SQLite, shell script, CSV, google Spreadsheet, Ducksboard
Wed Aug 28, 2013 2:20 pm
henkjanvries offline
Ive been trying to grab data from the sqlite db, export it to a csv file, than automagically import it to a google spreadsheet. From there use that info to fill a Ducksboard dashboard.
And ive actually done it!
but now my issue.
I have 5 temperature sensors. All installed and connected to rfxcom at the same time.
But for some reason the output of all 5 is different. The amount of rows put into the sqlite is not the same.
some have 50 records, anther just 10.
But all last records have similar timestamps.
and another thing thats weird is that the timestamp column is 2 hours earlier than the lastupdated column.
having all sensors input data into ducksboard and therefor have a nice chart with 5 lines only works if all data is the same (at least the amount of rows)
if anyone can help all data is available.
thanks!
Wed Aug 28, 2013 4:02 pm
Re: SQLite, shell script, CSV, google Spreadsheet, Ducksboar
Unfortunately I don't think the rows are going to match. The RFXCOM sensors I have seen have a moderate amount of variance in their broadcast durations, and Indigo only writes data to the SQLite database if the state (temperature) actually changes.
Ducksboard looks interesting. I've wanted a good configurable dashboard visualizer.
Wed Aug 28, 2013 5:08 pm
I have a script running that appends to a csv file every 2 minutes with
- all temperatures (internal + external) , humidity, a/c heat, fan , energy used KWH, KW etc
Then you can use either excel or .. what ever you like.
The parameters might have not been updated, but at least the time "column" is the same for all measurements, makes live easier.
Sun Sep 01, 2013 2:31 am
could you send the script? im really interested in how to do that
Sun Sep 01, 2013 7:39 am
here you go, see attached applescript.
write all info on temperatures, humidity, AC/(Heat to be added) on off, Fan on/off,  etc to comma delimited file, to be used by excel in ie "xy plot"
V1.0
Karl Wachs
info per thermostat:
- set temp,  actual tem fan on/off ac on/off, heat on / off   for 4 thermostats
info from other temp sensors tem and hunidity
info from NOA on current humidity
AC on off is written as 0/100 so that in excel it can use the same scale as temperature (inside 65-80 outside 20-105)
call on a fixed schedule ie 2 or 5 minutes, to have equal bin size. makes plotting easier
all info has to be in variables:
as part of the scheduled action,  copy all info from thermostat etc into variables
-- get date string
set rightNow to (current date)
set theTime to text -8 thru -1 of ((current date) as «class isot» as string)
set YR to ((year of rightNow) as text)
set MO to ((month of rightNow) as integer)
if MO < 10 then set MO to "0" & MO as text
set MO to MO as text
set DA to ((day of rightNow) as integer)
if DA < 10 then set DA to "0" & DA as text
set DA to DA as text
set rightNow to YR & "/" & MO & "/" & DA & " " & theTime
set rightNow to rightNow as text -- YYYY/MM/DD HH:MM:SS   in 24 hour mode
-- setup output file
set outputfile to "energyused.csv"
--create headerline if called first time
set myPath to "/Users/karlwachs/Documents/scripts/" & outputfile
set create to "yes"
try
   POSIX file myPath as alias
   set create to "no"
end try
if create = "yes" then
   set outcmd to "echo  \"YYYY/MM/DD HH:MM:SS, AccumKWH, KW, ACU, ACD, ACE, ACG, TempU, TempD, TempE, TempG,fanU, FanD, FanE, fanG, ACsetU, ACsetD, ACsetE, ACsetG, TempU2, TempD2, HumU, HumD, TempOut, HumOut  \"  > " & myPath
   do shell script outcmd
end if
-- get variables
using terms from application "IndigoServer"
      -- ac on / off
      set ACU to (get value of variable "ThermostatUpstairsAC") as text
      set ACD to (get value of variable "ThermostatDownstairsAC") as text
      set ACE to (get value of variable "ThermostatExerciseRoomAC") as text
      set ACG to (get value of variable "ThermostatGameRoomAC") as text
      if ACU = "true" then
         set ACU to 100
      else
         set ACU to 0
      end if
      if ACD = "true" then
         set ACD to 100
      else
         set ACD to 0
