Somfy rfxtrx433
Mon Aug 25, 2014 11:13 am
crsarnelli offline
Re: Somfy rfxtrx433
Hello All!
I am new to the forum and I have a question regarding the RFXTRX433E plugin.
I created a SOMFY device (the only options on the device are ON & OFF, my roller shades react to those command as UP & Down). So far great, however, how can I send a "STOP" command with indigo, that way I can stop my shades, let's said, half way?
Thank you,
Carlos
Mon Aug 25, 2014 11:48 am
RJdeKok offline
Re: Somfy rfxtrx433
Hi Carlos,
The stop button is in the menu, Plugins/RFXCOM/Stop Somfy
Mon Aug 25, 2014 1:12 pm
crsarnelli offline
Re: Somfy rfxtrx433
RJ,
Thanks a lot! It worked as advertised!!
Carlos
Tue Aug 26, 2014 12:50 pm
Juju offline
Re: Somfy rfxtrx433
Hello,
During the creation of SOMFY devices, it is requested to fill an house code and an unit code.
I assume the house code is the "address" of the blind, but what is the objective of the unit code. For instance, I put 1 for each device ...
Julien
Sat Nov 01, 2014 1:41 pm
RJdeKok offline
Re: Somfy rfxtrx433
The angle function is implemented and available in the new version:http://www.rjdekok.nl/downloads/RFXCOM.indigoPlugin.zip
Tue Jan 06, 2015 10:16 am
TANE offline
Re: Somfy rfxtrx433
I have installed the latest plugin.
Kaku and Harrison are working fine.
Somfy is not connecting
I have shades with comfy support
any tips?
Enver Tanriverdi
TANE Domotica Advies
Wed Jan 07, 2015 3:54 pm
TANE offline
Re: Somfy rfxtrx433
Problem solved.
When using somfy luxaflex shades you need to use up /down for the angel. (Note the angel+ / Angel -)
Thanks Robert.
Enver Tanriverdi
Sun Aug 30, 2015 3:14 pm
roquej offline
Re: Somfy rfxtrx433
Trying to get Somfy blinds working with RFXCOM. As the installation was professionally done, not sure how/where to find the two required parameters asked in the plugin: housecode and unitcode. The units are working with the Somfy remote.
Would greatly appreciate any suggestions.
JP
Mon Aug 31, 2015 12:40 am
b_weijenberg offline
Re: Somfy rfxtrx433
You have to add the RFXtrx433E device as a new remote to the Somfy motor.
Select a random code and pair this device.
Mon Aug 31, 2015 3:05 pm
roquej offline
Re: Somfy rfxtrx433
Thank you. It worked!
Wed Feb 17, 2016 9:52 pm
DVDDave offline
Re: Somfy rfxtrx433
Just got my rfxtrx433e and was easily able to configure my 3 solar screens to work from Indigo. So cool to be able to control them from my watch, Siri, Apple TV, etc. Thanks for this great plugin!!
--Dave
Sat Feb 20, 2016 6:10 am
haavarda offline
Re: Somfy rfxtrx433
I am using this plugin with my somfy vertical blinds, and it is working good. There should however be an option to send a very small angle change signal to the blinds. The command is available from rfx manager... Could it be possible to add these commands also?
Håvard
