Timers not updating, Thermo resets itself. Trigger fails.
Sat Feb 28, 2015 10:59 pm
hamw offline
Re: Timers not updating, Thermo resets itself. Trigger fails
I toggled debugging in the timers and pesters plugin, but it is making a log entry for every second each timer ticks down, and is really rapidly filling the log. Is that the right way to enable debugging for this problem? Should I just let it run?
Sun Mar 01, 2015 3:11 pm
Chockymonster offline
You're not going mad, I'm having exactly the same issue.
I don't have many timers but I had a motion sense timer that used to turn the light off in my downstairs hall, dimming it after 2 minutes and then off completely a minute later.
Some time in December it just stopped working and I haven't been able to figure out why.
If I trigger the event group manually it works but the timer never resets if I leave indigo to do it's stuff.
Sun Mar 01, 2015 7:24 pm
In order to get any further data you'll need to let it run. I was under the impression that it would run less than a day before failing...
Mon Mar 02, 2015 5:47 pm
hamw offline
Below is about 45 seconds worth of log for three timers. The log file closed itself after it accumulated 9.2 megs of data in less than 9 hours.
2015-03-02 08:41:00.852   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:17 left)
2015-03-02 08:41:00.868   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:48 left)
2015-03-02 08:41:00.899   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:30 left)
2015-03-02 08:41:01.922   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:16 left)
2015-03-02 08:41:01.935   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:47 left)
2015-03-02 08:41:01.946   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:29 left)
2015-03-02 08:41:02.961   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:15 left)
2015-03-02 08:41:02.979   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:46 left)
2015-03-02 08:41:02.995   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:28 left)
2015-03-02 08:41:04.009   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:14 left)
2015-03-02 08:41:04.034   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:45 left)
2015-03-02 08:41:04.051   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:27 left)
2015-03-02 08:41:05.067   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:13 left)
2015-03-02 08:41:05.086   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:44 left)
2015-03-02 08:41:05.110   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:26 left)
2015-03-02 08:41:06.121   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:12 left)
2015-03-02 08:41:06.138   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:43 left)
2015-03-02 08:41:06.155   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:25 left)
2015-03-02 08:41:07.171   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:11 left)
2015-03-02 08:41:07.183   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:42 left)
2015-03-02 08:41:07.195   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:24 left)
2015-03-02 08:41:08.208   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:10 left)
2015-03-02 08:41:08.221   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:41 left)
2015-03-02 08:41:08.235   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:23 left)
2015-03-02 08:41:08.550   Timers and Pesters Debug   Timer found: Active with 0:00:29:23 left
2015-03-02 08:41:08.550   Timers and Pesters Debug   Restarting timer "Timer RFX CrawlSp 1 Fam Rm" for 1800 seconds
2015-03-02 08:41:08.571   Timers and Pesters Debug   Timer started: Active with 0:00:30:00 left
2015-03-02 08:41:09.244   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:09 left)
2015-03-02 08:41:09.255   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:40 left)
2015-03-02 08:41:09.277   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:59 left)
2015-03-02 08:41:10.288   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:08 left)
2015-03-02 08:41:10.316   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:39 left)
2015-03-02 08:41:10.339   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:58 left)
2015-03-02 08:41:11.372   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:07 left)
2015-03-02 08:41:11.394   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:38 left)
2015-03-02 08:41:11.416   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:57 left)
2015-03-02 08:41:12.437   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:06 left)
2015-03-02 08:41:12.451   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:37 left)
2015-03-02 08:41:12.462   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:56 left)
2015-03-02 08:41:13.477   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:05 left)
2015-03-02 08:41:13.515   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:36 left)
2015-03-02 08:41:13.540   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:55 left)
2015-03-02 08:41:14.546   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:04 left)
2015-03-02 08:41:14.573   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:35 left)
2015-03-02 08:41:14.585   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:54 left)
2015-03-02 08:41:15.592   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:03 left)
2015-03-02 08:41:15.603   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:34 left)
2015-03-02 08:41:15.626   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:53 left)
2015-03-02 08:41:16.634   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:02 left)
2015-03-02 08:41:16.645   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:33 left)
2015-03-02 08:41:16.654   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:52 left)
2015-03-02 08:41:17.672   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:01 left)
2015-03-02 08:41:17.685   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:32 left)
2015-03-02 08:41:17.696   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:51 left)
2015-03-02 08:41:18.704   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:20:00 left)
2015-03-02 08:41:18.715   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:31 left)
2015-03-02 08:41:18.727   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:50 left)
2015-03-02 08:41:19.770   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:59 left)
2015-03-02 08:41:19.790   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:30 left)
2015-03-02 08:41:19.810   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:49 left)
