All plugins have now been tested as well. Here are some things that we noticed that should help:
- 10/23/2013 - Airfoil doesn't yet support Instant On (the ability to switch between apps without restarting) doesn’t currently work with Airfoil so if you use that feature you might want to wait until they have a revision out that does support it.
- 10/23/2013 - Growl has yet to be updated with Mavericks support so we can't really test until it's updated.
- 10/23/2013 - We noticed when we re-paired our first iTunes server device (which will probably have to be done) that we got a network timeout. Redoing the pairing worked the second time so it may have just been a transient issue.
- 10/23/2013 - We tested against WeatherSnoop 2.x and it worked fine. The WeatherSnoop 3 download from Tee-Boy's website appears to be corrupt. Once we can get a working version of WeatherSnoop 3 we'll test it as well though we don't have any reason to believe it won't work.
So unless otherwise specified all plugins appear to be working normally. If you find something post it here.
Updates:
• Indigo 5 seems fine as well - again, report any issues you find here.
• Indigo 4 and previous are not supported on Mavericks.
