Feature Request - Device State for the Current Fav/Playlist
Sun May 29, 2016 4:42 pm
ckeyes888 offline
Hoping it may be possible to have a device state showing the current playlist or favorite
playing?
Carl
Mon May 30, 2016 6:37 am
autolog offline
Re: Feature Request - Device State for the Current Fav/Playl
Hi Carl,
It is certainly possible :wink:
I'll take a look and see what I can do for you :)
Jon
Mon May 30, 2016 10:10 am
ckeyes888 offline
Appreciate your looking into it, and thanks for your awesome plugins.
I use a number of Sonos players as well but it some cases there's nothing
better that a simple unit with hard buttons for presets/adjustments.
Carl
Mon May 30, 2016 11:55 am
autolog offline
I have got it to work when a playlist is selected and played. :)
Favourites are bit more problematic as the server doesn't return a favourite name when you play one, it just indicates that a new album or track is being played. Likewise with a preset (button press) - all you get is an indication that a button was pressed on a device. Even if you have a playlist in the the favourites, it doesn't indicate that that a playlist is playing.
There is an ability to look up any track that is playing and see if it is in a favourite but I am not sure how useful that is?
How exactly did you envisage this working and how do you use favourites?
Mon May 30, 2016 12:45 pm
ckeyes888 offline
Actually if there's an indication that a specific preset button is pressed that's good enough for me.
My use case comes from now having about 20 buttons on a CP for all kinds of music,
and in that some might play the same song from different sources I thought it would be
good to know which preset button was pressed to play it.
Carl
Mon May 30, 2016 1:35 pm
autolog offline
Now I am slightly confused :?
When I talk about a Preset Button, I mean one of the physical preset buttons (1-6) on say a Squeezebox Boom or Squeezebox radio.
Your reply indicates that you are referring to "preset" buttons on a Control Page (if I understand you correctly). When you press one of the Control Page buttons, what Squeezebox Action are you executing? I am not sure how my Plugin can work out which Control Page button you pressed?
Mon May 30, 2016 1:54 pm
ckeyes888 offline
Sorry, that's very true. If it only indicates an actual preset button press on the radio
that wouldn't be too useful. The CP buttons play fav's or playlists so you're right, might not
be of much help. Thanks for looking into it though!
Carl