2015-03-02 08:41:20.823   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:58 left)
2015-03-02 08:41:20.852   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:29 left)
2015-03-02 08:41:20.868   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:48 left)
2015-03-02 08:41:21.876   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:57 left)
2015-03-02 08:41:21.888   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:28 left)
2015-03-02 08:41:21.901   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:47 left)
2015-03-02 08:41:22.909   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:56 left)
2015-03-02 08:41:22.928   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:27 left)
2015-03-02 08:41:22.948   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:46 left)
2015-03-02 08:41:23.966   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:55 left)
2015-03-02 08:41:23.989   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:26 left)
2015-03-02 08:41:24.024   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:45 left)
2015-03-02 08:41:25.029   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:54 left)
2015-03-02 08:41:25.051   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:25 left)
2015-03-02 08:41:25.061   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:44 left)
2015-03-02 08:41:26.069   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:53 left)
2015-03-02 08:41:26.082   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:24 left)
2015-03-02 08:41:26.094   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:43 left)
2015-03-02 08:41:27.124   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:52 left)
2015-03-02 08:41:27.143   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:23 left)
2015-03-02 08:41:27.177   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:42 left)
2015-03-02 08:41:28.191   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:51 left)
2015-03-02 08:41:28.207   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:22 left)
2015-03-02 08:41:28.228   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:41 left)
2015-03-02 08:41:29.240   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:50 left)
2015-03-02 08:41:29.279   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:21 left)
2015-03-02 08:41:29.298   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:40 left)
2015-03-02 08:41:30.307   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:49 left)
2015-03-02 08:41:30.323   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:20 left)
2015-03-02 08:41:30.342   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:39 left)
2015-03-02 08:41:31.345   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:48 left)
2015-03-02 08:41:31.360   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:19 left)
2015-03-02 08:41:31.373   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:38 left)
2015-03-02 08:41:32.407   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:47 left)
2015-03-02 08:41:32.432   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:18 left)
2015-03-02 08:41:32.448   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:37 left)
2015-03-02 08:41:33.452   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:46 left)
2015-03-02 08:41:33.463   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:17 left)
2015-03-02 08:41:33.473   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:36 left)
2015-03-02 08:41:34.484   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:45 left)
2015-03-02 08:41:34.507   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:16 left)
2015-03-02 08:41:34.549   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:35 left)
2015-03-02 08:41:35.567   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:44 left)
2015-03-02 08:41:35.606   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:15 left)
2015-03-02 08:41:35.630   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:34 left)
2015-03-02 08:41:36.635   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:43 left)
2015-03-02 08:41:36.648   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:14 left)
2015-03-02 08:41:36.660   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:33 left)
2015-03-02 08:41:37.682   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:42 left)
2015-03-02 08:41:37.699   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:13 left)
2015-03-02 08:41:37.712   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:32 left)
2015-03-02 08:41:37.745   Received INSTEON   "Thermostat Main Bedrooms" temperature changed to 67.0
2015-03-02 08:41:38.720   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:41 left)
2015-03-02 08:41:38.730   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:12 left)
2015-03-02 08:41:38.750   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:31 left)
2015-03-02 08:41:39.767   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:40 left)
2015-03-02 08:41:39.780   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:11 left)
2015-03-02 08:41:39.816   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:30 left)
2015-03-02 08:41:40.825   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:39 left)
2015-03-02 08:41:40.841   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:10 left)
2015-03-02 08:41:40.855   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:29 left)
2015-03-02 08:41:41.867   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:38 left)
2015-03-02 08:41:41.912   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:09 left)
2015-03-02 08:41:41.936   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:28 left)
2015-03-02 08:41:42.954   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:37 left)
2015-03-02 08:41:42.977   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:08 left)
2015-03-02 08:41:42.995   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:27 left)
2015-03-02 08:41:44.005   Timers and Pesters Debug   Timer "Timer 05 Kitchen Sink" (Active with 0:19:19:36 left)
2015-03-02 08:41:44.018   Timers and Pesters Debug   Timer "Timer 03 Pool House Equipment" (Active with 0:19:22:07 left)
2015-03-02 08:41:44.032   Timers and Pesters Debug   Timer "Timer RFX CrawlSp 1 Fam Rm" (Active with 0:00:29:26 left)
*** Log File Overflow -- suppressing future logging to this file and console ***
How we would debug this issue? I was thinking I could revert to an earlier version to see if something was introduced in the last few versions. I'm on 6.0.20. Any issues with downgrading?
