uniFi WiFi AP: download
Mon May 06, 2019 7:53 am
Re: uniFi WiFi AP: download
posted: 7.26.163
fixed: "key ip.. not found in dict"
Sun Jun 16, 2019 2:12 pm
the new version .165 posted:
Will adopt / add an unify automatically --> indigo device if
- a sw / ap / gw slot (in config) is "disabled and the ip number is NOT a valid one"
- it assumes that if there is a valid IP number and you have disabled it might be temporary setting by the user and will not change that
==> when editing the IP number in config, you MUST edit the field then click on another text field. otherwise it will not save that field (that's from indigo)
so when eg you edit the ip number and click on enable/disable, the ip textfield contents will not be saved.
Wed Jun 19, 2019 10:22 am
new version 7.26.167 posted
Mojave seems to have problems with reading streaming files. It sometimes gives read error 22.
It looks as if a reduction in buffer size (from 32k to eg 16k) seems to solve that.
Added option to set read buffer for listeners - in config at the bottom.
Default is 32767(32k) .
Only change if you have read error 22,
Thanks to Wouter to help find this solution and test it.
- I am still on High Sierra on the Indigo server .. need to add a new graphics card to upgrade my MAC Pro
Wed Jun 26, 2019 9:36 am
release v 7.26.168
The camera event logs from unifi have changed with the recent unify NVR op sys upgrade
Now handles also the new version - detects both versions
Mon Jul 15, 2019 6:36 am
I don't see any other mention of this, but when I click the "download release 7.26.163" button on http://www.indigodomo.com/pluginstore/7 ... /7.26.163/ I get sent to
https://github.com/kw123/unifi/releases ... Plugin.zip which has nothing on it but "Not Found". Nothing downloads.
Mon Jul 15, 2019 12:41 pm
when i go to the plugin store and download the latest release it works fine. : v 7.26.168
oooh I see you want to download an older version.. and yes that one seems to have disappeared.. Also not on GitHub..
can't you use the latest V?
Tue Jul 16, 2019 11:34 am
I wasn't trying to download an old version, so I'm not sure how I got to that page. Actually I am--when I select Download New Version from the Unifiap plugin menu, it takes me to that page. Where I see:
Latest release: v7.26.168 released on June 26, 2019
Release downloaded: 1 times
Requires: Indigo v7.0.2 or higher
(Check the Releases tab below for older releases that may have different requirements)
Download release v7.26.163
That last line is the button to download. note the difference.
But I've got the current version now, from the link below that.
Tue Jul 16, 2019 4:54 pm
I guess the solution is to delete that one.. will ask Matt/ Jay.
==> Matt, Jay, could you remove the entry from the selection?.
http://www.indigodomo.com/pluginstore/73/#id1230
UnifiAP plugin release 7.26.163
Screen Shot 2019-07-16 at 17.44.49.png (177.96 KiB) Viewed 1534 times
Screen Shot 2019-07-16 at 17.42.23.png (368.29 KiB) Viewed 1534 times
Tue Jul 16, 2019 5:14 pm
Deleted. Given that you deleted it from GitHub, I believe it should stay deleted in the Plugin Store.
Tue Dec 03, 2019 1:37 pm
changes in V 7.26.169  @ 2019-12-03
1. added option for gateway devices to select which MAC number to be used for reports
   gateways have several MAC numbers, and depending on version the query has to pick the proper MAC number for querries in the controller
   in device edit you can pick the MAC number (MAC or MAClan)
