[ANSWERED]: Indigo Touch 2.0.5
Thu Apr 30, 2015 10:50 pm
zurich offline
Greetings - I use X10 motion sensors. Under Devices in Indigo Touch they are all listed in red and as '-interface disabled-'. They all werk fine and have Comm and Remote Display enabled. Can you tell me why they are all listed in red and as 'interface disabled'.
thanks to you,
Z
Fri May 01, 2015 8:25 am
Re: Indigo Touch 2.0.5
At the bottom left of the screen, next to the activity bar that shows green/purple blobs of activity being sent/received, it should show a list of which interfaces you have enabled.
Does X10 appear there?
If not, go to the menu > interfaces > X10/Powerline and enable the interface.
If it's already there but red with strikethrough, your interface (CM15?) isn't being detected by Indigo.
Fri May 01, 2015 9:42 am
zurich offline
The W800RF32 is listed as an enabled interface in Indigo so it is being detected by Indigo. If the W800RF32 had a red line through it my motion sensors vouldn't be working. It is only on my iPad with Indigo Touch 2.0.5 under DEVICES that my X10 motion sensors have the label in red and underneath the label it says -interface disabled- also in red.
thanks to you,
Zurich
Fri May 01, 2015 9:18 pm
Sounds like a buglet. We'll look into it.
Sat Jul 18, 2015 8:13 am
captcurrent offline
Re: [ANSWERED]: Indigo Touch 2.0.5
Just thought I would throw w me too
6.1.2 indico server running on os 10.10 Touch on IOS 8.4
Sat Nov 19, 2016 1:44 pm
captcurrent offline
bump. I have still have this situation with indigo 6.1.1 -current Verizon of touch
Fri Dec 23, 2016 11:32 am
Still on the list to look into. Duplicate posts won't make it happen any sooner.
Fri Dec 23, 2016 12:09 pm
captcurrent offline
I am sorry about duplicate but the last chain said "answered" which I assuemd was same as solved
Fri Dec 23, 2016 1:02 pm
We hope to have this fixed in Indigo 7.0.3. Luckily, it is something that I believe can be fixed in Indigo Server (versus Indigo Touch which we will be working on in the nearish future).
Fri Dec 23, 2016 1:39 pm
captcurrent offline
Great news.
Fri Dec 23, 2016 1:54 pm
We use SOLVED and ANSWERED somewhat interchangeably, but SOLVED should mean it's fixed and ANSWERED may not mean there's a fix yet but that we've answered the OP question.
Thu Jan 26, 2017 1:45 pm
Indigo v7.0.3 is now available and fixes the UI display bug that causes Indigo Touch to display "interface disabled" for X10 RF modules when using a W800RF32 or MR26.
