[SOLVED]iTunes Plugin Problems
Mon Jan 13, 2014 9:02 pm
RufusFirefly offline
I am having a problem with the iTunes plug in. I keep getting the following error .....
iTunes Error iTunes stopped due to the following error (will attempt to recover in 10 seconds):
File "statusThread.py", line 128, in run
File "itunes.py", line 169, in status
AttributeError: 'timeout' object has no attribute 'errorNum'
I am running Indigo 6.07, iTunes 11.1.3, and OSX 10.9.1
I can re-enable the plugin, it will work for a bit, then would error out again.
Any suggestions ?
Tue Jan 14, 2014 10:33 am
Re: iTunes Plugin Problems
(moved to a more appropriate location)
Odd - those line numbers aren't matching up with the currently shipping plugin. What version number shows when you look at the "Plugins->iTunes->About iTunes vX.X.X..." menu item?
In any event, it appears that the plugin is getting a network timeout talking to your iTunes instance. Is it on the same Mac as your IndigoServer or on a different Mac?
Tue Jan 14, 2014 5:19 pm
iTunes Plugin is version 1.1.4
Yes, Indigo server and iTunes are all on the same computer.
Tue Jan 14, 2014 7:02 pm
Send me an email (indigo DASH support AT perceptiveautomation DOT com) pointing to this thread - I want to take this one offline to diagnose more.
Sat Jan 25, 2014 11:14 pm
Solved.
I did a clean install of Mavericks, and since then have had no issues at all.
Thanks.
Sun Jan 26, 2014 9:58 am
Glad it's working for you - I suspect you might notice other things that are working more consistently as well. Sometimes a good OS cleaning is just what the doctor ordered (though I know it's painful).
