I just tried the plugin - didn't get too far. Current version of Indego (just upgraded). I cranked up debugging and put the log output below.
Any thoughts?
- Code: Select all
Starting plugin "Sharp TV Network Remote Plugin 1.0.4" (pid 9476)
Sharp TV Network Remote Plugin Debug Beginning processing of RPFrameworkConfig.xml file
Sharp TV Network Remote Plugin Debug Found device mapping; id: sharpTvRemoteDevice to class: SharpTvNetworkRemoteDevice
Sharp TV Network Remote Plugin Debug Created device parameter for managed device 'sharpTvRemoteDevice': ipAddress
Sharp TV Network Remote Plugin Debug Created device parameter for managed device 'sharpTvRemoteDevice': portNumber
Sharp TV Network Remote Plugin Debug Created device parameter for managed device 'sharpTvRemoteDevice': updateInterval
Sharp TV Network Remote Plugin Debug Found device setting: deviceAddressFormat=%ap:ipAddress%:%ap:portNumber%
Sharp TV Network Remote Plugin Debug Found device setting: telnetConnectionDeviceStateName=connectionState
Sharp TV Network Remote Plugin Debug Found device setting: telnetConnectionDeviceStateBoolean=isConnected
Sharp TV Network Remote Plugin Debug Found device setting: telnetConnectionRequiresLoginProperty=requiresLogin
Sharp TV Network Remote Plugin Debug Found device setting: updateStatusPollerActionId=updateDeviceStatesFromTv
Sharp TV Network Remote Plugin Debug Found managed action: updateDeviceStatesFromTv
Sharp TV Network Remote Plugin Debug Found managed action: toggleTVPower
Sharp TV Network Remote Plugin Debug Found managed action: setTVPower
Sharp TV Network Remote Plugin Debug Processing 1 params for action
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'setTVPower': powerState
Sharp TV Network Remote Plugin Debug Found managed action: changeTVPowerOnMessages
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'changeTVPowerOnMessages': powerOnMessageState
Sharp TV Network Remote Plugin Debug Found managed action: changeAVMode
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'changeAVMode': avMode
Sharp TV Network Remote Plugin Debug Found managed action: changeViewMode
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'changeViewMode': viewMode
Sharp TV Network Remote Plugin Debug Found managed action: setVolumeLevel
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'setVolumeLevel': volumeLevel
Sharp TV Network Remote Plugin Debug Found managed action: setMuteStatus
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'setMuteStatus': muteState
Sharp TV Network Remote Plugin Debug Found managed action: setSurroundSoundMode
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'setSurroundSoundMode': surroundSoundMode
Sharp TV Network Remote Plugin Debug Found managed action: setSleepTimer
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'setSleepTimer': sleepTimerSetting
Sharp TV Network Remote Plugin Debug Found managed action: setClosedCaptioning
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'setClosedCaptioning': ccState
Sharp TV Network Remote Plugin Debug Found managed action: selectInput
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'selectInput': tvInput
Sharp TV Network Remote Plugin Debug Found managed action: tuneToAnalogChannel
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'tuneToAnalogChannel': channelNumber
Sharp TV Network Remote Plugin Debug Found managed action: addDigitToChannelSelector
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'addDigitToChannelSelector': digitToAdd
Sharp TV Network Remote Plugin Debug Found managed action: remoteDigitFromChannelSelector
Sharp TV Network Remote Plugin Debug Found managed action: clearChannelSelector
Sharp TV Network Remote Plugin Debug Found managed action: tuneToChannelSelector
Sharp TV Network Remote Plugin Debug Found managed action: sendRemoteKey
Sharp TV Network Remote Plugin Debug Created parameter for managed action 'sendRemoteKey': keyToSend
Sharp TV Network Remote Plugin Debug Successfully completed processing of RPFrameworkConfig.xml file
Started plugin "Sharp TV Network Remote Plugin 1.0.4"
Sharp TV Network Remote Plugin Debug Version check initiated
Sharp TV Network Remote Plugin Debug Version File Url:https://www.rogueproeliator.com/IndigoPlugins/SharpTvNetworkRemote/SharpTvNetworkRemoteVersionInfo.html
Sharp TV Network Remote Plugin Your plugin version, v1.0.4, is current.
Sharp TV Network Remote Plugin Debug Entering deviceStartComm for Living Room TV; ID=1673038095
Sharp TV Network Remote Plugin Debug Read device state config... isConnected: 'isConnected'; connectionState: 'connectionState'
Sharp TV Network Remote Plugin Debug Establishing connection to 192.168.1.80
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
Sharp TV Network Remote Plugin Debug Exiting deviceStartComm for Living Room TV
Sharp TV Network Remote Plugin Debug Connection established
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:telnetConnectionEOLString
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:telnetConnectionStringEncoding
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:updateStatusPollerIntervalProperty
Sharp TV Network Remote Plugin Debug Command queue has 1 command(s) waiting
Sharp TV Network Remote Plugin Debug Create connection command de-queued
Sharp TV Network Remote Plugin Debug Executing full status update request...
Sharp TV Network Remote Plugin Debug Command queue has 15 command(s) waiting
Sharp TV Network Remote Plugin Debug Sending command: POWR?
Sharp TV Network Remote Plugin Debug Write command completed.
Sharp TV Network Remote Plugin Debug Received: 1
Sharp TV Network Remote Plugin Debug Found response match: powerStatusQuery
Sharp TV Network Remote Plugin Debug Effect execution: Update state 'powerState' to 'True'
Sharp TV Network Remote Plugin Debug Command queue has 14 command(s) waiting
Sharp TV Network Remote Plugin Debug Sending command: RSPW?
Sharp TV Network Remote Plugin Debug Received: ERR
Sharp TV Network Remote Plugin Debug Found response match: powerOnMessagesEnabledStatusQuery
Sharp TV Network Remote Plugin Debug Effect execution: Update state 'powerOnCommandsEnabled' to 'False'
Sharp TV Network Remote Plugin Debug Command queue has 13 command(s) waiting
Sharp TV Network Remote Plugin Debug Sending command: ITGD?
Sharp TV Network Remote Plugin Debug Found response match: currentInputQuery
Sharp TV Network Remote Plugin Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sharp TV Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 209, in concurrentCommandProcessingThread
self.handleDeviceResponse(responseText.replace(lineEndingToken, ""), command)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sharp TV Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 330, in handleDeviceResponse
rpResponse.executeEffects(responseText, rpCommand, self, self.hostPlugin)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sharp TV Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkDeviceResponse.py", line 115, in executeEffects
newStateValue = eval(newStateValueString)
File "<string>", line 1, in <module>
ValueError: invalid literal for int() with base 10: 'ERR'
Sharp TV Network Remote Plugin Debug Closing connection to device
