Yes, you'll see that sometimes. I didn't make it a plugin error because there's generally nothing you can do about it. It's just letting you know that one of the data sources it's getting from NOAA is corrupted and can't be read. In this case, it's the list of all NOAA weather stations which the NOAA Weather Plus plugin uses to find a secondary data source, in the event that the primary weather data source fails for some reason.Dewster35 wrote:Getting this. It's not red as an error in my event log, but it doesn't look like it is doing something properly?
Aug 8, 2013 8:08:59 AM
NOAA Weather Plus Plugin Unknown error getting weather station list.
NOAA Weather Plus Plugin Warning: Error parsing weather station list XML from NOAA: no element found: line 1, column 0
It looks like the weather station list from NOAA is empty, or there's some weird network issue going on. You could try reloading the NOAA Weather Plus plugin, but if NOAA is giving bad data, it won't fix that particular problem.
