Plugin requests
Plugin requests
[MODERATOR NOTE]: moved to the correct forum
Are there substitutes/updates for EPS super conditions&device extensions, ring, network devices, and smartphone radar plugins?
Re: Having issue with Indigo reflector since updating to Sequoia
It's hard to answer a question like that because it's not clear how you might use the various plugins in your setup.
Any plugin authored by Colorado4Wheeler [Homebridge Buddy, Device Extensions Plugin, HomeKit Bridge, LCD Creator, Other Indigo Bits and Bytes, Room-O-Matic, Scene Toggle, Super Conditions (IF-THEN-ELSE)] -- none of those plugins are supported any longer because the developer of those plugins has left the platform. That developer's license terms and code base are such that other developers are unable to take over their development. These are all considered EOL.
There are several other options for Smartphone Radar depending on your equipment and what you want to do.
I'm not familiar with the Ring and Network Devices plugins, but Network Devices has an open license, so you might be able to find someone willing to take a crack at updating it.
Hi Dave,DaveL17 wrote: ↑Tue Oct 01, 2024 5:57 amIt's hard to answer a question like that because it's not clear how you might use the various plugins in your setup.
Yeah figured as much - such a shame as half my dashboard is developed with if this then that features to open up options that are limited in the user interface...such, such a shame!
Smartphone radar I think that I can reproduce with possible unifi plugin, and network devices is just for a ping of phones as confirmatory secondary pieces of info for phones presence. the ring plugin I think was beneficial, but not going to be able to work any longer as that creator appears to have left the platform too. Homekit Bridge sucks to lose too, but oh well!
Thank you,
Daniel
Hi @Jay, @Matt, @Dave, is there another plugin that does pings? Also is there another plugin that allows for changing through options on a device like super conditions opened up?
Sorry to say that those aren't features I use, so I'm not familiar enough with what's out there to have an opinion. In cases where I need complex logic for something, I'll write a Python script to take care of it.
I did want to mention that there is a supported plugin for HomeKit available.
- jay (support)
- Site Admin
- Contact:
You don't need a plugin, just use a script (use this as a base):
import os
hostname = "google.com" # insert your url here
response = os.system(f"ping -c 1 {hostname}")
#and then check the response...
if response == 0:
print(f"{hostname} is up!")
print(f"{hostname} is down!")
I've never used that plugin, and I would need more clarity on the request to comment.
Re: Plugin requests
Hi Jay,
Nice I'll implement the script...the super conditions does if-then-else routines and is a choice in the server action on click in control page to have the decision of intelligent toggle and knows what the device state is and changes it to the next.
- Screenshot 2024-10-01 at 8.57.18 PM.png (70.8 KiB) Viewed 446 times
Excuse my ignorance:jay (support) wrote: ↑Tue Oct 01, 2024 8:38 pm
import os hostname = "google.com" # insert your url here response = os.system(f"ping -c 1 {hostname}") #and then check the response... if response == 0: print(f"{hostname} is up!") else: print(f"{hostname} is down!")
Can you run that script from an Action Group to PING a URL?
Where do you see the UP/DOWN response?
Can it continue to PING until you get an UP response?
Is it possible for the response to populate a variable?
Re: Plugin requests
You can, but it will need some modifications tailored to what you want to do. See below. You would run it under Server Actions > Script and File Actions > Execute Script.
I've modified the script to print the up/down response to the Indigo events log and save the result to a variable.
That would require more extensive changes to the script below (which is set to try one attempt), but I'd recommend against doing what you suggest. Rather, I'd suggest setting up the script to run on some sort of timer or schedule to keep from tying up resources.
Sure. I've added an example to the script.
One other note, depending on your environment, it may be necessary to point directly to the `ping` command when using this script from within the Indigo scripting environment. I've modified the script to point to `/sbin/ping` which should work for you.
import os
hostname = "google.com" # insert your IP or hostname here
response = os.system(f"/sbin/ping -c 1 {hostname}")
# and then check the response...
if response == 0:
indigo.server.log(f"{hostname} is up!")
indigo.variable.updateValue(12345678, 'Up!') # replace with your variable id.
indigo.server.log(f"{hostname} is down!")
indigo.variable.updateValue(12345678, 'Down!') # replace with your variable id.
- FlyingDiver
Re: Plugin requests
Nit on the comment in line 2 - the ping command requires a hostname or IP address, not a URL or URI. I think this script originally used a URL with the requests library, and the comment didn't get changed.
But.... Some Internet sites block responses to ping commands because they're sometimes used in DDOS attacks. So an actual HTTPS get with a URL is probably more reliable for testing those kinds of sites. OP doesn't state what he actually is targeting with this check.
Re: Plugin requests
PERFECT! Thank You DaveL17DaveL17 wrote: ↑Wed Oct 02, 2024 6:23 amYou can, but it will need some modifications tailored to what you want to do. See below. You would run it under Server Actions > Script and File Actions > Execute Script.
import os hostname = "google.com" # insert your IP or hostname here response = os.system(f"/sbin/ping -c 1 {hostname}") # and then check the response... if response == 0: indigo.server.log(f"{hostname} is up!") indigo.variable.updateValue(12345678, 'Up!') # replace with your variable id. else: indigo.server.log(f"{hostname} is down!") indigo.variable.updateValue(12345678, 'Down!') # replace with your variable id.
Re: Plugin requests
Thank you, Craig and Dave!!
I was trying to replace smartphone radar with Unifi, but boy I had no luck trying to get that configured!! That's a beast of a config + I have a UCG Max and not entirely sure how to adjust accordingly.
Re: Plugin requests
You can try fingscan. That supports pinging external sites.
Re: Plugin requests
Hahah, I've already got fingscan doing a job for presence detection in the same routine for robustness - was hoping for a different one to achieve and replace specifically smartphone radar! Thanks though KW!!
Re: Plugin requests
Fingscan uses the same fing exe as Smartphone Radar I believe