      end if
      if ACE = "true" then
         set ACE to 100
      else
         set ACE to 0
      end if
      if ACG = "true" then
         set ACG to 100
      else
         set ACG to 0
      end if
      -- fan on / off
      set fanU to (get value of variable "ThermostatUpstairsFan") as text
      set fanD to (get value of variable "ThermostatDownstairsFan") as text
      set fanE to (get value of variable "ThermostatExerciseRoomFan") as text
      set fanG to (get value of variable "ThermostatGameRoomFan") as text
      if fanU = "true" then
         set fanU to 100
      else
         set fanU to 0
      end if
      if fanD = "true" then
         set fanD to 100
      else
         set fanD to 0
      end if
      if fanE = "true" then
         set fanE to 100
      else
         set fanE to 0
      end if
      if fanG = "true" then
         set fanG to 100
      else
         set fanG to 0
      end if
      -- current actual temps
      set tempU to (get value of variable "ThermostatUpstairsTemp") as text
      set tempD to (get value of variable "ThermostatDownstairsTemp") as text
      set tempE to (get value of variable "ThermostatExerciseRoomTemp") as text
      set tempG to (get value of variable "ThermostatGameRoomTemp") as text
      -- current setpoints
      set ACsetU to (get value of variable "ThermostatUpstairsACSetPoint") as text
      set ACsetD to (get value of variable "ThermostatDownstairsACSetPoint") as text
      set ACsetE to (get value of variable "ThermostatExerciseRoomACSetPoint") as text
      set ACsetG to (get value of variable "ThermostatGameRoomACSetPoint") as text
      -- temps and humidity from additional sensors
      set tempD2 to (get value of variable "Stanford_Inside_Temperature_Downstairs") as text
      set tempU2 to (get value of variable "Stanford_Inside_Temperature_Upstairs") as text
      set humD to (get value of variable "Stanford_Inside_Humidity_Downstairs") as text
      set humU to (get value of variable "Stanford_Inside_Humidity_Upstairs") as text
      set tempOut to (get value of variable "Stanford_outside_Temperature") as text
      set humOut to (get value of variable "NOA_loveField_humidity") as text
      -- accumulated KWH
      set KWH to (get value of variable "KWH") as text
      -- current KW
      set KW to (get value of variable "KW") as text
   end tell
end using terms from
-- now append info t csv file
set writeText to rightNow & ", " & KWH & ", " & KW & ", " & ACU & ", " & ACD & ", " & ACE & ", " & ACG & ", " & tempU & ", " & tempD & ", " & tempE & ", " & tempG & ", " & fanU & ", " & fanD & ", " & fanE & ", " & fanG & ",  " & ACsetU & ", " & ACsetD & ", " & ACsetE & ", " & ACsetG & ", " & tempU2 & ", " & tempD2 & ", " & humU & ", " & humD & ", " & tempOut & ", " & humOut
set outcmd to "echo  \" " & writeText & "\"  >> " & myPath
return true
Sun Sep 01, 2013 9:31 pm
hamw offline
That looks pretty neat. What would one have to change in the script to adapt it to a different system? Obviously it would be convenient to change the names, but does the POSIX path need to change or other stuff?
Sun Sep 01, 2013 9:53 pm
you have to
1. change the path of the file to where ever you want to put the file, change:
set myPath to "/Users/your userid here/Documents/" & output file
2. save the file applescript file to ....indigo 6/scripts/attachments as app (export from applescript editor as app)
in indigo reload attachments under PLUGINS
3. define/create the variables as you need
4. setup scheduled action with actions:
- update variables from device1
- update variables from device2
- execute script as file after delay of 1 sec to make sure that the variables are updated.
let me know if you need more info
Wed Jul 16, 2014 12:16 pm
mrosenblatt offline
Karl,
Just wanted to let you know I found this thread today, and used your script - was exactly what I was looking for.
I couldn't get it to run as a app, kept giving an alert box "Application Not Running", but when I embedded it in the Indigo schedule it worked fine.
Great work. Thank you for contributing.
Michael
Wed Jul 16, 2014 10:02 pm
welcome..
