jay (support) wrote:But the cloud-based thing is really becoming a non-starter for me.
+1
jay (support) wrote:Here's to hoping that we can get a working Z-Wave controller someday.
+5
berkinet wrote:Korey wrote:...Looks like the new firmware will include a Pause:...
...Web interface
...- Added Pause feature, a pause button will show up during watering that allows user to delay the watering for 30 minutes.
Interesting they documented the pause feature under the web UI. Maybe it is not supported in the API, yet.
- Updated API to 4.6 version to reflect the new API calls like Pause.
Korey wrote:...
- Code: Select all
jay (support) wrote:...Here's to hoping that we can get a working Z-Wave controller someday.
berkinet wrote:Well, there is the Nortek GoControl WI15VZ-1, also sold by Homeseer. (Matt has previously commented on this).
lanbrown wrote:berkinet wrote:RogueProeliator wrote:Note: It is possible to use a wired ethernet adapter with the Rainmachine. There are some minor limitations dealing with setup, but it works. Check their forums. AND, the next version, the PRO version, will directly support wired ethernet.Got my RainMachine installed yesterday evening and.. color me impressed so far. Didn't go too far into the configuration, just ended up running some zones manually. But the setup was nice and clean and the app is pretty well done from what I have seen.
Hope to dig more into this very shortly...
Where did you hear about the Pro version? Wired Ethernet is what I want and I'm contemplating replacing my Skydrop with a RainMachine and even found a PoE splitter that can provide AC that it requires. Having Ethernet in it natively will be much better though...even if a PoE splitter is required.
I am looking to get my rainmachine in a few months, and given how hyper localised the rain has been recently, the nearest wunderground weather station 2 miles from me has regularly had storms and 5mm of rain to my none, I am looking at getting a weather station.
What are my best options now that wunderground doesnt let you have access to your own data? As RainMachine uses the no longer supposed free API keys, I guess that is no longer an option. It supports Netatmo directly, so is that my obvious option, as I was looking at other stations that I could use with WeatherSnoop and have local data to analyse as well as on Netatmo's cloud.
RogueProeliator wrote:[...SO, I plan on just seeing how it goes and only adding a sensor if it becomes necessary....
Note you can use multiple weather data sources and weight them. Between that, and adding a local rain sensor things should be ok. Note that while rainfall may vary over short distances, other factors like cloud cover, temperature and humidity may not. So, in spite of the difference in rainfall, the ETo calculation is likely to still be useful.
RogueProeliator wrote:...about 3 or 4 in the afternoon and then cloudy for a bit while the afternoon rains run in......
siclark wrote:So it sounds like you are saying don't but new toys?? I thought you guys at least would encourage that
But yes it's probably something I should only decide once I've used it a bit. For now I know I over water but as 2 days ago was first rain for 2 over 2 months that hasn't been a problem!!
(And yes I live in the UK!)...
