APCUPSD Plugin discussion
Thu Sep 12, 2013 4:41 am
berkinet offline
This topic is for discussion of the apcupsd plugin.
See the APCUPSD (UPS daemon) Plugin announcement topic for documentation and download instructions.
Fri Sep 13, 2013 6:50 am
berkinet offline
New version available
Version 0.1.2 of the acpupsd plugin is now available. See the APCUPSD Announcement Forum for more information.
Sun Sep 15, 2013 5:52 am
philc offline
Re: APCUPSD Plugin discussion
Berkinet,
Really glad to see that you are working this. I have a localhost APC UPS, running APCUPSD on my Mac Mini Server at port 3551.
Plugin reports comms with the UPS (after reconfiguring NetBarrier BTW, which automatically blocked comms) but no device state is being reported and no variables are being update.
No errors being thrown in the log - other than an error suggesting there is already an update to the plugin (0.3.0) that it appears you haven't posted yet.
What else do you need from me to investigate? Plugin is set up with all defaults.
Best
Phil
Sun Sep 15, 2013 5:56 am
berkinet offline
Phil... best to wait a short bit for 0.3.1 -- I changed a lot of the internals, plus added a lot of features. Should be today.
Sun Sep 15, 2013 6:17 am
philc offline
Awesome, great!
Sun Sep 15, 2013 9:04 am
philc offline
Berkinet,
Plugin is throwing the following error:
Reloading plugin "apcupsd 0.3.1"
Stopping plugin "apcupsd 0.3.1" (pid 318)
Stopped plugin "apcupsd 0.3.1"
Starting plugin "apcupsd 0.3.1" (pid 829)
Started plugin "apcupsd 0.3.1"
apcupsd Error readApcupsd: Status read for UPS UPS failed. Data received was:{}. Will retry in 15 seconds.
Sep 15, 2013 11:02:00 AM
Sep 15, 2013 11:02:15 AM
Sep 15, 2013 11:02:30 AM
Sep 15, 2013 11:02:45 AM
Sep 15, 2013 11:03:00 AM
apcupsd Error exception in deviceStartComm(UPS): not all arguments converted during string formatting
Not showing any comms with the UPS. APCUPSD is seeing the UPS, and everything is good on that end - plugin just isn't seeing it.
Hope this helps. BTW, running 0.3.1
Best,
Phil
Sun Sep 15, 2013 9:07 am
berkinet offline
Get 0.3.2 !!!!
Sun Sep 15, 2013 2:47 pm
berkinet offline
Handling apcupsd events IMPORTANT INFORMATION
If you are planning on enabling event handling you need to read this
When you edit the various event handler shells, you MUST edit the first line of the file.
Change
#!/bin/sh
to
#!/bin/ksh
If you do not do this, each time apcupsd passes an event to Indigo, the interface process will hang after completing it's task. The hung processes will be swapped out to disk, so the damage is not that great. But, having a lot of hung processes it not a good idea. BTW, if you did not change sh to ksh and find a hung process, you need to use kill -9 to get rid of it from the terminal, or force quit from the application monitor.
Mon Sep 16, 2013 3:20 am
berkinet offline
apcupsd plugin 0.3.3 available
Version 0.3.3 of the acpupsd plugin is now available. See the APCUPSD Announcement Forum for more information.
Mon Sep 16, 2013 6:06 pm
philc offline
Upgraded to 0.3.3 - not having any issues, comms are good.
Tue Oct 29, 2013 1:54 pm
berkinet offline
apcupsd plugin 0.4.0 available
Version 0.4.0 of the acpupsd plugin is now available. See the APCUPSD Announcement Forum for more information.[/quote]
Thu Oct 31, 2013 5:15 pm
philc offline
Version 0.4 is a big step backward on my system. While the plugin shows up in the plugin list, when I go to create a new device APCUPSD is not one of the options. APCUPSD plugin also doesn't offer a configure setup. Maybe I installed it wrong - followed the uninstall/reinstall instructions from above. Any ideas?
Thu Oct 31, 2013 5:33 pm
philc offline
Follow up - dunno if this is a contributing problem, but there is no prefs file in the preferences folder for this plugin anymore. I deleted the old prefs file - should it have been replaced on install?
Phil
Fri Nov 01, 2013 4:50 pm
philc offline
Here's what Indigo is logging when I do a fresh install after a reboot:
Installing and enabling plugin "apcupsd" v0.4.0
Loading plugin "apcupsd 0.4.0"
Starting plugin "apcupsd 0.4.0" (pid 586)
apcupsd Log level preferences are set to "Normal".
apcupsd Error Error in plugin execution InitializeMain:
File "<string>", line 1, in <module>
File "plugin.py", line 102, in __init__
<type 'exceptions.KeyError'>: key apcupsdTimeout not found in dict
Stopping plugin "apcupsd 0.4.0" (pid 586)
Stopped plugin "apcupsd 0.4.0"
Sat Nov 02, 2013 3:36 am
berkinet offline
philc wrote:
...While the plugin shows up in the plugin list, when I go to create a new device APCUPSD is not one of the options. APCUPSD plugin also doesn't offer a configure setup. Maybe I installed it wrong - followed the uninstall/reinstall instructions from above. Any ideas?
The problem appears to be related to the order in which the plugin was upgraded and the plugin config file was deleted. I have made changes to the plugin to allow it to use default config values, and warn the user, in cases where the config file is not, for whatever reason, available.
Thanks for catching this bug.
