Moving from Intel to M1 Mini.
BenHM4590
Post by BenHM4590 »
Greetings,
I've relocated my Indigo server from an Intel mac mini to an M1. HomeKitLink Siri won't start or install. I received these errors in attempting to restart the old install:
HomeKitLink Siri Error          Error in plugin execution InitializeMain:
  File "plugin.py", line 48, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/accessory_driver.py", line 31, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/zeroconf/__init__.py", line 25, in <module>
type: dlopen(/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/zeroconf/_cache.cpython-311-darwin.so, 0x0002): tried: '/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/zeroconf/_cache.cpython-311-darwin.so' (mach-o file, but is an incompatible architecture (have 'x86_64', need 'arm64e' or 'arm64')), '/System/Volumes/Preboot/Cryptexes/OS/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/zeroconf/_cache.cpython-311-darwin.so' (no such file), '/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/zeroconf/_cache.cpython-311-darwin.so' (mach-o file, but is an incompatible architecture (have 'x86_64', need 'arm64e' or 'arm64'))
   Stopping plugin "HomeKitLink Siri 0.6.61" (pid 71229)
Thinking a fresh install might review the requirements and fix it, I did that. With no success. Thinking maybe I needed XCode, I've installed that and tried a 2nd fresh install. It failed with the following MASSIVE log:
Sep 9, 2024 at 8:19:57 PM
   Error                           Requirements file for "HomeKitLink Siri 0.6.61" failed to process correctly, contact the developer with the following information:
   Error                             error: subprocess-exited-with-error
  × Building wheel for zeroconf (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [347 lines of output]
      A setup.py file already exists. Using it.
      warning: src/zeroconf/_cache.py:47:23: Unknown type declaration '_DNSRecordCacheType' in annotation, ignoring
      warning: src/zeroconf/_cache.py:47:49: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_cache.py:47:63: Unknown type declaration '_DNSRecord' in annotation, ignoring
      warning: src/zeroconf/_cache.py:67:33: Unknown type declaration '_DNSRecord' in annotation, ignoring
      warning: src/zeroconf/_cache.py:100:36: Unknown type declaration '_DNSRecord' in annotation, ignoring
      warning: src/zeroconf/_cache.py:117:32: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_cache.py:126:38: Unknown type declaration '_UniqueRecordsType' in annotation, ignoring
      warning: src/zeroconf/_cache.py:138:41: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_cache.py:138:54: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:138:68: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:184:47: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:184:61: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:205:51: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:205:65: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_cache.py:237:93: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:76:33: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_dns.py:119:31: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:191:43: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_dns.py:197:37: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:202:30: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:206:28: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:210:29: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:219:39: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_dns.py:255:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:300:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:346:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:380:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:429:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:480:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_dns.py:552:33: Unknown type declaration '_DNSRecord' in annotation, ignoring
      warning: src/zeroconf/_dns.py:224:25: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_handlers/answers.py:82:50: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/answers.py:90:13: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/answers.py:90:96: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_handlers/answers.py:102:56: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:67:29: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:67:46: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/multicast_outgoing_queue.py:89:50: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:118:48: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:129:51: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:134:51: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:206:44: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:220:55: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:238:20: Unknown type declaration '_AnswerWithAdditionalsType' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:240:15: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:267:23: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:403:14: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:404:14: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_handlers/query_handler.py:405:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
      warning: src/zeroconf/_handlers/record_manager.py:51:33: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_history.py:41:63: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_history.py:45:53: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_history.py:67:32: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_listener.py:87:20: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/zeroconf/_listener.py:109:18: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_listener.py:110:13: Unknown type declaration '_float' in annotation, ignoring
      warning: src/zeroconf/_listener.py:111:14: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/zeroconf/_listener.py:189:14: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_listener.py:190:14: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_listener.py:191:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
      warning: src/zeroconf/_listener.py:214:48: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_listener.py:222:14: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_listener.py:223:14: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_listener.py:224:19: Unknown type declaration '_WrappedTransport' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:262:35: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:22: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:35: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:49: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:60: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:305:74: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:362:32: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/incoming.py:394:44: Unknown type declaration '_int' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:152:67: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:200:33: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:205:32: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:209:44: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:213:36: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:213:49: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:217:33: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:232:34: Unknown type declaration 'bytes_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:239:28: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:257:31: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:300:41: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:306:40: Unknown type declaration 'DNSQuestion_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:323:33: Unknown type declaration 'DNSRecord_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:323:50: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:327:36: Unknown type declaration 'DNSRecord_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:327:53: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:349:63: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:349:81: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:368:61: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:376:56: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:384:79: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:393:32: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:393:53: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:393:77: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_protocol/outgoing.py:393:102: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/__init__.py:69:64: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/__init__.py:73:66: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/browser.py:189:39: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:212:16: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:212:35: Unknown type declaration 'bool_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:212:71: Unknown type declaration '_QuestionWithKnownAnswers' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:250:16: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:378:55: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:378:84: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:417:53: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:417:84: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:513:47: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:628:22: Unknown type declaration 'ServiceStateChange' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:629:15: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:630:14: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:645:56: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/browser.py:147:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/browser.py:153:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/browser.py:165:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/browser.py:171:28: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/info.py:304:44: Unknown type declaration 'IPVersion' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:323:23: Unknown type declaration 'IPVersion' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:336:29: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:442:35: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:442:49: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:455:66: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:464:66: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:473:56: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:485:81: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:573:17: Unknown type declaration 'IPVersion' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:704:77: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:731:52: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:861:13: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:862:14: Unknown type declaration 'str_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:863:15: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:864:16: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:885:35: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:885:58: Unknown type declaration 'DNSQuestionType' in annotation, ignoring
      warning: src/zeroconf/_services/info.py:107:42: Strings should no longer be used for type declarations. Use 'cython.int' etc. directly.
