fixed G.timezones in line 1288, piBeaconUtils. in next release,
the stopBLE not found can be ignored. It is not an error, it is exists it is a msg from other processes, ==> will suppress msg
so do you still get
05-17:09:48 beaconloop execbeaconloop L:982 Lv:50 in Line 973 has error=timed out.. sock.recv error, likely time out ?
@GlennNZ:
published new version .346 with fixes for timezone, NTP install and removed the stopBLE msg
GlennNZ
Post by GlennNZ »
kw123 wrote:@GlennNZ:
Thanks Karl! Thats fixed those..
Working my way through a few other bits and pieces,
the INPUT-ADC-4x12/16bit-one-channel-i2c-ADS1x15 device
Have a few that has now updated (see it has had considerable code changes)
Seems a few issues:
- status: from device always blank
- state: always 0
- INPUT_raw: 255.99 - always??
Even for different devices on different rpis?
Below is logging from rpis with everything line with 255.99 - as can see across multiple (well I have three) sensors connected to two different rpis, and quite different devices always give the same answer...
2020-04-06 17:11:13 sensor input  pi: 5; data {u'ADS1x15': {u'1036561108': {u'INPUT': 255.99}, u'752082303': {u'INPUT': 255.99}}}
2020-04-06 17:11:13 updateINPUT: piBeacon Level Sensor 185 rpi;  sensor: ADS1x15;  upState: INPUT_0; inputState: INPUT;  data: {u'INPUT': 255.99}
2020-04-06 17:11:13 updateINPUT: Pibeacon - test watertank;  sensor: ADS1x15;  upState: INPUT_0; inputState: INPUT;  data: {u'INPUT': 255.99}
2020-04-06 17:11:13 pi# 5  1036561108  {u'187287881': {u'last_MessageFromRpi': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': '2020-04-06 17:11:13'}}, u'752082303': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'255.99'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}, u'1036561108': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'-38.003329533'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}}
2020-04-06 17:11:13 pi# 5  752082303  {u'187287881': {u'last_MessageFromRpi': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': '2020-04-06 17:11:13'}}, u'752082303': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'255.99'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}}
2020-04-06 17:11:40 sensor input  pi: 2; data {u'ADS1x15': {u'1874635667': {u'INPUT': 255.99}, u'1980283685': {u'INPUT': 255.99}}}
2020-04-06 17:11:40 updateINPUT: Pibeacon Pool pH copy;  sensor: ADS1x15;  upState: INPUT_1; inputState: INPUT;  data: {u'INPUT': 255.99}
2020-04-06 17:11:40 updateINPUT: Pibeacon Pool ORP;  sensor: ADS1x15;  upState: INPUT_0; inputState: INPUT;  data: {u'INPUT': 255.99}
2020-04-06 17:11:40 pi# 2  1874635667  {u'1874635667': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'3.2944625'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}, u'1980283685': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'2.16322564'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}, u'1991519083': {u'last_MessageFromRpi': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': '2020-04-06 17:11:40'}}}
2020-04-06 17:11:40 pi# 2  1980283685  {u'1980283685': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'2.16322564'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}, u'1991519083': {u'last_MessageFromRpi': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': '2020-04-06 17:11:40'}}}
2020-04-06 17:12:15 sensor input  pi: 5; data {u'ADS1x15': {u'1036561108': {u'INPUT': 255.99}, u'752082303': {u'INPUT': 255.99}}}
2020-04-06 17:12:15 updateINPUT: piBeacon Level Sensor 185 rpi;  sensor: ADS1x15;  upState: INPUT_0; inputState: INPUT;  data: {u'INPUT': 255.99}
2020-04-06 17:12:15 updateINPUT: Pibeacon - test watertank;  sensor: ADS1x15;  upState: INPUT_0; inputState: INPUT;  data: {u'INPUT': 255.99}
2020-04-06 17:12:15 pi# 5  1036561108  {u'187287881': {u'last_MessageFromRpi': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': '2020-04-06 17:12:15'}}, u'752082303': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'255.99'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}, u'1036561108': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'-38.003329533'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}}
2020-04-06 17:12:15 pi# 5  752082303  {u'187287881': {u'last_MessageFromRpi': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': '2020-04-06 17:12:15'}}, u'752082303': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'255.99'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}}
2020-04-06 17:14:43 pi# 2  1874635667  {u'1874635667': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'3.2944625'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}, u'1980283685': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'2.16322564'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}, u'1991519083': {u'last_MessageFromRpi': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': '2020-04-06 17:14:43'}}}
2020-04-06 17:14:43 pi# 2  1980283685  {u'1980283685': {u'INPUT': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': u'2.16322564'}, u'INPUT_raw': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': 255.99}}, u'1991519083': {u'last_MessageFromRpi': {'decimalPlaces': '', 'force': False, 'uiValue': '', 'value': '2020-04-06 17:14:43'}}}
rpi 5
pi@raspberrypi:~/pibeacon/temp $ tail ADS1x15.dat
  "1874635667": {
    "INPUT": 255.99
  "1980283685": {
    "INPUT": 255.99
& this is rpi2
  "1036561108": {
    "INPUT": 255.99
  "752082303": {
    "INPUT": 255.99
}pi@raspberrypi:~/pibeacon/temp $
mine works fine.
