iRoomba iRobot Plugin
GlennNZ
Re: iRoomba iRobot Plugin
Post by GlennNZ »
Hi
Sorry to hear has had slight hiccup.
The limited instructions needed to install paho-mqtt are in the first post in this thread. If you haven’t installed it you should see a big error message.
Check the first post and run the terminal command to install paho-mqtt.
Questions
1. Are you getting any logging/messaging from the plugin?? From Indigos event log. That is where any errors etc should be displayed.
2. May need to turn debug logging on within the plugin config settings to see other messages.
Finally if still issues please feel free to PM me the debug log file as will be quickest way to seeing what is going on.
Glenn
Mark
Post by Mark »
Glenn, thank you so much for such a quick reply.
The plug-in is writing to the log. It's definitely indicating the library is missing:
   iRobot-Roomba Error             Need to install module Mqtt for this plugin to work.  See Forum.
I ran the Terminal code as instructed. I get a missing file error, which is expected since I didn't provide any sort of file for it to install. That's what I'm missing, where to find the mqtt file.
I just tried it again, using Terminal and this command:
<sudo> pip install paho-mqtt
I get this, from Terminal:
-bash: sudo: No such file or directory
I didn't point Terminal at any particular directory. Would paho-mqtt be included on a Mac standard OS install, or do I need to download it from somewhere?
GlennNZ
Post by GlennNZ »
Just type: (no brackets)
sudo pip install paho-mqtt
Mark
Post by Mark »
Shows ya how much I know about Terminal! :lol: Stand by, I'll give it a go...
Mark
Post by Mark »
Now I get this from Terminal:
sudo: pip: command not found
Am I missing any punctuation in the sudo command. This is what I tried:
GlennNZ
Post by GlennNZ »
Ok
Your python is missing the pip command install
There are a few posts here about how to fix/install.
Could try
sudo easy_install pip
Then the one last post, to install paho-mqtt
https://stackoverflow.com/questions/172 ... os-or-os-x
Mark
Post by Mark »
Now this:
Back:~ mark$ sudo easy_install pip
Password:
Searching for pip
Reading https://pypi.python.org/simple/pip/
Couldn't find index page for 'pip' (maybe misspelled?)
Scanning index of all packages (this may take a while)
No local packages or download links found for pip
error: Could not find suitable distribution for Requirement.parse('pip')
GlennNZ
Post by GlennNZ »
Hi
Could try
sudo easy_install paho-mqtt
But check the linked post as well as I’m running out of ‘live’ time.
Glenn
Mark
Post by Mark »
Nope:
Back:~ mark$ sudo easy_install paho-mqtt
Password:
Searching for paho-mqtt
Reading https://pypi.python.org/simple/paho-mqtt/
Couldn't find index page for 'paho-mqtt' (maybe misspelled?)
No local packages or download links found for paho-mqtt
error: Could not find suitable distribution for Requirement.parse('paho-mqtt')
I've made a mess now. I think I got a pip installed, but it is not compatible with Python 2.7 (I have 2.7.16). Apparently 2.7.18 will work? Uhg. Now I think I have to try to uninstall what I did, and then try to upgrade Python? I know just enough to end up tanking my OS... Or at least my Python... :(
Thanks for you help so far...
GlennNZ
Post by GlennNZ »
Mark wrote:Nope:
Password:
Don’t fiddle with you default python install - it will cause major issues for indigo.
Hopefully someone else can take over as need to go offline
But check this forum, for pip install there are a few posts about how to solve.
How to install python modules in Indigo 7
https://r.tapatalk.com/shareLink/topic? ... source=app
Mark
Post by Mark »
OK, got a pip to install and then your original Terminal instructions worked, ending in:
Successfully installed paho-mqtt-1.5.1
Holding breath while I restart everything...
Mark
Post by Mark »
Before I do, this is what worked on Mac Mojave:
sudo curl -O https://bootstrap.pypa.io/pip/2.7/get-pip.py
and then:
sudo python2.7 get-pip.py
and then:
GlennNZ
Post by GlennNZ »
Well done, you can use terminal after all!
Mark
Post by Mark »
Ta da!
Looks like the plug-in loaded with no issues. No errors in log.
All Custom States are filled in now, except: SqFT, X and Y (perhaps because my Roomba is parked in the charger?).
I'll give it a good test and see what happens...
Thanks again for pointing me in the right direction.
Mark
Post by Mark »
Use Terminal? Well, I can copy and paste! If it wasn't for stackoverflow.com none of my stuff would work!! :lol:
Return to “iRoomba iRobot Plugin”