      warning: src/zeroconf/_services/registry.py:82:65: Unknown type declaration '_str' in annotation, ignoring
      warning: src/zeroconf/_updates.py:52:56: Unknown type declaration 'float_' in annotation, ignoring
      warning: src/zeroconf/_utils/ipaddress.py:112:43: Unknown type declaration 'bytes_' in annotation, ignoring
      warning: src/zeroconf/_utils/ipaddress.py:112:58: Unknown type declaration 'int_' in annotation, ignoring
      warning: src/zeroconf/_utils/time.py:40:30: Unknown type declaration '_float' in annotation, ignoring
      Compiling src/zeroconf/_dns.py because it changed.
      Compiling src/zeroconf/_cache.py because it changed.
      Compiling src/zeroconf/_history.py because it changed.
      Compiling src/zeroconf/_record_update.py because it changed.
      Compiling src/zeroconf/_listener.py because it changed.
      Compiling src/zeroconf/_protocol/incoming.py because it changed.
      Compiling src/zeroconf/_protocol/outgoing.py because it changed.
      Compiling src/zeroconf/_handlers/answers.py because it changed.
      Compiling src/zeroconf/_handlers/record_manager.py because it changed.
      Compiling src/zeroconf/_handlers/multicast_outgoing_queue.py because it changed.
      Compiling src/zeroconf/_handlers/query_handler.py because it changed.
      Compiling src/zeroconf/_services/__init__.py because it changed.
      Compiling src/zeroconf/_services/browser.py because it changed.
      Compiling src/zeroconf/_services/info.py because it changed.
      Compiling src/zeroconf/_services/registry.py because it changed.
      Compiling src/zeroconf/_updates.py because it changed.
      Compiling src/zeroconf/_utils/ipaddress.py because it changed.
      Compiling src/zeroconf/_utils/time.py because it changed.
      [ 1/18] Cythonizing src/zeroconf/_cache.py
      [ 2/18] Cythonizing src/zeroconf/_dns.py
      [ 3/18] Cythonizing src/zeroconf/_handlers/answers.py
      [ 4/18] Cythonizing src/zeroconf/_handlers/multicast_outgoing_queue.py
      [ 5/18] Cythonizing src/zeroconf/_handlers/query_handler.py
      [ 6/18] Cythonizing src/zeroconf/_handlers/record_manager.py
      [ 7/18] Cythonizing src/zeroconf/_history.py
      [ 8/18] Cythonizing src/zeroconf/_listener.py
      [ 9/18] Cythonizing src/zeroconf/_protocol/incoming.py
      [10/18] Cythonizing src/zeroconf/_protocol/outgoing.py
      [11/18] Cythonizing src/zeroconf/_record_update.py
      [12/18] Cythonizing src/zeroconf/_services/__init__.py
      [13/18] Cythonizing src/zeroconf/_services/browser.py
      [14/18] Cythonizing src/zeroconf/_services/info.py
      [15/18] Cythonizing src/zeroconf/_services/registry.py
      [16/18] Cythonizing src/zeroconf/_updates.py
      [17/18] Cythonizing src/zeroconf/_utils/ipaddress.py
      [18/18] Cythonizing src/zeroconf/_utils/time.py
      running build
      running build_py
      creating /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build
      creating /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311
      creating /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_record_update.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_cache.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/asyncio.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_updates.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/__init__.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_engine.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_transport.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_core.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_logger.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_listener.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_exceptions.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_history.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/const.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_dns.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      creating /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/multicast_outgoing_queue.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/record_manager.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/__init__.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/query_handler.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/answers.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      creating /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_protocol/outgoing.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_protocol/__init__.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_protocol/incoming.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      creating /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/registry.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/__init__.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/types.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/browser.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/info.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      creating /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/time.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/ipaddress.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/asyncio.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/net.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/__init__.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/name.py -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/py.typed -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_dns.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_updates.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_record_update.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_cache.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_history.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_listener.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf
      copying src/zeroconf/_handlers/answers.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/record_manager.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/multicast_outgoing_queue.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_handlers/query_handler.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_handlers
      copying src/zeroconf/_protocol/outgoing.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_protocol/incoming.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_protocol
      copying src/zeroconf/_services/browser.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/__init__.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/registry.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_services/info.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_services
      copying src/zeroconf/_utils/ipaddress.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      copying src/zeroconf/_utils/time.pxd -> /private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311/zeroconf/_utils
      running build_ext
        File "/private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/setup.py", line 43, in <module>
          setup(**setup_kwargs)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 117, in setup
          return distutils.core.setup(**attrs)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 184, in setup
