https://www.dropbox.com/s/lfhwrc00twtk6f8/INDIGOplotD-v-3-11-2.zip?dl=0 Version 3-11-2
FIXES:added compatibility for GNUPLOT 5.x. it will detect your GNUPLOT version modify the GNUPLOT commands accordingly
Some of the line types are not available anymore i.e. lt=0. Time convention is different now (0 was 2000-01-01 00:00:00, now epoch 1970 xx as standard unix)
USABILITY- menue structures improved:
-- can print individual configurations to log file
-- added besides ADD line, DELETE line : DUPLICATE line. with this options you can as it says duplicate a line with all parameters and then one or 3 to add other configs or effects
FUNCTIONALITYyou now can:
- add numbers to specific lines and there to specific points in time, every other, every end of day, min/ max right/left ..
- select a specific point in time for a single data point from a line i.e. MAX/ MIN every 5/6/12th .. bin etc
- new line type: Impulse. Essentially a histogram with a very small widths. useful for single events, i.e. door opened
- add average indicators to individual lines on the left or right y axis
Here 2 examples 1. timeframe: 1 fixed week, always shows monday... sunday
- with current and last weeks temperature with average indicator on right axis
- maximum temperature this week
- current power consumption [W} with min and max value and average indicator on left side
- energy consumption [KWH] for each day this week
- energy consumption for the whole last and this week and Energy consumption for each day
- numbers at end of day, current (e.g. the black 86)
13 lines make up this plot many data sources are in several times, as regular line, as min, as max etc.
- example1.png (30.93 KiB) Viewed 19390 times
2. timeframe: 2 weeks
similar states as above.
in addition cost of electricity consumed this and last week each day (green line)
- example2.png (29.61 KiB) Viewed 19390 times
How to use it:
to generate each of the lines (solid, histogram and Numbers..) your select the data source then the line type:
Here you can see the options. In addition to solid/dashed dotted lines we have added:
average line left and right
vertical lines (impulse)
and NUMBERS
- Screen Shot 2015-07-15 at 10.49.23 PM.png (54.64 KiB) Viewed 19390 times
new menu points:
repeat / every x points:
- Screen Shot 2015-07-15 at 10.52.26 PM.png (94.09 KiB) Viewed 19390 times
here you select if it should a regular line with points everywhere or every other .. or at the Max/Min point or end of day, first point, or last point with data.
number formathere you enter the format string for the numbers show in the plot. "%3.1f" would show 55.378 as 55.3; "%3.0f" as 55 you can add text around it i.e. MAX T=%3.1fC would show e.g. MAX T=93C
number offsetwith x,y you can move the starting point of the number by n character width left/right or up and down. You must use x,y format e.g. 2.4,-0.9
- Screen Shot 2015-07-15 at 11.01.55 PM.png (14.32 KiB) Viewed 19390 times
