Honeywell Thermostat
Tue Aug 19, 2014 6:03 pm
nlagaros offline
First attempt at a plugin for the newish Honeywell thermostats!
Adjust your thermostat from anywhere. Create your own unique look to match your home’s decor. Enjoy unsurpassed comfort control. Receive reminders to change a filter or be alerted of extreme home temps. Beauty and brains collide with Honeywell’s Smart Wi-Fi Thermostat.
v0.1.0 - 08/19/2014
  • The plugin was created as an extension to basic Indigo thermostat control. There is currently no ability to know if heating or cooling is actually running.
  • This seems to be a limitation of the Honeywell Total Connect Comfort API.
  • Note that this plugins requires connectivity to the Total Connect Comfort website. Each device is configured with the Device ID that is in the URL line of the website.
  • Thanks to Brad Goodman for reverse engineering connectivity to the Honeywell website. There is no public API that is being shared at this point in time.
  • Limited testing has been done with the Honeywell WIFI 9580 Thermostat.
Download from my wiki page: https://vulture.lagaros.com/wiki/projects/homeautomation/Home_Automation.html
Sat Aug 23, 2014 9:42 am
nlagaros offline
Honeywell v0.1.1 Beta
v0.1.1 - 08/23/2014
  • Added logic to guess when cooling and heating equipment is running. Must re-save device configurations.
  • Added an action to dump JSON data to Indigo log.
Sat Sep 13, 2014 3:02 am
nlagaros offline
Honeywell v0.1.2 Beta
v0.1.2 - 09/13/2014
  • Updated plugin for Honeywell website changes.
  • Added logic to detect internal humidity sensor.
Wed Sep 17, 2014 11:10 am
nlagaros offline
Honeywell v0.1.3 Beta
v0.1.3 - 09/17/2014
  • Additional fixes for Honeywell website changes.
  • Added plugin configuration for Polling Time. Default value = 30 seconds.
Please re-save plugin configuration.
Sun Oct 26, 2014 2:47 pm
nlagaros offline
Honeywell v0.2.0 Beta
v0.2.0 - 10/25/2014
  • Cleaned up error handling.
The Honeywell website seems to be unavailable more frequently than it should. I've put retry loops in for many actions and made the error reporting a bit more gentle.
Sat Nov 29, 2014 3:36 am
nlagaros offline
Honeywell v0.2.1 Beta
v0.2.1 - 11/29/2014
Honeywell was at it again - they updated URLs on their website. Perhaps they will actually release an API to the public sometime.
Download here: https://vulture.lagaros.com/wiki/projects/homeautomation/Home_Automation.html
Wed Mar 16, 2016 3:17 am
nlagaros offline
Honeywell v0.3.0
v0.3.0 - 03/15/2016
  • Official Honeywell API!
  • Wi-Fi Models 6880, 8580, 9580, 9590 supported.
Everything you need to know about the re-release of the Honeywell Thermostat Plugin is here: https://vulture.lagaros.com/wiki/pages/d017N1W5/Honeywell_Thermostats.html
As always, please report any issues you encounter.
Have fun!
Sat Apr 30, 2016 4:41 am
nlagaros offline
Honeywell v0.4.4
v0.4.4 - 04/29/2016
  • Official evohome support.
Thank you to all that helped test this out! Please report any issues. As always, not much if any documentation exists (yet).
For evohome device owners:
  • Enter your Total Connect Comfort credentials in the plugin configuration.
  • Select "Log evohome TCC Device IDs" from the Plugins/Honeywell menu. If credentials are correct, it will return a list of all evohome devices to the Indigo log.
  • Select "Create evohome Devices" from the Plugins/Honeywell menu. This will iterate through all devices configured on the TCC site and add them to Indigo.
Wed Jul 27, 2016 12:29 pm
nlagaros offline
Honeywell v0.4.5
v0.4.5 - 07/27/2016
  • Refactored code in main thread. Removed daily plugin re-starts.
Sun Aug 07, 2016 6:14 am
nlagaros offline
Honeywell v0.4.6
v0.4.6 - 08/06/2016
  • Adjusted setpointStatus code to support additional Prestige thermostats.
Thu Nov 24, 2016 7:55 am
nlagaros offline
Honeywell v0.5.0
v0.5.0 – 11/24/2016
  • This plugin now requires Indigo v7.
  • Adjusted logic to be more sensitive to Honeywell TCC website outages.
  • Added plugin configuration parameters for refresh interval and maximum consecutive errors before re-authenticating to TCC.
*DO NOT UPGRADE IF YOU ARE NOT RUNNING INDIGO V7*
Sat Feb 18, 2017 4:41 pm
Professor Falken offline
Re: Honeywell Thermostat
Is there a way to download this plugin at present?
The links seem to point to a disabled server.
Sun Feb 19, 2017 1:52 am
CliveS offline
CliveS
Indigo 7.3.0 : MacOS High Sierra 10.13.6 : Mac mini Server (Mid 2011) : 2 GHz Core i7. : 8 GB. : 2 x 256GB Samsung EVO SSD
Tue Feb 21, 2017 1:22 pm
Got it, thanks
Wed Jul 05, 2017 10:15 am
nlagaros offline
Honeywell v0.5.1
v0.5.1 - 07/05/2017
  • WiFi: Removed error logging for equipmentOutputStatus and fanMode.
  • WiFi: Added custom action to set Cool/Heat Setpoint with permanent or temporary hold.
  • WiFi: Bug fix for Setpoint Status action for thermostats with Auto Cool/Heat configuration.
  • WiFi: Added plugin configuration option to choose either temporary or permanent hold for Setpoint changes made with Indigo UI.
Download here: http://vulture.lagaros.com/IndigoPlugins/Honeywell/Honeywell.indigoPlugin_0.5.1.zip
