Pushover Plugin - push notifications
Wed Feb 14, 2018 4:44 pm
Re: Pushover Plugin - push notifications
Apparently the last version the developer released has a bug. Another user has added an issue on GitHub with a potential solution but didn't issue a pull request with the fix. Because the plugin is open sourced, anyone is welcome to fix the bug in 1.2.0.
I recommend reverting back to 1.1.6 until the fix gets published.
swisskent wrote:
IMHO, the Pushover plugin should be a well-maintained Indigo default plugin.
Everyone believes that about their favorite/most critical 3rd party plugin. We created the 3rd party plugin mechanism so that other developers could add functionality because we just don't have the bandwidth to do it all. I guarantee that a lot more people would be unhappy if it took even longer for new Z-Wave devices to get supported. Or a REST API that includes plugin devices, or any of a hundred other things that people think are more important than Pushover.
Wed Feb 14, 2018 4:59 pm
Good news guys - GitHub user jcs (also a forum user) issued a pull request with the fix. I accepted it (on behalf of the developer), created a new release, and added it to the Plugin Store. It's listed as v1.2.2 (and is the latest release in the Plugin Store).
Happy Valentine's Day (and thanks @jcs)!
Wed Feb 14, 2018 5:00 pm
PS - @swisskent, apparently your forum email address is about to stop working (we got a bounce from you) so you probably should change it before it stops working...
Wed Feb 14, 2018 7:27 pm
swisskent offline
Thank you for resolving this issue!
Because notifications are such an important component of automation systems, I would like to request that native OS and iOS Notifications be included in a future release of Indigo.
Wed Feb 14, 2018 9:04 pm
jcs offline
Hi all, sorry I broke the previous version but it should be fixed now. (I only knew it was broken when I wasn't getting Pushover notifications myself when playing with a new device today, but I've subscribed to this topic in my RSS reader so I'll know sooner if things go wrong in the future.)
As for the delays in notifications with image attachments, those are actually due to the iOS app and not any Indigo issue. A new Pushover for iOS release is in beta testing that should make things a bit faster. I'm not well versed in Indigo's plugin architecture so I don't know if there is a formal way for other camera plugins to hand image data to the Pushover plugin, but adding the code to upload images should be pretty easy.
Thu Feb 15, 2018 10:15 am
We include a plugin for Growl, which puts notifications into the Mac notification center and if you have the Prowl app installed on your iOS device it pushes notifications there as well.
Adding push notifications to Indigo Touch is on the feature request list as well.
You can do notifications to the notification center as well on your Mac with a simple script (requires Indigo 7.1):
import applescript
notification_script = 'display notification "{}" with title "{}"'
title = "Some title here"
message = "Some message here, could come from variable or device, etc."
script_source = notification_script.format(message, title)
script = applescript.AppleScript(script_source)
script.run()
Sat Feb 17, 2018 11:00 am
roquej online
Version 1.2.2 worked originally, then all of a sudden getting:
Pushover Error Error in plugin execution ExecuteAction:
File "plugin.py", line 56, in send
KeyError: key msgUser not found in dict
Had to go back to 1.1.6, which works without issues or changes in configuration.
Suggestions?
JP
Sat Feb 17, 2018 11:18 am
jcs offline
If you update to 1.2.2, then open the Trigger that tried to send that notification, then edit the Pushover action, and just hit Save, does it work after that?
Sat Feb 17, 2018 4:08 pm
roquej online
Ok. the re-saved solved the issue. However, the fix doesn't work if use python to send messages.
JP
Sun Feb 18, 2018 6:32 am
haavarda offline
I would assume that pointing to a file in finder would be the most common way to solve this? I have a trigger that stores a picture in a folder when triggered. With file path to this file I could send any image. Is this possible?
Håvard
Sun Feb 18, 2018 7:12 am
CliveS offline
JP
If you are using the python code shown previously from this thread then just add the line
'msgUser' : 'YourUserKeyHere', as below
priority = 0
alertPlugin = indigo.server.getPlugin('io.thechad.indigoplugin.pushover')
if alertPlugin.isEnabled():
   alertProps = {  'msgTitle'       :      'Window and Door Status',
               'msgBody'        :       str(msg),
               'msgSound'       :      'pushover',
               'msgPriority'    :      priority,
               'msgDevice'      :      '',
               'msgSupLinkUrl'  :      '',
               'msgSupLinkTitle':      ''
   alertPlugin.executeAction("send", props=alertProps)
   indigo.server.log('pushover plugin is not available')
Works with 1.2.2 for sending all my window and door states if anyone of them is open when we go out.
CliveS
Indigo 2021.1.0 : MacOS Catalina 10.15.1 : Mac mini Server (Mid 2011) : 2 GHz Core i7. : 8 GB. : 2 x 256GB Samsung EVO SSD
Sun Feb 18, 2018 11:52 am
Version 1.3.0 has been published to the Plugin Store and includes an action to cancel emergency notification retries (thanks again @jcs for the contribution).
Sun Feb 18, 2018 8:26 pm
roquej online
CliveS wrote:
JP
priority = 0
               'msgDevice'      :      '',
Worked great. Thank you!
JP
Mon Feb 19, 2018 7:51 am
haavarda offline
There is now a pull request on github that adds the possibility to send images. Any chance of a quick approval?
Håvard
Mon Feb 19, 2018 7:54 am
vtmikel offline
In the meantime, would be great if you could test. Grab it here: https://github.com/mlamoure/indigo-pushover
Page 10 of 14 1 ... 7, 8, 9, 10, 11, 12, 13, 14
