Nissan Leaf Plugin
Sat Aug 11, 2018 12:06 pm
Re: Nissan Leaf Plugin
Thanks Thomas!
Just got round to updating my copy of the plugin for the new address and my 2018 Leaf.
Peter
Fri Sep 14, 2018 3:37 pm
thomas-ja27 offline
Is there someone else getting this error?
Leaf 2018
The plugin logging successfully in to the Nissan server, but when it updating the status this error appears..
Nissan Leaf Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 171, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/indigo_leaf.py", line 146, in update_if_necessary
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/indigo_leaf.py", line 166, in request_and_update_status
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/indigo_leaf.py", line 295, in update_status
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/pycarwings2/pycarwings2.py", line 387, in get_latest_hvac_status
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/pycarwings2/responses.py", line 292, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/pycarwings2/responses.py", line 50, in _set_cruising_ranges
KeyError: 'CruisingRangeAcOff'
Nissan Leaf Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Thomas
Fri Sep 14, 2018 3:43 pm
thomas-ja27 offline
Tride to login to my dads 2015 leaf, get an error on that too, but not the same:
TypeError: list indices must be integers, not str
Thomas
Fri Sep 14, 2018 4:07 pm
No errors here, though I’m getting 0.0 miles as a result for that value.
Try editing/resave your device?
Peter
Fri Sep 14, 2018 4:33 pm
thomas-ja27 offline
I have deleted the plugin and the device and installed it again, and changed the base url, but get the same error.
Have also tried on an different Mac with a fresh indigo install :?
Thomas
Tue Feb 12, 2019 2:43 pm
dherren offline
I am unable to get this plugin to work. Running Indigo 7.2 and plugin version 0.2.1
I get this error when I try to enable to plugin:
Feb 12, 2019, 3:36:43 PM
Installing and enabling plugin Nissan Leaf v0.2.1
Loading plugin "Nissan Leaf 0.2.1"
Starting plugin "Nissan Leaf 0.2.1" (pid 79042)
Nissan Leaf Error Error in plugin execution InitializeMain:
File "plugin.py", line 9, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/indigo_leaf.py", line 5, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/pycarwings2/__init__.py", line 2, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Nissan Leaf.indigoPlugin/Contents/Server Plugin/pycarwings2/pycarwings2.py", line 73, in <module>
ImportError: No module named Crypto.Cipher
Stopping plugin "Nissan Leaf 0.2.1" (pid 79042)
Stopped plugin "Nissan Leaf 0.2.1"
Any suggestions?
Tue Feb 12, 2019 2:44 pm
lanbrown offline
What macOS/OS X version are you running?
The issue seems to be this:
Tue Feb 12, 2019 2:53 pm
dherren offline
My server is running on 10.12.6
On my desktop, 10.13.4
Tue Feb 12, 2019 3:52 pm
lanbrown offline
Wed Feb 13, 2019 11:15 am
dherren offline
That looked like it was the problem, and I was encouraged, but:
idiomatrix:~ sysadmin$ sudo easy_install-2.6 pycrypto
Password:
Searching for pycrypto
Reading http://pypi.python.org/simple/pycrypto/
Couldn't find index page for 'pycrypto' (maybe misspelled?)
Scanning index of all packages (this may take a while)
No local packages or download links found for pycrypto
I'm pretty inexperienced when it comes to installing such things. Was I to have downloaded something first?
Thanks for you help!
Wed Feb 13, 2019 11:38 am
dherren offline
OK, so new territory. I manually downloaded the source code to pycrypto. Then had to install the developer tools. Got the package compiled and installed.
This time around the plugin loaded. When I attempted to configure it, it generates the following error:
Error validating fields. Hover over the red field labels above to see the error reason.
There are no red labels. Using the same username and password I use for the Nissan Connect app on iPhone.
The Indigo log with debugging turned on for the plugin reports:
Feb 13, 2019 at 12:43:33 PM
Nissan Leaf Debug debug logging enabled
Nissan Leaf Debug using distance scale 'm'
Nissan Leaf Error Error in plugin execution UiValidate:
File "plugin.py", line 157, in validatePrefsConfigUi
KeyError: key username not found in dict
Fri Mar 01, 2019 2:10 am
Hi dherren
Sorry I’ve missed your posts.
Glad Ian could help with pointing you to pycrypto; the original dev has disappeared so I’m going to look at rewriting the plugin on the same codebase as my Tesla plugin.
In the meantime can you delete the Leaf plugin, browse to the Indigo folder in Finder and find the Leaf plugin prefs file and delete it - sorry I don’t have path to hand right now.
Then reinstall plugin.
Peter
