Same here but I modified the plugin and it works!
Enabling debug in the Plugin revealed that the Cree bulb is not returning a 'modelid'. It returns a blank ''. So I added '' to the kLivingWhitesDeviceIDs variable in the plugin.py file of Nathan's excellent plugin.
Here is the modified statement in version 1.3.10:
kLivingWhitesDeviceIDs = ['LWB001', 'LWB003', 'LWB004', 'LWL001', 'ZLL Light', '']
Notice the , '' at the end of the list. I reloaded the plugin after the edit.
When defining a Cree choose the "LivingWhites" model. Now it works.
Nathan, I know this is not an elegant solution but I was glad to see that it worked. I suppose the right fix is to get Cree to include a modelid. Do you know if the modelid is a part of the ZigBee standard? If so, I will ask Cree to add a model in their future bulbs.
Thanks again Nathan for such a great plugin. My Indigo server is in one town and the Hue hub is in an apartment in another town. I have an ipsec tunnel between the two locations and the Hue Plugin works great.
Fyi, the debug output for the Cree bulb.
{u'name': u'Cree Bulb', u'swversion': u'420 ', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'reachable': True, u'bri': 254, u'alert': u'none'}, u’uniqueid': u'e2:0d:b9:ff:fe:00:62:1f-0a', u'type': u'Dimmable light', u'modelid': u''}, u'4':