          return run_commands(dist)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 200, in run_commands
          dist.run_commands()
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 954, in run_commands
          self.run_command(cmd)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 950, in run_command
          super().run_command(command)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 973, in run_command
          cmd_obj.run()
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 135, in run
          self.run_command(cmd_name)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 316, in run_command
          self.distribution.run_command(command)
          cmd_obj.run()
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 329, in run
          customize_compiler(self.compiler)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 299, in customize_compiler
          _customize_macos()
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 285, in _customize_macos
          sys.platform == "darwin" and __import__('_osx_support').customize_compiler(
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 488, in customize_compiler
          _find_appropriate_compiler(_config_vars)
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 244, in _find_appropriate_compiler
          raise SystemError(
      SystemError: Cannot locate working compiler
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
          main()
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
          return _build_backend().build_wheel(wheel_directory, config_settings,
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
          return WheelBuilder.make_in(
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 88, in make_in
          wb.build(target_dir=directory)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 121, in build
          self._build(zip_file)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 182, in _build
          self._run_build_command(setup)
        File "/private/tmp/pip-build-env-igyrl8yt/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 248, in _run_build_command
          subprocess.check_call([
        File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/subprocess.py", line 413, in check_call
          raise CalledProcessError(retcode, cmd)
      subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/setup.py', 'build', '-b', '/private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build', '--build-purelib', '/private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib', '--build-platlib', '/private/tmp/pip-install-0rpdprki/zeroconf_333ee33c88a543b094c7a13eb26768ce/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for zeroconf
  × Building wheel for chacha20poly1305-reuseable (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [90 lines of output]
      warning: src/chacha20poly1305_reuseable/__init__.py:50:57: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:105:14: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:139:14: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:164:72: Unknown type declaration '_int' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:178:17: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:178:67: Unknown type declaration '_int' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:178:84: Unknown type declaration '_int' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:219:47: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:225:37: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:237:10: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:238:21: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:244:37: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:244:62: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:261:10: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:262:21: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:275:37: Unknown type declaration '_bytes' in annotation, ignoring
      warning: src/chacha20poly1305_reuseable/__init__.py:275:62: Unknown type declaration '_bytes' in annotation, ignoring
      Compiling src/chacha20poly1305_reuseable/__init__.py because it changed.
      [1/1] Cythonizing src/chacha20poly1305_reuseable/__init__.py
      running build
      running build_py
      creating /private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build
      creating /private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build/lib.macosx-10.9-universal2-cpython-311
      creating /private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
      copying src/chacha20poly1305_reuseable/__init__.py -> /private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
      copying src/chacha20poly1305_reuseable/py.typed -> /private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
      copying src/chacha20poly1305_reuseable/__init__.pxd -> /private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
      running build_ext
        File "/private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/setup.py", line 35, in <module>
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 117, in setup
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 184, in setup
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 200, in run_commands
          dist.run_commands()
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 954, in run_commands
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 950, in run_command
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 973, in run_command
          cmd_obj.run()
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 135, in run
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 316, in run_command
          cmd_obj.run()
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 329, in run
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 299, in customize_compiler
          _customize_macos()
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 285, in _customize_macos
          raise SystemError(
          main()
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 88, in make_in
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 121, in build
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 182, in _build
        File "/private/tmp/pip-build-env-_rcbwf3z/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 248, in _run_build_command
      subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/setup.py', 'build', '-b', '/private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build', '--build-purelib', '/private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build/lib', '--build-platlib', '/private/tmp/pip-install-0rpdprki/chacha20poly1305-reuseable_74daaa3bae5a4a93bfb97a70a40165c9/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
      [end of output]
  ERROR: Failed building wheel for chacha20poly1305-reuseable
ERROR: Could not build wheels for zeroconf, chacha20poly1305-reuseable, which is required to install pyproject.toml-based projects
  File "plugin.py", line 21, in <module>
type: No module named 'ifaddr'
   Stopping plugin "HomeKitLink Siri 0.6.61" (pid 72507)
   Stopped plugin "HomeKitLink Siri 0.6.61"
I've now tried a THIRD time, deleting the old HKLS* device, and the same error and 347+ lines of logging.
