Hello - receiving an error when trying to unpack the most current version.
Dave
Action Group Sonos Announce MP3 Test
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 162, in actionZP_announcementMP3
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 898, in actionAnnouncement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 884, in actionStates
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 255, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 860, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 732, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 699, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 683, in connect
<class 'socket.timeout'>: timed out
ckeyes888 wrote:Just tried 6.18 on a 10.8 machine and get this error:
- Code: Select all
The plugin did create the mp3 file in this version...just won't play it.
The Sonos app will play it fine.
Carl
Indy_Larry wrote:Hey Nick,
I after updating the Sonos Plugin on my 10.7.5 server I'm seeing the following errors
File "plugin.py", line 9, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 39, in <module>
File "./lib/zmq/__init__.py", line 35, in <module>
<type 'exceptions.ImportError'>: dlopen(./lib/zmq/utils/initthreads.so, 2): Library not loaded: /usr/local/lib/libzmq.1.dylib
Referenced from: /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/lib/zmq_10.6/utils/initthreads.so
Reason: image not found
Stopping plugin "Sonos 0.6.18" (pid 78246)
Stopped plugin "Sonos 0.6.18"
Error plugin "Sonos 0.6.18" (pid 78246) failed to start -- restarting in 20 seconds
Thanks for all of you work and help with this Plugin.
haavarda wrote:Has there any movement on this? I am waiting eagerly because my announcement system is down due to some error in this plugin.
There has been done some great work on this, so I hope these small issues can be fixed!
Håvard
nlagaros wrote:I think I fixed the issue with the radio station flipping back after the group announcement. Can you please download the latest version and give this another try. Thanks.haavarda wrote:Has there any movement on this? I am waiting eagerly because my announcement system is down due to some error in this plugin.
Håvard
