Plugin for Haiku Fan with SenseME
Sun May 13, 2018 7:43 am
norcoscia offline
Re: Plugin for Haiku Fan with SenseME
Does anyone know if the SenseME plug-in supports Haiku Lights (the light w/o a fan) - Link to them below.
BTW, I have been using this plug in for many months and it works great - it also lets me use the fans other sensors within Indigo. It is a great plug-in and the fans are fantastic.
I'm think about adding two of the standalone lights but I did not see mention of them anywhere in the plug-in documentation. Thanks for any help in advance
https://www.haikuhome.com/haiku-light-p ... odel-white
_______
Norm
Mon Sep 10, 2018 8:21 pm
fishmg01 offline
[quote="bap"]HI all,
I've just released version 0.6 of the SenseME plugin,. This is a pretty major update to the plugin......
Bruce,
I am thinking of purchasing a Haiku fan, and since its been some time since you released version 0.6 of your plugin, I'm wondering whether you know if its still compatible with the most recent Haiku fans and WIFI modules - specifically , with what they are calling their: Haiku WiFi Module for Haiku L Ceiling Fan.
Sat Oct 06, 2018 4:38 pm
gt3mike offline
Hi Bruce,
I've been using plugin 0.6.1 for several months now with no issues. Today I installed version 0.7.0 and I immediately got this error in the Indigo log:
   SenseME Fan Error               Error in plugin execution runConcurrentThread:
  File "plugin.py", line 515, in runConcurrentThread
  File "plugin.py", line 434, in processFanMessage
KeyError: 'key fanTempUnits not found in dict'
   SenseME Fan Error               plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
The error appeared one more time 10 seconds later, and then I didn't see it again. But when I attempted to update my device configuration for my one Haiku fan, I got this error and the config wouldn't save:
   SenseME Fan Error               Error in plugin execution UiValidate:
  File "plugin.py", line 553, in validateDeviceConfigUi
ValueError: invalid literal for int() with base 10: ''
I rolled back to plugin 0.6.1 and it is working fine again. Is there anything you'd like me to test or check?
Mike
Mon Oct 08, 2018 10:22 pm
Ramias offline
Same.
Though saw this when trying to add a new Indigo Device for a fan.
  File "plugin.py", line 544, in validateDeviceConfigUi
KeyError: (1488353430,)
If I set it to Celsius, it shows this error:
  File "plugin.py", line 547, in validateDeviceConfigUi
ValueError: could not convert string to float:
For what it is worth I did not have Sleep Mode or Smarter Cooling turned on. But turning those on gave the same result.
Mon Nov 26, 2018 8:41 am
gt3mike offline
I just updated to Indigo 7.2 so I thought I'd try SenseME again. Now I can't add my fan at all. (Prior to the Indigo upgrade I removed the SenseME plugin from Indigo. So this is a new install.)
Now the error I get when I try to save my new fan config is:
KeyError: (258863032,)
Also I am getting an error in the config popup directing me to a red label, but no labels are red. (See attachment.)
Screen Shot 2018-11-26 at 7.36.36 AM.png (100.31 KiB) Viewed 91 times
Please advise. Using SenseME plugin 0.7.0.
Mon Nov 26, 2018 9:00 am
norcoscia offline
I could never get the latest version of the Haiku Fan plug-in to work - I also had to roll back to 0.6.1 - I would try that. Just disable the latest version, then move it to the trash and load 0.6.1, Indigo will ask you if you want to roll back to a previous version, click yes and I'm fairly sure you will be working...
_______
Norm