Could you share the setup
1. which hardware?
2. parameters for section:
  "sensors": {
    "ADS1x15": {
      "188809276": {
        "gain": "6144",
        "i2cAddress": "72",   < -- this is decimal == 48 hex
        "input": "0",
        "logScale": "0",
        "minSendDelta": "4",
        "offset": "0",
        "resModel": "16",
        "sendToIndigoEvery": "60",
        "sensorRefreshSecs": "2",
        "useMuxChannel": "-1"
i2cdetect -y 1
 i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- 48 -- -- -- 4c -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@raspberrypi:~/pibeacon $
.. my config
With some of the hardware boards you need to be careful with ground. It is connected to the RPi ground make sure that your sensor connected to the board is floating.
Also if you could disconnect input from the ADC converter and just touch the input with your fingers, you should see some changes in value.
And do you have other inputs ie i2c conflicts?
AND THESE ADC are sensitive to over voltage > VDD = 3.3V !! they die
GlennNZ
Post by GlennNZ »
kw123 wrote: Could you share the setup
1. which hardware?
.. my config
Hi Karl,
Thousand apology's for the delay - I know how annoying it is to troubleshoot over gap of days. Few things going on in world/work and all!
These devices I haven't touched/rewired or looked at for a few years. They were working with the previous device definition - but updated then as you depreciated it.
Seems strange to me that both reading the same amount following this update.
rpi-2
pi@raspberrypi:~ $ i2cdetect -y 1
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- 48 49 -- -- -- -- -- --
pi@raspberrypi:~ $
Sorry - which file is the Sensors data in?
pi@raspberrypi:~/pibeacon/temp $ tail alive.ADS1x15
1586476061.47
  "1874635667": {
    "INPUT": 255.99
  "1980283685": {
    "INPUT": 255.99
}pi@raspberrypi:~/pibeacon/temp $ tail parameters
    "eth0": {
      "on": "off",
      "useIP": "doNotUse"
    "wlan0": {
      "on": "on",
      "useIP": "use"
}pi@raspberrypi:~/pibeacon/temp $ cd ..