Wed Mar 04, 2015 10:11 pm
That plugin hasn't changed since beta so it's unlikely that it's something recent. Disable debugging for the moment. I'll send you an email tomorrow with a special build of the plugin that will have different debugging that shouldn't overwhelm the log file.
Sun Mar 15, 2015 7:10 pm
hamw offline
I installed the revised plugin, and the timers have updated without a problem for the last 8 days. Really interesting; it may be that my plugin somehow got corrupted and this is the cause of the failures to update. Anyway, problem seems solved for now, and I'll report back if there are further issues.
Jay, thanks for the support!
Sun Mar 15, 2015 8:18 pm
Very odd. Keep us posted.
Sun Mar 29, 2015 8:11 am
hamw offline
I had recreated my timers for the RFX devices, and that seemed to do the trick. However, all the leak sensors had their batteries die within the last few weeks. I finally got around to replacing them, and my issue with the RFX device bicolor state icons returned, with a couple of them stuck on red even when active. I noted some funky behavior with the "Timer 12 Hot Water Heaters", where it would shift between the initial set time, 24 hours, and the actual time remaining on the timer. I created a new timer device and triggers, and turned off the triggers for the original timer. The new timer behaved properly, and interestingly enough, the RG icons for the RFX control page timers started working properly again as well.
I have another leak sensor timer with the same issue, "Timer 09 Sink Game Room", and attach the log file showing odd behavior. It seems it may have been duplicated somehow or is getting activated by another sensor? I don't know how to look at it in the database, but there is only one instance of it that I see. I also turned off the RFX sensor triggers to be sure they were not cross activating the timer, since the timer activation seems to happen every minute or so. I have separately sent some quicktime movies so you can see how the timer cycles.
Hope this is useful. I won't replace this "Timer 09 Sink Game Room" yet if you need further information, but I figure it is some kind of corruption.
Mar 29, 2015 9:21:15 AM
  Timers and Pesters Debug        restartTimer called
  Timers and Pesters Debug          Timer found: 03:59:29
  Timers and Pesters Debug          Restarting timer "Timer RFX CrawlSp 3 Game Rm" for 14400 seconds
  Timers and Pesters Debug          Timer restarted: "Timer RFX CrawlSp 3 Game Rm" (04:00:00)
  Timers and Pesters Debug        Timer main thread still active
  Timers and Pesters Debug          Active timer: "Timer 05 Kitchen Sink" (22:19:36)
  Timers and Pesters Debug          Active timer: "Timer 09 Sink Game Room" (14:24:25)    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  Timers and Pesters Debug          Active timer: "Timer 09 Sink Game Room" (1:00:59:41)  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<   duplicated?
