berkinet wrote:It looks like you have an incompatibility between the Indigo thermostat device and the plugin version. Try deleting the thermostat device and recreating it.
matt (support) wrote:It looks like this plugin also need to have its usage of deviceUpdated() modified. In general plugins should use deviceStartComm() and deviceStopComm() and not deviceUpdated(), and if deviceUpdated() is called it should always call the parent/base class implementation.
berkinet wrote:Sorry 'bout that Version 1.9.6 is now available on dropbox and it fixes the update problem.
asw24b wrote:berkinet wrote:Sorry 'bout that Version 1.9.6 is now available on dropbox and it fixes the update problem.
I am getting 2 errors when I create a new device:
Proliphix Thermostat Control Error Error in plugin execution ServerAddedElem:
File "plugin.py", line 514, in deviceCreated
<type 'exceptions.KeyError'>: key NumHumidityInputs not found in dict
followed by:
Error (client) illegal state key hvacHeaterIsOn defined by plugin -- native state keys cannot be overriden (ignoring)
Error (client) illegal state key hvacCoolerIsOn defined by plugin -- native state keys cannot be overriden (ignoring)
I should mention that I have set humidity inputs to 0. I have a 350W; Maybe that needs to be set to 1...
Users browsing this forum: No registered users and 27 guests
