[SOLVED] NOAA Weather Plugin
Sun Jan 26, 2014 8:20 am
jalves offline
I updated Indigio (Pro) to 6.0.10 yesterday morning and noticed that the NOAA Weather plugin has stopped updating. Is that happening for anybody else? I've reloaded the plug-in several times to no avail. The error log shows nothing. Wondering if this is just a coincidence of my upgrade and something happening at NOAA.
Note that this is the NOAA Weather, not NOAA Weather Plus.
[VIEW SOLUTION]
Jeff
Sun Jan 26, 2014 8:53 am
Chompy offline
Re: NOAA Weather Plugin
I use NOAA Weather Plus & get errors occasionally, but I doubt it has anything to do with the latest release of Indigo.
This morning the plug in is failing to update about 1/2 the time. (I think it runs every 15 minutes)
 NOAA Weather Plus Error         Unknown error getting weather for coordinates 47.6152, -122.3497: <urlopen error timed out>
The failures most likely have something to do with the site the plugin connects to.
Sun Jan 26, 2014 10:02 am
Look at the Last Update field in the Device Details tile - does it show a time within the last hour or so? If so, then the NOAA data is just not getting updated in their feed. If there are no errors in the log then the plugin is getting data from NOAA.
Sun Jan 26, 2014 10:30 am
jalves offline
I did check that before I wrote my post and it was showing that the last update was a day old. :cry:
However, I tried one last thing after my post this morning. I stopped the Indigo server and quit the application. Then I restarted everything. Just looked at the variables and they have now updated for the latest info. So, problem solved.
Jeff
Thu Jan 30, 2014 6:39 am
HFTobeason offline
I, too, see this type of error quite often:
    NOAA Weather Plus Error Unknown error getting weather for coordinates XX.0625, -XXX.502: <urlopen error timed out>
Usually in groups of two, sometimes groups of four -- and often multiple times per hour for hours at a time. And then, it'll simply resolve itself. Note that the author of the plugin states (viewtopic.php?f=3&t=11122&hilit=noaa+weather+plus):
    Ah yes. That error. I do recognize that one. Unfortunately, the "urlopen error timed out" error is one I haven't been able to fix. It appears to either be intermittent NOAA server reliability issues or, more likely, a known issue with the urllib2 library that comes with Python 2.5. I'll continue to search for workarounds.
Also (viewtopic.php?f=31&t=8701&hilit=noaa+weather+plus&start=210) -- scroll down.
Thu Jan 30, 2014 9:41 am
@HFTobeason - wrong plugin, the OP was talking about the NOAA plugin that ships with Indigo. The NOAA Weather Plus plugin is a 3rd party plugin.
Thu Jan 30, 2014 9:42 am
HFTobeason offline
Ooops! Sorry. Same error, though. Though @Chompy is referring to Weather Plus...
Thu Jan 30, 2014 10:12 am
No problem - just wanted to make sure you knew it since I don't know that Nathan is watching this thread since it's not in his forum… ;)
Wed Apr 23, 2014 3:53 pm
jgraybill offline
Re: [SOLVED] NOAA Weather Plugin
Somewhat related, is there way to email the variable data from the plugin? For example, I'd like to receive an email as a "freeze temp" alert for a second home.
Thu Apr 24, 2014 8:36 am
If you're wanting to add the contents of a variable to an email, there is an example in the scripting tutorial (you need to use a little script).
Fri Apr 25, 2014 11:49 am
jgraybill offline
thanks Jay!