pi@raspberrypi:~/pibeacon $ ls
 actions.py                  displayDistance.py                installLibs2.py            mpu9255.py                                     rc.local                  stepperc.py
 ADS1x15.py                  displayfiles                      installLibs.done           myBLEmac                                       rc.local.default          stepperDR.py
 amg88xx.py                  display.inp                       installLibs.py             myprogram.py                                   rd200radon.py             stepper.py
 apds9960.py                 display.py                        interface.py               neopixelClock.py                               receiveCommands.py        temp
 as3935.py                   doGPIOatStartup.py                interfaces                 neopixel.inp                                   renameMeTo_myoutput.py    testLED.py
 as726x.py                   doNotIgnore                       interfaces-adhoc           neopixel.py                                    renameMeTo_myprogram.py   tmp006.py
 autostart.forxwindows       execcommands.current              interfaces-DEFAULT         nohup.out                                      renameMeTo_mysensors.py   tmp007.py
 batteryLevelPosition        execcommands.py                   interfaces-DEFAULT-clock   offsetUUID                                     rgbmatrix.so              touchFile
 beacon_ExistingHistory      fastDown                          interfaces-DEFAULT-wifi    onlyTheseMAC                                   _rpi_ws281x.so            ultrasoundDistance.py
 beaconloop.py               fonts                             interfaces-old             OUTPUTgpio.py                                  rsyslog                   upsV2.py
 beacon_parameters           getBeaconParameters.py            ipAddress                 '<PageElemList type="vector"> 3.textClipping'   setGPIO.py                UUIDtoIphone
'beacon_parameters copy'     h1106.py                          l3g4200.py                 parameters                                     setmcp4725.py             vcnl4010Distance.py
'beacon_parameters copy 2'   hmc5883L.py                       launchpgm.py               parameters-DEFAULT-clock                       setPCF8591dac.py          vl503l0xDistance.py
 BLEconnect.py               hwclock.set.nohwclock             lidar360.py                parameters.startup                             setStepperMotor.py        vl53l0x_python.so
 BLEsensor.py                ignoreMAC                         lsm303.py                  patterns                                       setTEA5767.py             vl6180xDistance.py
 bme680.py                   ignoreUUID                        mag3110.py                 patterns-DEFAULT                               sgp30.py                  webserverINPUT.py
 bno055.py                   images                            master.py                  patterns-DEFAULT-clock                         si7021.py                 webserverSTATUS.py
 callbeacon.py               ina219.py                         master.sh                  PCF8591.py                                     signalDelta               wifiInfo.json
 ccs811.py                   ina3221.py                        masterStartAfterboot       permanent.log                                  simplei2csensors.py       Wire18B20.py
 checkForInclude-py2.py      INPUTgpio.count                   max31865.py                piBeaconGlobals.py                             smbus2.py                 wpa_supplicant.conf
 checkForInclude-py3.py      INPUTgpio.py                      mhzCO2.py                  piBeaconGlobals.pyc                            smbus2.pyc                wpa_supplicant.conf-DEFAULT
 checkVoltage.py             INPUTpulse.count                  mlx90614.py                piBeaconUtils.py                               soundfiles                wpa_supplicant.conf-DEFAULT-clock
 convert.py                  INPUTpulse.py                     mlx90640.py                piBeaconUtils.pyc                              spiMCP3008.py             wpa_supplicant.conf-old
 copyToTemp.py               INPUTRotarySwitchAbsolute.py      moist.py                   playsound.py                                   startmaster.sh            wpa_supplicant.conf-temp
 dhclient.conf-fast          INPUTRotarySwitchIncremental.py   moistureSensor.py          pmairquality.py                                stepper2H.py
 DHT.py                      INPUTtouch.py                     mpu6050.py                 rainSensorRG11.py                              stepper2.py
I had the same problem with a broken chip. The value was constant 512
Also normally the i2c channels are 2 apart ( not 48 and 49) ... what other sensor do you have attached?
and for the parameter file do a
cat
not a
tail
need to see the section:
"sensors": {
"ADS1x15": {
in the parameters file
and the directory listing needs the date stamp:
ls -l
... just saw, you are NOT using the old device def?
In Indigo you need to delete and recreate with the new device type
ps.. and / or show the device edit screen shot
GlennNZ
Post by GlennNZ »
Thanks Karl
Using new device definition - didn't delete and recreate - but done so now and same 255.99 result for x2 devices, across x2 rpi's
  "sensors": {
    "ADS1x15": {
      "1874635667": {
        "format": "%1.2f",
        "gain": "256",
        "i2cAddress": "73",
        "input": "0",
        "logScale": "0",
        "offset": "685.285",
        "resModel": "16",
        "sensorRefreshSecs": "1",
      "1980283685": {
        "format": "%1.2f",
        "gain": "256",
        "i2cAddress": "73",
        "input": "0",
        "logScale": "0",
        "offset": "-2500",
        "resModel": "16",
    "INPUTgpio-1": {
      "108500439": {
        "INPUTS": [
            "count": "off",
            "gpio": "26",
            "inpType": "high"
        "gpio": "26",
        "inpType": "high",
        "lowHighAs": "0",
        "offset": "0"
      "1354564053": {
        "INPUTS": [
            "count": "off",
            "gpio": "20",
            "inpType": "high"
        "gpio": "20",
        "inpType": "high",
        "lowHighAs": "1",
        "offset": "0"
      "1655035980": {
        "INPUTS": [
            "count": "off",
            "gpio": "16",
            "inpType": "high"
        "gpio": "16",
        "inpType": "high",
        "lowHighAs": "0",
        "offset": "0"
      "1992126480": {
        "INPUTS": [
            "count": "off",
            "gpio": "19",
            "inpType": "high"
        "gpio": "19",
        "inpType": "high",
        "lowHighAs": "0",
        "offset": "0"
    "i2cTMP102": {
      "1737976775": {
        "displayEnable": "1",
        "i2cAddress": "72",
        "offsetTemp": "0",
Image of new device definition :
Adding rest..
