Mar 29, 2015, 2:53:38 PM
Z-Wave Syncing - started for device "(Motion) Living Room"
Z-Wave Syncing - retrieved module neighbors list: 1, 6, 7
Z-Wave Syncing - requesting neighbor list update of "011 - (Motion) Living Room"
Z-Wave Syncing - neighbor list update complete (no change)
Z-Wave Syncing - assigning return route to "011 - (Motion) Living Room"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Multi Sensor (DSB05) - 00020005
Z-Wave Syncing - retrieved protocol version 3.28, app version 1.18
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01, base 30)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 31v5 72v1
Z-Wave Syncing - retrieved wake interval of 240 minutes
Z-Wave Syncing - device "011 - (Motion) Living Room" wake interval changed to 240 minutes
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - retrieved Wake for 10 minutes after battery change is true
Z-Wave Syncing - retrieved Enable motion sensor is true
Z-Wave Syncing - retrieved parameter 3 "Delay after no motion before OFF sent" is 60 seconds
Z-Wave Syncing - retrieved parameter 5 "Motion sensor command sent flags" is 1
Z-Wave Syncing - retrieved parameter 101 "Group 1 report sent flags" is 224
Z-Wave Syncing - retrieved parameter 102 "Group 2 report sent flags" is 0
Z-Wave Syncing - retrieved parameter 103 "Group 3 report sent flags" is 0
Z-Wave Syncing - module returned parameter 103 instead of parameter 111 "Delay between reporting sensors values" (skipping)
Z-Wave Syncing - retrieved parameter 111 "Delay between reporting sensors values" is 300 seconds
Z-Wave Syncing - retrieved parameter 112 "Delay between reporting for group 2 (unused)" is 720 seconds
Z-Wave Syncing - retrieved parameter 113 "Delay between reporting for group 3 (unused)" is 720 seconds
Z-Wave received "(Motion) Living Room" status update is on
Z-Wave Error Timeout waiting for "011 - (Motion) Living Room". Module might be asleep, or is unreachable.
Z-Wave Indigo Device "(Motion) Living Room" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.281
Node ID: 11
Model: Multi Sensor (DSB05)
Model ID: 00020005
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.28
Application Version: 1.18
Model Definition Version: 4
Library Type: 6
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 80v1 84v2 85v1 86v1 70v1 30v1 31v5 72v1
Features: routing, battery, beaming, waking
Neighbors: 1, 6, 7
Associations: 1:[1]
Config Values: 112:720 113:720 2:1 3:60 4:1 5:1 102:0 103:0 111:300 101:224
Mar 29, 2015, 2:50:28 PM
Z-Wave received "(Motion) Living Room" status update is off
Z-Wave received "(Lux) Downstairs" sensor update to 258 lux
Z-Wave received "(Humidity) Downstairs" sensor update to 45%
Z-Wave received "(Temp) Downstairs" sensor update to 73.6 °F
Z-Wave received "(Lux) Living Room" sensor update to 86 lux
Z-Wave received "(Lux) Living Room" units changed to lux
Z-Wave Error rcvd incomplete interface requestConfigVal packet (parm index 113, size 4): 01 0C 00 04 00 0B 06 70 06 71 04 00 00 F9 (expected 16 bytes)
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Z-Wave sent "(Motion) Living Room" status request
Z-Wave received "011 - (Motion) Living Room" status update battery level 100%
Z-Wave received "(Lux) Living Room" sensor update to 88 lux
Z-Wave received "(Humidity) Living Room" sensor update to 38%
Z-Wave received "(Humidity) Living Room" units changed to %
Z-Wave received "(Temp) Living Room" sensor update to 78.1 °F
Z-Wave received "(Temp) Living Room" units changed to °F
edrabbit wrote:However I have only received one or two readings from the other onboard sensors (Lux/Humidity/Temp).
FWIW, when I open the device in Indigo it says it's a "Multi Sensor (DSB05)" but now I don't see the extra settings in the dialog.
wideglidejrp wrote:I have the multi sensor installed on my z-wave network with Indigo. Works fine except the Lux is always 1,000 even in the wee hours of pitch blackness. The temp and humidity readings work fine. How can I find what level of firmware my multisensor has?
