Question on running Shortcuts via Indigo
Share your macOS, iOS, and iPadOS shortcuts here. Post your shortcut in a new topic and be sure to describe thoroughly (screenshots, full text of any scripts, apps used, etc).
norcoscia
Re: Question on running Shortcuts via Indigo
Post by norcoscia »
Just FYI, in case anyone else runs into this - using direct IP fixed this - I assume the Soro app must maintain some type of network map for Sonos devices, then it is flushed every day - then on a new call the map is remade, I’m thinking the command line call might time out waiting for the new map to build (I noticed on my Indigo that process takes ~5 seconds(you can manually order it). I’m just guessing but I cannot think of anything else that would explain the crazy behavior. If I have any more problems I’ll post. Thanks for the help and suggestions from everyone….
_______
Norm
Return to “Apple Shortcuts”
