Homebridge 2.0 with Indigo plugin brings Siri to Indigo
Sat Nov 07, 2015 4:13 pm
webdeck offline
NOTE: I have locked this very long thread, which was migrated over from another forum. Please post new topics in their own threads in this forum - thanks!
Homebridge 2.0 - New Release
Homebridge has been upgraded to version 2.0, and with that, there is a whole new way of doing things. The plugins are now separate modules that are installed independently. That means I will be able to update the homebridge-indigo plugin without needing to wait for it to be merged into homebridge. That also means it's easy for anyone else who wants to contribute improvements to the homebridge-indigo plugin to submit them to me for inclusion. Also, it makes it easy to install other homebridge plugins to bridge other systems into HomeKit.
Migrating from Homebridge 1.0
This section is only relevant if you were using Homebridge 1.0. First, if you were using Homebridge 1.0, you'll want to stop your homebridge server, take your config.json file and persist directory, and copy them into a new .homebridge (yes, with a leading period) directory in your home folder. You may want to edit your config.json as I have added new features. See below for more details. Here are example commands to move your files to the right location:
cd path-to-wherever-you-have-homebridge-installed
mkdir ~/.homebridge
cp -rp config.json persist ~/homebridge
Installing Homebridge 2.0
See the new sticky thread with updated installation instructions.
-Mike
Sat Nov 07, 2015 4:51 pm
petematheson offline
Re: Homebridge 2.0 with Indigo plugin brings Siri to Indigo
Hey Mike - awesome work once again!
First one for you:
Loading 1 platforms...
[Matheson Manor] Initializing Indigo platform...
[Matheson Manor] Indigo base URL is http://127.0.0.1:8176
[Matheson Manor] Indigo request: http://127.0.0.1:8176/devices.json/
Loading 0 accessories...
/usr/local/lib/node_modules/homebridge-indigo/node_modules/request/request.js:1173
self.redirects.push(
TypeError: Cannot read property 'push' of undefined
at Request.onRequestResponse (/usr/local/lib/node_modules/homebridge-indigo/node_modules/request/request.js:1173:19)
at emitOne (events.js:77:13)
at ClientRequest.emit (events.js:169:7)
at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:415:21)
at HTTPParser.parserOnHeadersComplete (_http_common.js:88:23)
at Socket.socketOnData (_http_client.js:305:20)
at Socket.emit (events.js:169:7)
at readableAddChunk (_stream_readable.js:146:16)
at Socket.Readable.push (_stream_readable.js:110:10)
Sat Nov 07, 2015 4:55 pm
webdeck offline
Wow, that's an error inside the request module of Node. Can you share your config.json?
Sat Nov 07, 2015 5:00 pm
"bridge": {
"name": "Homebridge",
"username": "CC:22:3D:E3:CE:30",
"port": 51826,
"pin": "031-45-154"
"description": "This is an example configuration file to configure the Indigo platform plugin. See README.md for more details.",
"platforms": [
"platform": "Indigo",
"name": "My Indigo Server",
"protocol": "http",
"host": "127.0.0.1",
"port": "8176",
"path": "",
"username": "xxxxx",
"password": "xxxxx",
"includeActions": true
"accessories": [
Sat Nov 07, 2015 5:09 pm
Also just tried a re-install of Node and npm but getting the same error (since I installed previously for home bridge v1)
Sat Nov 07, 2015 5:20 pm
webdeck offline
First one for you:
It was an issue with how node is handling authentication with Indigo and redirecting that I missed. Great catch! I pushed a fixed version. Just do sudo npm install -g homebridge-indigo to pick up the fixed version.
-Mike
Sat Nov 07, 2015 5:34 pm
Now we're cooking - aside for some reason when I tried the re-install it's now decided to put it under a totally different directory under /opt instead of /usr
It scanned through all of my Indigo devices, but now I'm getting this error, possibly because of an Action Group?
[My Indigo Server] Ignoring unknown accessory type Plex Media Client
[My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20Kitchen.json
[My Indigo Server] Discovered Sonos Zone Player (ID 1822020093): Sonos Kitchen
[My Indigo Server] Ignoring unknown accessory type Sonos Zone Player
[My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20M ... droom.json
[My Indigo Server] Discovered Sonos Zone Player (ID 24514010): Sonos Master Bedroom
[My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/TekkersHQ%20Geofence.json
[My Indigo Server] Discovered Geofence Location Device (ID 1855040900): TekkersHQ Geofence
[My Indigo Server] Ignoring unknown accessory type Geofence Location Device
[My Indigo Server] Indigo request: http://127.0.0.1:8176/actions.json/
[My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/0.json
[My Indigo Server] Discovered Action (ID 345151065): 0
/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:45
if (!displayName) throw new Error("Accessories must be created with a non-empty displayName.");
Error: Accessories must be created with a non-empty displayName.
at IndigoActionAccessory.Accessory (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:45:27)
at IndigoActionAccessory.IndigoAccessory (/usr/local/lib/node_modules/homebridge-indigo/index.js:302:15)
at new IndigoActionAccessory (/usr/local/lib/node_modules/homebridge-indigo/index.js:729:21)
at IndigoPlatform.createAccessoryFromJSON (/usr/local/lib/node_modules/homebridge-indigo/index.js:278:16)
at IndigoPlatform.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/index.js:196:42)
at IndigoPlatform.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/index.js:269:17)
at Request.self.callback (/usr/local/lib/node_modules/homebridge-indigo/node_modules/request/request.js:373:22)
at emitTwo (events.js:87:13)
at Request.emit (events.js:172:7)
at Request.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/node_modules/request/request.js:1318:14)
Sat Nov 07, 2015 5:38 pm
webdeck offline
It looks like you have an action group that is named the single digit zero "0", which the Indigo RESTful API is returning as a number in JSON instead of a string. Can you rename the Action Group?
-Mike
Sat Nov 07, 2015 5:42 pm
Awesome, that all loads up now - cheers !
Last issue I have is that it's not displaying in mytouchhome, but that's something I can probably figure out.... Just going to try restarting things first. Cheers!
Sat Nov 07, 2015 5:45 pm
webdeck offline
-Mike
FYI, I just pushed version 0.2.2 that converts the names to be strings. A device name of "0" may still cause fits however, because that evaluates to false in JavaScript if you compare it as a boolean.
-Mike
Sat Nov 07, 2015 5:49 pm
webdeck offline
HomeKit easily gets confused. It's usually one of these two cases:
  1. Homebridge server thinks it's been paired with, but iOS thinks otherwise. Fix: delete the persist directory in your ~/.homebridge directory and restart homebridge.
  2. iOS device has gotten your Homebridge "username" (MAC address) "stuck" somehow, where it's in the database but inactive. Fix: change your "username" in the "bridge" section of config.json to be some new value (e.g. change the ending 30 to 31) and restart homebridge.
-Mike
Sat Nov 07, 2015 6:02 pm
Almost there, still no luck though!
It now discovers Homebridge, but just says 'Adding Failed' Could not connect to accessory.
Sat Nov 07, 2015 6:04 pm
webdeck offline
Any errors from the homebridge output log?
-Mike
Sat Nov 07, 2015 6:06 pm
Sorry, where do I find those exactly?
Sat Nov 07, 2015 6:08 pm
webdeck offline
Sorry, by output log I meant what it is printing out in the Terminal window where you ran the homebridge command. It doesn't get saved to a file by default, it just prints it to the Terminal window.
-Mike
