Weather Underground Plugin
Thu Mar 20, 2014 6:59 pm
Download it here: [Download]
Overview:
The Weather Underground plugin scrapes key weather data from a JSON feed provided by Weather Underground. It allows the user to be able to create devices that represent individual locations for which weather data is presented. The weather data is presented by setting up devices (the data are stored in device state values.) Each location is represented by an individual device.
Thu Mar 20, 2014 8:46 pm
Re: Weather Underground Plugin
Hi Dave,
Great contribution -- thanks for sharing it! I've added it to our list of weather related plugins.
Thu Mar 20, 2014 9:19 pm
Korey offline
matt (support) wrote:
Hi Dave,
Not seeing the download link for the plugin.. I could be blind thou.. :?
Korey
Fri Mar 21, 2014 3:15 am
It's available now from the User Contribution Library:
http://www.perceptiveautomation.com/fil ... ds=weather
Fri Mar 21, 2014 6:15 am
jalves offline
Wondering what level of developer I need to select in order to use this plug-in. Stratus, Cumulus, or Anvil?
Jeff
Fri Mar 21, 2014 6:23 am
I use the most basic level (Stratus, Developer, No History). It's free, and provides up to 10 calls per minute and up to 500 calls per day (per API Key).
Dave
Fri Mar 21, 2014 11:20 am
colinpartridge offline
Thought I'd try this plugin with a local pws and I'm getting the following error..
Wunderground Error              plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Wunderground Debug              runConcurrentThread initiated.
  Wunderground                    Wunderground: pws:IGREATER22
  Wunderground Error              Error in plugin execution runConcurrentThread:
  File "plugin.py", line 342, in runConcurrentThread
  File "plugin.py", line 74, in convStr
<type 'exceptions.ValueError'>: invalid literal for float(): NA
It works fine if I use Canada/Toronto for example so I know my developer key is OK.
any ideas
Fri Mar 21, 2014 11:46 am
jalves offline
Dave
Thanks! Found out that I could select the Anvil plan with History at the Developer level for no cost so I did that. Got to allow for future expansion!
Jeff
Jeff
Fri Mar 21, 2014 1:51 pm
jalves offline
So just trying this out but not seeing where I enter my API key. There doesn't seem to be an option for that when I select Plugin or when I create a device.
Jeff
Fri Mar 21, 2014 1:54 pm
any ideas
The plugin is trying to convert something into a floating value and is really unhappy about it. Seriously though, what's happening is that Weather Underground is probably returning a string for a variable where a numeric is usually provided. It can be easily fixed, but I'm not in a place to be able to make a revised version of the plugin available until later today.
If you're seeing the error repeat in your log over and over again, I'd suggest disabling the plugin for the time being as it's possibly going to be reaching out to Weather Underground site every time Indigo reloads it.
[EDIT] Nevermind on the location info; I see now that it's in the log data you posted.
Sorry for the troubles,
Dave
Fri Mar 21, 2014 1:57 pm
The API key is entered through the plugin configuration menu. In Indigo, go to plugins, Wunderground and select Configure... From there you can enter the key and the frequency that you want to update the data.
On each device is where you enter the location you'd like to monitor.
Fri Mar 21, 2014 2:35 pm
jalves offline
Don't know how I missed this in the first place. Thanks!
Jeff
Fri Mar 21, 2014 2:43 pm
No problem whatsoever. Thanks for checking it out!
Dave
Fri Mar 21, 2014 3:02 pm
Dave
No need to apologise, wouldn't have surprised me if I had got the location information wrong..
Colin
Fri Mar 21, 2014 3:44 pm
Colin
You are too kind.
I have revised the code, and need to run a test against the WU server. Will ask Jay and Matt to make the new version available later tonight.
Dave