  Timers and Pesters Debug          Active timer: "Timer RFX Rain Gauge" (13:30:33)
  Timers and Pesters Debug          Active timer: "Timer 01 Pool House Kitchen Sink" (1:00:29:54)
  Timers and Pesters Debug          Active timer: "Timer 11 Guest BR" (12:44:02)
  Timers and Pesters Debug          Active timer: "Timer 04 Washer" (1:00:59:42)
  Timers and Pesters Debug          Active timer: "Timer RFX TempHum Outside in Weber Base" (13:45:47)
  Timers and Pesters Debug          Active timer: "Timer 03 Pool House Equipment" (15:15:57)
  Timers and Pesters Debug          Active timer: "Timer RFX CrawlSp 3 Game Rm" (03:59:59)
  Timers and Pesters Debug          Active timer: "Timer 07 Ice Maker Alcoholway" (12:52:29)
  Timers and Pesters Debug          Active timer: "Timer RFX CrawlSP 2 Main House" (03:59:38)
  Timers and Pesters Debug          Active timer: "Timer 08 Foyer Bath First Floor" (13:43:24)
  Timers and Pesters Debug          Active timer: "Timer 06 Fam Rm Bath" (12:35:59)
  Timers and Pesters Debug          Active timer: "Timer Kitchen Thermo Reset after 20 min" (00:19:52)
  Timers and Pesters Debug          Active timer: "Timer RFX CrawlSp 1 Fam Rm" (03:59:36)
  Timers and Pesters Debug          Restarting timer "Timer RFX CrawlSp 1 Fam Rm" for 14400 seconds
  Timers and Pesters Debug          Timer restarted: "Timer RFX CrawlSp 1 Fam Rm" (04:00:00)
  Timers and Pesters Debug          Timer found: 03:59:26
  Timers and Pesters Debug          Restarting timer "Timer RFX CrawlSP 2 Main House" for 14400 seconds
  Timers and Pesters Debug          Timer restarted: "Timer RFX CrawlSP 2 Main House" (03:59:59)
  Timers and Pesters Debug          Timer found: 1:00:59:25
  Timers and Pesters Debug          Restarting timer "Timer 04 Washer" for 90000 seconds
  Timers and Pesters Debug          Timer restarted: "Timer 04 Washer" (1:01:00:00)
  Timers and Pesters Debug          Timer found: 1:00:59:23
  Timers and Pesters Debug          Restarting timer "Timer 09 Sink Game Room" for 90000 seconds   <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  Timers and Pesters Debug          Timer restarted: "Timer 09 Sink Game Room" (1:01:00:00)
  Received INSTEON                "Driveway Gate Door Sensor" off (heartbeat)
  Received INSTEON                "Thermostat GameRm" temperature changed to 59.0
  Timers and Pesters Debug          Timer found: 03:59:28
  SQL Logger                      creating table device_history_756609379 for "new device"
  Timers and Pesters Debug          Timer found: 03:59:24
  Timers and Pesters Debug          Timer restarted: "Timer RFX CrawlSP 2 Main House" (04:00:00)
  Timers and Pesters Debug          Timer found: 1:00:59:21
  Timers and Pesters Debug        Validating device config             (here I am creating a new sink timer to replace the other; ignore)
  Timers and Pesters Debug        Creating timer: new device
  Timers and Pesters Debug        Timer instance created: "new device"
  Received INSTEON                "Thermostat Main Bedrooms" off (button 2)
  Received INSTEON                "Thermostat Main Bedrooms" temperature changed to 65.0
  Timers and Pesters Debug          Timer found: 1:00:59:26
  Timers and Pesters Debug          Timer found: 1:00:59:22
  Received INSTEON                "Thermostat MBR" temperature changed to 64.0
Mar 29, 2015 9:23:41 AM
  Timers and Pesters Debug          Timer found: 03:59:25
  Received INSTEON                "Thermostat Main Bedrooms" temperature changed to 64.0
>>>>>>>> I then turned off the RFX timer triggers, and there was no change in the "Timer 09 Sink Game Room" process  <<<<<<<<<<<<<<
Mar 29, 2015 9:39:56 AM
  Timers and Pesters Debug          Active timer: "Timer 05 Kitchen Sink" (22:04:33)
  Timers and Pesters Debug          Active timer: "Timer 09 Sink Game Room" (14:09:22)
  Timers and Pesters Debug          Active timer: "Timer 09 Sink Game Room" (1:00:59:47)
Mar 29, 2015 9:58:37 AM
  Timers and Pesters Debug          Active timer: "Timer 05 Kitchen Sink" (21:49:30)
  Timers and Pesters Debug          Active timer: "Timer 09 Sink Game Room" (13:54:19)   <<<<<<<<< this continues to count down while the other stays up.
  Timers and Pesters Debug          Active timer: "Timer 09 Sink Game Room" (1:00:51:02)
Mon Mar 30, 2015 9:54 pm
Let's keep this on offline for the moment - it really shouldn't be in this area anyway. I'll update and move if/when we get to the bottom of it and I'll spend some time tomorrow trying to follow what you emailed me.
Sat Apr 13, 2019 6:25 am
hamw offline
As an update, I think we solved the problem by deleting and replacing the timers and pesters plugin. This began happening again, so I deleted and replaced from an archived version. That fixed it. Same version number; just deleted and replaced with another. Wonder how that could become corrupted.
Sat Apr 13, 2019 10:17 am
Disk errors is the most likely cause. I'd recommend running disk utility to see if it finds anything.
