No subject)
echiehackett wrote:
gregss wrote:
Echiehackett,
-Greg
ok - so here's the solution - read the directions - i was executing the file instead of the line "InitializeDimmingSystem()"
got it :)
Sun Oct 21, 2007 5:32 pm
gregss offline
(No subject)
Glad you got it figured out!
Fri Feb 22, 2008 11:52 pm
morps offline
(No subject)
After upgrading from 10.4 to 10.5, I am now running into the following error with the dimming system script:
 Error              script error: The Dimming System could not create or update the action group required to support dimming commands. Device dimming is not currently available through the Dimming System.
I experienced this error with 2.09 as well as beta 17 of 2.5. Any ideas?
Sat Feb 23, 2008 6:31 am
gregss offline
Things to Try
Morps,
Can you check a couple of things for me? First of all, in the log, do you see an entry labeled:
Dimming System
The Dimming System has been initialized.
If you do see this, then it's possible there are somehow multiple copies of the script. If not, have a look in your action groups to see if there is one labeled:
Dimming: Execute Dimming
If there is, everything should be ready to go, and I'm not sure why the script would complain. You have it in your attachments directory? Just for kicks, you could try a Scripts>Reload Attachments command and try again.
If all else fails, you can modify the script (as long as the action group above is installed). Find the line that has this on a line by itself:
_AddDimmingActionGroup()
(It's in the on _InitializeDimmingSystem() function.) You could comment out that line by adding two dashes (--) in front of it and reload your script attachments.
Hope this helps!
-Greg
Sat Feb 23, 2008 5:23 pm
morps offline
(No subject)
Gregss,
Thanks for the reply. it looks like all is well again... it appears that I was running into the 10.5.1 bug where embedded scripts were not compiling. As a result, all actions that were using Applescript were going south on me. After updating to Matt's latest beta, I seem to be in a much better place. I rebooted a second time after installing 2.5 b17 and that seems to have done the trick. Weird little demons musta been lurking :)
Thanks again!
Sun Feb 13, 2011 11:21 pm
artpics offline
Great Script works nice for my new aquarium
Fri Feb 18, 2011 11:07 pm
teejay6 offline
Very Cool! Worked right out of the box. Thanks for the script.
Mon Jul 18, 2011 7:54 am
GoBecky offline
Does this script still exist somewhere out there? Am getting a 404 when I attempt to download. Having installed my first dimmers this weekend, would love to have this sort of functionality!
I'm a wheelchair user & use Indigo to make my home & office accessible & safe without the expense of ECU's: door openers, emergency alerts, & even buttons my service dog can push to activate triggers! Feel free to PM fo info/advice.
Mon Jul 18, 2011 9:14 am
Greg posted it in the File Library (I also changed the link in the OP).
