Pushover Plugin - push notifications
Thu Oct 18, 2018 6:28 pm
gt3mike offline
Re: Pushover Plugin - push notifications
Does the Pushover iOS app support 3D Touch actions on the lock screen? So far I don't see it. I've tried to search for an answer, but this forum software ignores "3D" in searches, so I can't easily search for it.
My use case is I get a push notification if I've left home without arming the alarm. I'd like to use a 3D Touch action on the lock screen notification to arm the alarm. (Not sure how I will do that yet. Maybe it will involve invoking Indigo Touch via URL? One step at a time.)
Thu Oct 18, 2018 6:29 pm
You really need to ask the developer of the iOS app about that.
Thu Oct 18, 2018 6:57 pm
gt3mike offline
It does put "Open URL" on the lock screen in response to a hard press, but it requires unlocking the phone. I'm asking them whether there is a way to invoke a URL without unlocking the phone where I'm calling a trigger and don't need to see the response.
Thu Oct 18, 2018 6:58 pm
Well, posting here you're not asking "them" anything.
Thu Oct 18, 2018 7:21 pm
gt3mike offline
I’ve already asked “them”. Was just posting some info others might find interesting or helpful. Have a nice day. :)
Thu Oct 18, 2018 7:25 pm
Ok, it looked to me like you were asking a question about the iOS client, If not, sorry for the confusion.
Fri Oct 19, 2018 4:55 pm
gt3mike offline
The response from the Pushover iOS app developers is that the only actions that can be done from the Pushover push notification without unlocking the iOS device are actions within the Pushover app itself. Anything that calls another app (such as Open URL) requires unlocking the phone. Makes total sense.
I was hoping there might be a way to invoke Indigo actions from push notifications without having to unlock the phone. Seems like the only way that would be possible would be if Indigo Touch supported push notifications natively. Sounds like an Indigo feature request. I'll take this conversation over there.
Mon Oct 22, 2018 9:11 am
WagnerOne offline
Is there a way to bulk edit Pushover entries? Either via db query or a config file somewhere?
I'd like to add a "indigo://" URL to all of my notifications so I can tap to launch the Indigo Touch app.
Mike
Mon Oct 22, 2018 9:12 am
You mean action groups containing pushover notifications? Or schedules? Or triggers?
Mon Oct 22, 2018 9:24 am
Be very careful. You can break your Indigo install doing this.
1. Shut down Indigo, client AND server.
2. Back up your current Indigo database (<something>.indiDb file)
3. Open the database in a text editor. Like BBEdit or TextWrangler. Not something that does formatted text.
4. Search for "io.thechad.indigoplugin.pushover". You'll find entries like:
               <Action type="dict">
                  <Class type="integer">999</Class>
                  <MetaProps type="dict">
                     <io.thechad.indigoplugin.pushover type="dict">
                        <msgAttachment type="string"></msgAttachment>
                        <msgBody type="string">Email received test</msgBody>
                        <msgDevice type="string"></msgDevice>
                        <msgPriority type="string">0</msgPriority>
                        <msgSound type="string">pushover</msgSound>
                        <msgSupLinkTitle type="string"></msgSupLinkTitle>
                        <msgSupLinkUrl type="string"></msgSupLinkUrl>
                        <msgTags type="string"></msgTags>
                        <msgTitle type="string">Email received test</msgTitle>
                        <msgUser type="string"></msgUser>
                     </io.thechad.indigoplugin.pushover>
                  </MetaProps>
                  <ObjVers type="integer">14</ObjVers>
                  <PluginID type="string">io.thechad.indigoplugin.pushover</PluginID>
                  <TypeIdPlugin type="string">send</TypeIdPlugin>
                  <TypeLabelPlugin type="string">Send Pushover Notification</TypeLabelPlugin>
               </Action>
5. Add the URL string to the appropriate field(s). I don't use Pushover much, so I'm not sure where it goes. Probably msgBody or msgSupLinkUrl. If you have one notification that works the way you want, find it then copy the fields to the others.
6. Repeat for each Action block you find.
7. Save the file, restart Indigo.
Fri Nov 23, 2018 10:15 pm
mattyf offline
I can't seem to get this working. I can send notifications through pushover via a shell script fine, but not though the plugin. I'm confused if this is the right forum even, because my plugin version is 2.0.4 according to the plugin menu, but this forum seems to say latest version is 1.4.0?
The only thing I'm not sure of is what's supposed to go in username in the plugin configuration. All my shell script needs is the API and user keys.
Sat Nov 24, 2018 7:30 am
Don't know what plugin you've got, but it's not the Pushover one. Download the correct one from the Plugin Store: http://www.indigodomo.com/pluginstore/14/
Fri Feb 22, 2019 7:57 pm
Dual online
How do I get my energy meter energy usage value into my pushover notification? I found the post for using variables: %%v:12345%%
Is there a way to do it directly without a variable?
Fri Feb 22, 2019 8:10 pm
If it's a device state, then you can do that substitution as well.
Fri Feb 22, 2019 8:15 pm
dduff617 offline
if your energy meter usage value is a property of an indigo device, then you can use the syntax "%%d:nnnnnn:stateid%%", where you would replace "nnnnnn" with the numeric deviceID and "stated" with the name of the state.
