Help converting a simple applescript to Python
Forum rules
matt (support)
Re: Help converting a simple applescript to Python
Post by matt (support) »
That error shows that you have modified the script from what you originally posted.
Please try compiling the original script above again, then copy/paste any errors you see in the Event Log. Let's not change things while we are trying to troubleshoot -- it just makes everything more complicated for us.
And also copy/paste yet again *exactly* what you are compiling.
bob
Post by bob »
Matt,
Compiling this code from the previous post:
#set coffee timestamp
import datetime
applianceLinc = indigo.devices["coffee"]
if applianceLinc.onState:
    indigo.variable.updateValue(862715057, str(datetime.datetime.now()))
Gives this in the log;
2012-03-27 9:18:59 AM
Script Error embedded script: invalid syntax
Script Error around line 6 - "indigo.variable.updateValue(862715057, str(datetime.datetime.now()))"
matt (support)
Does this compile:
    indigo.variable.updateValue(862715057, "hello")
And what version of OS X are you running?
bob
Post by bob »
Matt,
No it doesn't compile.
Script Error around line 3 - "indigo.variable.updateValue(862715057, "hello")"
OS X 10.7.2/Python 2.5.6/Indigo 5.0.4
matt (support)
How about just this single line script:
bob
Post by bob »
No joy, same error; invalid syntax. :?
matt (support)
Try:
foo = "hello"
bar = "bye"
And then:
foo = "hello"
bar = "bye"
indigo.server.log(foo)
And finally:
foo = "hello"
bar = "bye"
indigo.variable.updateValue(862715057, foo)
indigo.variable.updateValue(862715057, bar)
Copy/paste the Event Log error results from all three.
bob
Post by bob »
Matt,
Won't compile even the first one;
script Error embedded script: invalid syntax
Script Error around line 1 - "foo = "hello""
matt (support)
Try:
foo = 5
indigo.server.log(str(foo))
bob
Post by bob »
Matt,
I'm at home on a different computer with the same versions of Indigo. This code:
gives this error now;
Error script error: around characters 16 to 23
Error script error: A unknown token can’t go after this identifier. (-2740)
this code;
foo = "hello"
bar = "bye"
giver error:
Error script error: around characters 32 to 33
Error script error: Expected end of line, etc. but found unknown token. (-2741)
The last code you sent;
foo = 5
gives this error:
Error script error: around characters 14 to 15
matt (support)
Those are all AppleScript errors, which means you don't have python selected from the popup in the UI.
Also, make sure you have at least a space character indent on this line:
since Python requires it.
bob
Post by bob »
Matt,
OK, now it compiles with no errors in the log but it won't write the variable. I copied & pasted the new variable ID into the code so it is correct and the variable exists.
import datetime
 indigo.variable.updateValue(717445627, str(datetime.datetime.now()))
jay (support)
Post by jay (support) »
You still have a problem - the line after the "if" line needs to be indented by at least one space. Blocks in Python are delineated by indentation.
import datetime
4 spaces is generally considered standard form for Python.
matt (support)
It would be most helpful if you could explain what it is you changed to get it compiling -- it wasn't just the change from AppleScript to Python because your other posts on this forum thread are showing python errors, I believe. We've spent some time with you troubleshooting this and it would be good to know for other customers that might run across the same problem.
bob
Post by bob »
Matt,
I truly appreciate all your help.
I didn't change anything to get it to compile, I have no idea why it is compiling. I just switched to a different computer (old mac pro) when I got home from work (new AirBook). Same OS X version, same Indigo version. Even though it compiles on this computer it won't write to the variable.
The line after the "if" is indented.
I tried changing to a new variable/ID but it still won't write and I don't get errors in the log.
I have no idea what to do.
Locked
Return to “Extending Indigo with Plugins and Python”
