Artanis wrote:Wow, thanks for that Matt! I'll keep an eye out for the update.
Jay, (and apologies if any of my terminology is wrong)
A couple of years ago I bought an Australian Insteon hub and was able to modify it with some (unofficial) support from an Insteon tech. Inside the hub there was two cards - the powerline/rf card and the network interface card. I removed the network interface card and replaced it with a usb interface board from a US purchased PowerLinc Modem (#2413U) (A friend and I worked on it together to make sure we were following the provided wiring instructions correctly).
Indigo picked it up as a PowerLinc modem and its been smooth sailing since then. I've been able to connect every Insteon device I've bought so far - a mini remote, thermostat, motion sensor, plug in relay, micro dimmer, micro motor controller and the bayonet style globe I mentioned in my previous post. I've just picked up a micro relay which I'll try out on the weekend.
Thanks again for your support
