freshwuzhere wrote:Hi Petervon,
The USB part of the coms would probably not be too challenging - but which AC hardware do you have and how do you control that? I have found this expensive and challenging.
Ian
I looked here https://github.com/instanttim/monitormate and found python code that appears to do what you want. It isn't in a plugin frame work but it looks like most of the hard work has been done to stream and interpret the data.
From this starting point (I am making the BIG assumption this code is doing what you want done on the mate3 side) the plugin to place this data into indigo device states that can be used by indigo would be possible I am pretty sure.
Not sure my skill levels are up to commercial levels for this nor that I'd have time to do anything in the near future but I'm happy to help you where I can - it won't be before January tho.
The big challenge is debugging without a Mate3 unit present (this I think would make it nearly impossible) - the good news I am installing a solar and standby generator unit at my house early next year and every chance it will be a Mate 3 controller!
Ian