gain = 16 for both (param= 256 == 16x) maxes out at 0.256 volt = 255.99 bits (rounding effect)
try gain = 1 ( param = 4096) and see what happens
the device edit section for that parameter:
			<Field id="gain" type="menu"     defaultValue="4096"> <Label>Gain:</Label>
			<List>
				<Option value="6144"   >2/3 Gain : max=6.144V, 3mV/bit     res only if V+ 6V.xV </Option>
				<Option value="4096"   >1   Gain : max=4.096V, 2mV/bit     res default, goes to max 3.29V if V+=3.3V used</Option>
				<Option value="2048"   >2   Gain : max=2.048V, 1mV/bit     res</Option>
				<Option value="1024"   >4   Gain : max=1.024V, 0.5mV/bit   res</Option>
				<Option value="512"    >8   Gain : max=0.512V, 0.25mV/bit  res</Option>
				<Option value="256"    >16  Gain : max=0.256V, 0.125mV/bit res</Option>
			</List>
			</Field>
GlennNZ
Post by GlennNZ »
Yah!
Thanks - thats it - at least they now all give different readings...
Has there been a change in how this affects the raw input, I am still testing but warying of time difference so posting now
These images are the old device definitions - where for WaterTank-Level sensor with these settings would expect a value of 800-900 with the gain set as below
(new definition ?same gain maxs out at 299?)
I need to check. But the gain settings should be the same . May be the old was wrong. The new one is correct.
What are the actual voltages 800-900 mV?
Then yes the high gain will always result in max / overflow.
Karl.
GlennNZ
Post by GlennNZ »
Yes voltages given with old device and x16 gain 858, 1049, & 1051 (from looking a old, production computer settings)
Just presumed more gain, better resolution when I was creating
New devices maxing out at 255.99 - explains the across device issues I was seeing.
Trouble is had created a graph of various readings for sensor, matched to watertank pressure levels which gave me cm of water in tank.
Will have to check whether same rules apply now with a different gain.
Glenn
You can use offset and mult 1 2 to get the same values as before
GlennNZ
Post by GlennNZ »
Thanks Karl
Unfortunately used offset/multiple (as you'll see in device definitions) to covert the mV to CMS and unfortunately don't have the mV graph data that I collected at multiple water levels anymore.
Glenn
here the resolution:
this was the old code:
			if sensors[sensor][devId]["gain"] != "" :
				g=sensors[sensor][devId]["gain"]
			if g>6144: g=6144
			if g<256:  g=256
			if g%2!=0: g=6144
in principle correct but gain was "256" , not 256.
and "256" > 6144 == True ( also "6144" > 6144 ==True)
hence g= 6144 ALWAYS
So your setting was: 2/3 Gain : max=6.144V, 3mV/bit
if you use that setting it should behave like before.
So no matter what you picked it was always gain 2/3 => 3mV / bit; 0..... 6.144V
Measuring 3mV /bit accuracy in a stable way over a longer wire is actually not trivial. So you actually did not loose a lot of accuracy.
>>> IF<<< the voltage is 800.900 mV you could set the gain to 4 and change the multiplier from 1 to 0.25 and offset to oldOffset *4 , that SHOULD work.
value = ( raw + offset )* mult
GlennNZ
Post by GlennNZ »
Perfect thanks!
Enjoy your Easter!
Return to “piBeacon”
