[SOLVED] Aeon Panic Button
Sat Oct 19, 2013 1:49 am
col offline
Bought one of these although it is not in the supported list,hoped it would work as the Aeon key fob is supported, syncs ok but does not show up in the 'edit event settings' drop down menu.
Any chance of getting this to work? bought it for my elderly Mother and I told her that you are such nice Guys :lol:
Colin
Sat Oct 19, 2013 8:39 am
Re: Aeon Panic Button
Hi Colin
We have added support for that device. You should be able to create new Triggers of type Z-Wave Event that catch the button press. Does that work?
Sat Oct 19, 2013 8:48 am
col offline
I tried to make a trigger with a Z-wave event but the panic button does not show up in the Z-wave command drop down box
Sat Oct 19, 2013 9:06 am
Open the device settings dialog, press the button to write the device profile to the Event Log, then copy/paste the results into a post for me. You probably have a version of that module that has a different model ID than the one we added.
Sat Oct 19, 2013 9:20 am
col offline
Nothing happens when I press the button, no moving bars and nothing in the log
Indigo Z-Wave Version: 1.0.133
Node ID: 76
Model: Portable Remote Controller
Model ID: 00000000
Manufacturer: Unknown
Manufacturer ID: 0000
Protocol Version: 0.00
Application Version: 0.00
Model Definition Version: 0
Library Type: 0
Class Name: Portable Remote Controller
Class Hierarchy: 01 : 01 : 01
Command Class Base: 00
Command Versions: 20v1
Features: beaming
Neighbors: - none -
Associations: - none -
Config Values: - none -
Sat Oct 19, 2013 9:29 am
It doesn't look like that model sync'd fully. Try re-syncing it, and copy/paste the Event Log showing the results. Be sure and follow the steps outlined here to keep it awake during the sync.
If that doesn't work, then exclude it from the Z-Stick and try starting over (re-including it and re-defining/syncing it in Indigo).
Sat Oct 19, 2013 9:42 am
col offline
After 3 re-syncs it is now working
Thanks Matt
Sat Oct 19, 2013 10:56 am
col offline
My Mother says thank you and would like to invite you over for tea :mrgreen:
Sat Oct 19, 2013 2:20 pm
Tell her, "All in day's work, Mam."
