Sun Nov 27, 2016 4:34 pm
ryanbuckner offline
I deleted it and re-added it. It's being updated so I'm not sure why the sporadic errors.
Sun Nov 27, 2016 6:49 pm
Will check a little bit more in the next days. One explanation is the extra space. The variable looks identical you can see the blank. Had that before. Took me a long time to figure it out.
Sun Nov 27, 2016 10:15 pm
I looked at the logic:
it tries to update the variable. if it can not do that it will restart.
then at restart if will try to create that variable.
so if it works again after restart variable must be either unavailable or does not exist.
does not exist: something has deleted it.
can not update due to .?: could be that indigo is busy. That happens when an applescript runs and blocks indigo ( one of my favorite.) You will find that in the indigo or the general system log file as a timeout.
Tue Oct 10, 2017 7:43 pm
roquej offline
Karl,
Incorrect file attached to the latest version. It points to the uniFi plugin.
JP
Tue Oct 10, 2017 8:14 pm
sorry.. should be fixed now
Tue Nov 19, 2019 6:12 pm
Rjay offline
hey mate, after the recent issue with change to Mac OS Catalina the command line changes you specified worked. Since then the new version of Fingscan that came out I upgraded to but I am now seeing this in the log Windows consistently;
File "plugin.py", line 4531, in runConcurrentThread
File "plugin.py", line 4578, in dorunConcurrentThread
AttributeError: 'Plugin' object has no attribute 'quitNOW'
fingscan Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
19 Nov 2019 at 9:56:04 pm
fingscan Error Error in plugin execution runConcurrentThread:
Tue Nov 19, 2019 7:20 pm
could you a disable and enable plugin
then I need the FIRST error message. The quitNOW can not be the first one.
the log should start w:
FINGSCAN-- initializing will take ~ 2 minutes...; sending logs to ....
also check the plugin.log file /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log
Thu Nov 21, 2019 12:57 am
Rjay offline
No problems :)
Ok Error1 below I think is the full error while running from the top
Error2 is after a restart of plugin :)
thanks
Error2.txt
(3.78 KiB) Downloaded 21 times
Error1.txt
(1.17 KiB) Downloaded 17 times
Thu Nov 21, 2019 8:26 am
If you look at the restart logfile it states the plugin name is not correct
You like had an old plugin in download and the new one is now named -2
Stop the plugin
Rename the plugin to the correct name - remove the -2
And reload
Thu Nov 21, 2019 11:11 am
Out of interest, why does this affect the plugin running?
A few of my plugins have ended up being named-2 but other than annoying my OCD, it doesn’t affect the plugin...?
Peter
Thu Nov 21, 2019 11:17 am
All Kind of indigo function stop working and the path references are screwed up
There is the fileName and the plugin name in the props files- they must be the same at least after the first install no change is good
It’s not a plugin issue but driven by indigo functions.
This is a common mistake that’s why I added the log statement explicitly stating that this is wrong and what to do.
Then a sleep 1000 seconds after that to give the user the opportunity to fix it.
Sat Nov 23, 2019 2:36 am
Rjay offline
thanks mate.
Yep still a learning path structures in MacOS so didn't make much sense to me initially. All good looks to be going now :)
I am hoping this is the cause of the lag I have been seeing post Catalina upgrade.
thanks again
