Set variable from command line
Wed Jul 01, 2015 10:33 am
Peter Beyt offline
I hope this finds everyone healthy and happy!
Please, can anyone tell me if there is a cleaner way to do this? ---------
From a remote machine using ssh I call to execute one of two Applescripts like this one:
#!/usr/bin/osascript
tell application "IndigoServer" to set value of variable "database_busy" to false
************* IS THERE A BETTER WAY ?????????????
The operation must be call and exit on the remote machine…..
Any ideas you lovely smart people?
thanks peter
PEACE
Wed Jul 01, 2015 1:28 pm
Peter Beyt offline
Re: Set variable from command line
Will this be more reliable than the above?
/Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost -e indigo.variable.updateValue\(1730190951,\ value=unicode\(\"lock\"\)\)
Thu Jul 02, 2015 9:03 am
Either of those are fine. You could also use the Indigo RESTful API with curl...
Thu Jul 02, 2015 11:39 am
Peter Beyt offline
Thanks Jay,
Could you give me the equivalent RESTful API with curl. call?
I never realized how challenging it can be to get a command line to pass through
all the right channels, Script>SSH>Script>Indigo.
But first, I'm really interested in the most reliable way of doing it!
If I could do this all over eppc:// machine calls, it would be easy, but they hang and
with eight computers working like gears in a clock, one locks, they all lock!
Least interpretation and compiling is what I'm after.
Because I'm sending this command from another computers SSH script and
my execution time is mission critical, I sometimes get hung by the #!/usr/bin/osascript interpreter.
Maybe the real question is how to pass variables between IndigoServers,
I'm building a TV station, there is a lot going on between machines……
peter
PEACE
Thu Jul 02, 2015 12:18 pm
RogueProeliator offline
For real-time performance between two actual servers, your absolute best bet might be a plugin that keeps a communication channel between the two up at all times...
Adam
Thu Jul 02, 2015 1:12 pm
Peter Beyt offline
Thanks Adam,
You are right! But I'm a bit overwhelmed with the software
I need to get up and running, I'll need to put it on a wish list!
I grew up in Lafayette, mom tells me it's raining everyday right now!
But, I digress. Because, at the moment, this variable is only to stop
IndigoServers from accessing the same files at the same time,
I'm hoping to do it cheaply (without a big time investment).
It's easy to see what a real pipe between servers could do.
In this high level software world, you ask a machine to do something
and 90% it does on time! But your viewers don't like seeing 10%
of on air mistakes and you don't want to have to give back 10%
of your billings! I'm just saying if I ever get that far!
THANKS
PEACE
peter
Thu Jul 02, 2015 4:45 pm
Hi Peter,
I'd definitely avoid remote eppc:// calls, and probably avoid AppleScript/osascript. AppleScript just isn't my endorsed solution for reliability these days.
Using IndigoPluginHost -e should be reliable, but the problem is it has to spin up a new process and connect to the Indigo Server each time. The Indigo Server overhead on that is pretty minimal, but there still might be some delay as the process has to start up. If it seems too slow then using curl in a shell script to the RESTful API will likely be faster, as it will be accessing Indigo's always-running web server. Here is an example:
 curl -u username:password --anyauth -X PUT -d value=false http://127.0.0.1:8176/variables/database_busy
Thu Jul 02, 2015 5:41 pm
Peter Beyt offline
Now that's what I'm talking about…..
THANKS
