TED5000 - The Energy Detective
Sat Aug 04, 2012 6:56 am
nlagaros offline
I posted an update to the plugin to deal with Mountain Lion / Python 2.5 issues.
v1.02 - 2012-08-04
  • Update for Mountain Lion support. There was an issue with decimal formatting of values which has been changed to float formatting.
Thu Aug 09, 2012 8:53 am
Ian offline
Re: TED5000 - The Energy Detective
Thanks for the update...Ya, mine stopped working after Mountain Lion Install. Can you post the link to the updated plugin as the link that I had does not appear to be working.
Thu Aug 09, 2012 9:11 am
nlagaros offline
Here you go: https://vulture.lagaros.com/wiki/projects/homeautomation/Home_Automation.html
It is also in the plugin topic announcement.
Thu Aug 09, 2012 10:17 am
Ian offline
Thanks for the newer link
I was using this one from an older page. https://vulture.lagaros.com/wiki/pages/ ... l....which did not work.
Thanks again for the plugin and your work.
It is working well.
Cheers......Ian
Thu Aug 16, 2012 2:00 pm
terrydew offline
Nick
Will this work for multiple panels (3)?
Terry
Thu Aug 16, 2012 6:35 pm
nlagaros offline
Terry,
The TED gateway can be used with up to 4 sets of measuring clamps so the answer to your question is yes. Are your three panels independently fed from the utility? If one is a master and you are not interested in monitoring usage in each panel, you only need one set of clamps. In my configuration, I have three panels, but one main feeder. I have one set of clamps on the feeder, and a second set on my solar inverter.
It is a pretty slick device.
-Nick
Sun Dec 01, 2013 8:28 pm
hamw offline
This is not a problem with the plug-in, but I had a couple of power outages which resulted in a spike of 39,000 kW being recorded and my TED 5000. Do you know of any way of editing this in the TED database? Or is there some other way doing this without wiping out all the data?
Sun Dec 01, 2013 8:35 pm
nlagaros offline
I don't believe there is a way yet. Many TED users are frustrated by this: http://www.theenergydetectiveforums.com/index.php?PHPSESSID=hk4hms3sv4pi386ii2mp9u78p4&topic=2208.0
Sun Dec 01, 2013 8:55 pm
hamw offline
Wow, bad. Thanks for pointing that out.
Mon Dec 30, 2013 6:18 pm
Bollar offline
I just found this plug-in. Thanks!
I have an error on start-up that appears to let the plug-in update only once then stop:
  Starting plugin "TED 5000 Plugin 1.0.3" (pid 1251)
  Started plugin "TED 5000 Plugin 1.0.3"
  TED 5000 Plugin                 Your plugin version, v1.0.3, is current.
  TED 5000 Plugin Error           exception in deviceStartComm(TED 5000): global name 'flaot' is not defined
  TED 5000 Plugin                 Polling Interval: 5
Hopefully it's not just me. ;)
Tue Dec 31, 2013 3:51 pm
nlagaros offline
That is a strange error. Can you confirm that you configured the plugin polling interval and the TED device?
Tue Dec 31, 2013 7:50 pm
bda offline
I have the exact same error too!
Since day one. Would you like me to try something?
Tue Dec 31, 2013 8:00 pm
nlagaros offline
Can you go to the main plugin configuration screen and save all settings. I added the version checker options there so perhaps it is in a funky state. I've seen this before when adding new configuration options. Thanks.
Tue Dec 31, 2013 8:11 pm
nlagaros offline
You will have to restart the plugin after saving those options. If this doesn't work, then please activate debug mode and restart the plugin again. Perhaps there will be some helpful output.
This is the first plugin I wrote and there is absolutely no smart logic in it.. going to have to revamp it when I have a little time.
Tue Dec 31, 2013 10:01 pm
bda offline
Hello Nick;
I think the bug is with TED and that their XML is reporting back <float> as an element and not <float>.
Perhaps this is something you could see if you can work around.
What is important is that when I change the # of MTUs from 4 to 3 it appears to work!
It looks like an error with the TED software on the 4'th MTU.
Separately, I noticed that the TED unit can't resolve system time when I have 4 MTUs. Their software (TED's) is a bit buggy with more than 3 MTUs and it looks like it extends to their reporting. :(.
I appreciate your plugin and support. Happy New Year
