Reloading plugin "Group Trigger 0.9.15"
Stopping plugin "Group Trigger 0.9.15" (pid 64008)
Group Trigger Debug <<-- entering deviceStopComm: Group Door Open, 648352520
Group Triggers Plugin processing disabled for group trigger Group Door Open
Group Trigger Debug <<-- entering deviceStopComm: Group Motion, 346364470
Group Triggers Plugin processing disabled for group trigger Group Motion
Group Trigger Error exception in triggerStopProcessing(Group Motion): 346364470
Group Trigger shutdown called
Plugin "Group Trigger" disconnected
Starting plugin "Group Trigger 0.9.15" (pid 64022)
Plugin "Group Trigger" connected
Group Trigger Meta Triggers Plugin Initialized
Plugin "Group Trigger 0.9.15" started
Group Trigger Plugin startup.
Group Trigger Debug versionCheck() called
Group Trigger Your plugin version, v0.9.15, is current
Group Trigger Debug Trigger Startup
Group Triggers Plugin processing enabled for group trigger Group Door Open
Group Trigger Debug Finished device processing:
On dict is: {648352520: []}
Off dict is: {648352520: []}
Triggers are: {648352520: {'actionOff': u'428342652', 'process': True, 'saveVarOFF': '', 'saveVarON': u'whichdoor', 'responseOff': 'trigger', 'condOff': False, 'responseOn': 'trigger', 'condOn': False, 'timeOut': u'', 'actionOn': 648352520, 'selfOff': 'No'}}
Group Trigger Debug Finished variable processing:
On dict is: {648352520: [u'1036850980', u'587771681', u'370948314', u'1337008962', u'667800221', u'1192603301', u'1172733019', u'1419308057', u'436775088', u'168875380', u'1556965903', u'1575511318', u'1179951223', u'244177793', u'442776527']}
Off dict is: {648352520: [u'1036850980', u'587771681', u'370948314', u'1337008962', u'667800221', u'1192603301', u'1172733019', u'1419308057', u'436775088', u'168875380', u'1556965903', u'1575511318', u'1179951223', u'244177793', u'442776527']}
Group Triggers Plugin processing enabled for group trigger Group Motion
Group Trigger Error exception in triggerStartProcessing(Group Motion): 'key saveToVarON not found in dict'
terrydew wrote:updated to new release and got the following
- Code: Select all
berkinet wrote:Beta 0.9.15 is now available on dropbox
This release adds an option to save the name of the triggering variable or device to an Indigo variable. This can be specified independently for the On and Off trigger events. The Indigo variable name(s) can be set by the user.
DU Lou wrote:...When I click on the link to get the plugin I get this instead:
berkinet wrote:DU Lou wrote:...When I click on the link to get the plugin I get this instead:
I have checked the Dropbox link and it is working.
This sounds like a Windows virus. Are you trying the download on a Mac?
If so, possibly you are you running the Nginx web server as a proxy and have a configuration problem.
ckeyes888 wrote:...can Group Trigger check for any change to a group of variables?...
hamw wrote:Just to ask, why is it not possible to trigger on an arbitrary change, for instance a variable changing from "Playing" to "Paused"?
ckeyes888 wrote:...I am a bit curious how the app itself can trigger on any change to a variable, but the plugin can't. To the layman it would seem all the plugin would have to do is execute the action. ...
Users browsing this forum: No registered users and 17 guests
