berkinet wrote:Click Edit Action Settings... For Insert State: Select Temperature and for Into Variable: select the variable (it must already exist) you wish to save the temperature into.
Thanks berkinet, that's perfect.
M.
31 Aug 2013 18:31:15
SQL Logger Error exception trying to insert row into table device_history_1965852535 ("NA Outdoor") -- unable to modify table
SQL Logger Error near "when": syntax error
SQL Logger Error INSERT INTO device_history_1965852535 (battery_level, humidity, rf_signal, temperature, when) VALUES (%s, %s, %s, %s, %s);
Netatmo Plugin Error Error: -'NoneType' object is unsubscriptable- reading data for Indigo device 'NAOutdoor'
col wrote:Glad you found it. I also just updated the link to v0.4.1. Minor change to support users of the SQL Logger plugin.Is the download link broken? getting a 404 error
Ignore, just found it
oliverjhudson wrote:Will this plugin work with the standalone thermostat as well, or does it only handle the weather station?
Users browsing this forum: No registered users and 22 guests
