- Posted on
Sun Nov 04, 2012 10:30 am
jmesberg
offline
Spoke too soon....I seem to have this partly working, but not entirely. If I add a device for the plugin using the IP address of my 'main' ZonePlayer it works perfectly. However since that only controls/reports on what is playing on that Zoneplayer, I made the leap that I should add additional devices for the other ZonePlayers, etc. That throws a bunch of errors in the log (see below).
Obviously it doesn't like multiple Indigo devices referencing different Zone Players. I'll stop cluttering this thread with additional posts and give Nick or someone else a chance to tell me what I'm doing wrong. (If you can't add multiple Indigo devices for different zoneplayers, then how can you control or check state info on the various zoneplayers in the home?).
Thank you!
Sonos Error Error in plugin execution ServerAddedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 5/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 711, in deviceCreated
File "plugin.py", line 65, in deviceStartComm
File "plugin.py", line 229, in deviceStartComm
File "plugin.py", line 1271, in getLineInDirect
File "plugin.py", line 337, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 860, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 732, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 699, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 667, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/encodings/idna.py", line 164, in encode
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/encodings/idna.py", line 73, in ToASCII
<type 'exceptions.UnicodeError'>: label empty or too long
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "plugin.py", line 261, in runConcurrentThread
File "plugin.py", line 366, in checkDirect
File "plugin.py", line 371, in checkOneDirect