May 30, 2015, 11:08:25 AM
Z-Wave Indigo Device "(Motion) Downstairs" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.350
Node ID: 10
Model ID: 00020005
Library Type: 6
Neighbors: 1, 6, 7
Associations: 1:[1]
Config Values: 2:1 3:60 4:1 5:1 101:224 102:0 103:0 111:300 112:720 113:720
./indigo_log.txt:2015-05-30 09:49:08.343 Z-Wave received "(Lux) Downstairs" sensor update to 96 lux
./indigo_log.txt:2015-05-30 09:49:08.379 Z-Wave received "(Humidity) Downstairs" sensor update to 45%
./indigo_log.txt:2015-05-30 09:49:08.398 Z-Wave received "(Temp) Downstairs" sensor update to 71.1 °F
./indigo_log.txt:2015-05-30 09:57:08.317 Z-Wave received "(Lux) Downstairs" sensor update to 103 lux
./indigo_log.txt:2015-05-30 09:57:08.319 Z-Wave received "(Humidity) Downstairs" sensor update to 45%
./indigo_log.txt:2015-05-30 09:57:08.352 Z-Wave received "(Temp) Downstairs" sensor update to 70.8 °F
./indigo_log.txt:2015-05-30 10:05:08.264 Z-Wave received "(Lux) Downstairs" sensor update to 109 lux
./indigo_log.txt:2015-05-30 10:05:08.282 Z-Wave received "(Humidity) Downstairs" sensor update to 45%
./indigo_log.txt:2015-05-30 10:05:08.320 Z-Wave received "(Temp) Downstairs" sensor update to 70.8 °F
./indigo_log.txt:2015-05-30 10:13:08.201 Z-Wave received "(Lux) Downstairs" sensor update to 130 lux
./indigo_log.txt:2015-05-30 10:13:08.238 Z-Wave received "(Humidity) Downstairs" sensor update to 45%
./indigo_log.txt:2015-05-30 10:13:08.275 Z-Wave received "(Temp) Downstairs" sensor update to 70.6 °F
./indigo_log.txt:2015-05-30 10:21:10.188 Z-Wave received "(Lux) Downstairs" sensor update to 133 lux
./indigo_log.txt:2015-05-30 10:21:10.190 Z-Wave received "(Humidity) Downstairs" sensor update to 45%
./indigo_log.txt:2015-05-30 10:21:10.224 Z-Wave received "(Temp) Downstairs" sensor update to 71.0 °F
./indigo_log.txt:2015-05-30 10:29:10.146 Z-Wave received "(Lux) Downstairs" sensor update to 147 lux
./indigo_log.txt:2015-05-30 10:29:10.148 Z-Wave received "(Humidity) Downstairs" sensor update to 46%
./indigo_log.txt:2015-05-30 10:29:10.183 Z-Wave received "(Temp) Downstairs" sensor update to 70.7 °F
./indigo_log.txt:2015-05-30 10:37:10.082 Z-Wave received "(Lux) Downstairs" sensor update to 166 lux
./indigo_log.txt:2015-05-30 10:37:10.099 Z-Wave received "(Humidity) Downstairs" sensor update to 46%
./indigo_log.txt:2015-05-30 10:37:10.136 Z-Wave received "(Temp) Downstairs" sensor update to 70.9 °F
./indigo_log.txt:2015-05-30 10:45:10.063 Z-Wave received "(Lux) Downstairs" sensor update to 171 lux
./indigo_log.txt:2015-05-30 10:45:10.065 Z-Wave received "(Humidity) Downstairs" sensor update to 46%
./indigo_log.txt:2015-05-30 10:45:10.098 Z-Wave received "(Temp) Downstairs" sensor update to 70.6 °F
./indigo_log.txt:2015-05-30 10:53:10.019 Z-Wave received "(Lux) Downstairs" sensor update to 177 lux
./indigo_log.txt:2015-05-30 10:53:10.021 Z-Wave received "(Humidity) Downstairs" sensor update to 46%
./indigo_log.txt:2015-05-30 10:53:10.054 Z-Wave received "(Temp) Downstairs" sensor update to 71.0 °F
./indigo_log.txt:2015-05-30 11:01:12.935 Z-Wave received "(Lux) Downstairs" sensor update to 201 lux
./indigo_log.txt:2015-05-30 11:01:12.973 Z-Wave received "(Humidity) Downstairs" sensor update to 46%
./indigo_log.txt:2015-05-30 11:01:13.006 Z-Wave received "(Temp) Downstairs" sensor update to 70.8 °F