Any help to getting HKLS working would be appreciated.
Thanks for reading,
Ben
*It would've been nice to preserve the insane number of person-hours spent getting HKLS loaded, device labels and rooms all nice etc. But now I've resolved that I'm just going to have to do all that stuff over again.
GlennNZ
Re: Moving from Intel to M1 Mini.
Post by GlennNZ »
Thats annoying.
Its hard to completely follow the log and your comments in it (if put logging in code blocks makes it more readable - have edited it now). But think have worked through - saw the x-code comment - but need xcode tools specifically
It will likely relate to the lack of x-code tools on the new install - there is a troubleshooting post here regarding.
viewtopic.php?t=27750
Not sure you can recover, from deleting the device - but if have a backup? Might be recoverable. If no backup, could setup new bridge and transfer devices over - will still need setup in home as will appear as you bridge though.
Essentially covered in the link above.
Likely will need to reinstall the plugin bundle - by double clicking - same version is fine (as this remove the library directions) after reviewed the above steps and installed xcode tools.
BenHM4590
Post by BenHM4590 »
Thank you Glenn, installing the Xcode command line tools fixed the problem.
[i]Sep 10, 2024 at 4:55:52 PM
   Installing plugin HomeKitLink Siri v0.6.61 (previous version 0.6.61 moved to trash)
   Loading plugin "HomeKitLink Siri 0.6.61" using API v3.4
   Starting plugin "HomeKitLink Siri 0.6.61" (pid 35446)
   Processing requirements for plugin "HomeKitLink Siri 0.6.61"
   Requirements installing, this may take a few seconds...[/i]
Perhaps both Xcode and XCLT needs to be added, or pulled out to a pre-install checklist?
Now I cannot add any devices to be published, it says all 39 are already published. They appear greyed-out when I attempt to publish them to the new device.
Yes, I have months of backups, if I knew exactly what to take out from the Intel Mini install, I could put it in this new M1 Mini installation. Provided we don't crash into the Intel/Arm software problem.
Regards,
Ben
[i]Sep 10, 2024 at 4:56:13 PM
   Finished installing requirements for "HomeKitLink Siri 0.6.61", continuing startup
   HomeKitLink Siri
   HomeKitLink Siri                ================================================ Initializing New Plugin Session =================================================
   HomeKitLink Siri                Plugin name:                   HomeKitLink Siri
   HomeKitLink Siri                Plugin version:                0.6.61
   HomeKitLink Siri                Plugin ID:                     com.GlennNZ.indigoplugin.HomeKitLink-Siri
   HomeKitLink Siri                Indigo version:                2023.2.0
   HomeKitLink Siri                Silicon version:               arm64
   HomeKitLink Siri                Python version:                3.11.6 (v3.11.6:8b6ee5ba3b, Oct  2 2023, 11:18:21) [Clang 13.0.0 (clang-1300.0.29.30)]
   HomeKitLink Siri                Python Directory:              /Library/Frameworks/Python.framework/Versions/3.11
   HomeKitLink Siri                FFmpeg :                       /Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/homekitlink_ffmpeg/ffmpeg_binaries/arm/ffmpeg
   HomeKitLink Siri
   HomeKitLink Siri                ================================================== End Initializing New Plugin  ==================================================
   Started plugin "HomeKitLink Siri 0.6.61"
   HomeKitLink Siri                Finding devices to publish to HomeKit Given Startup...
   HomeKitLink Siri               [b] A total of 39 devices are currently selected to be published to HomeKit[/b]
   HomeKitLink Siri                0 Home Kit Accessories are now Started.
   HomeKitLink Siri                Given this difference, please review devices by Menu Item, Show Device Publications & Identity Devices Running for more information.[/i]
GlennNZ
Post by GlennNZ »
re: Command line tools - depends on the system and that is why that sticky is there!
The issue is you deleting the Indigo Bridge device. If that still existed all would be well.
The issue you are seeing here is because of that deleted bridge.
You need to delete orphaned devices - that is covered in the 'manual' and is a menuitem - the name of which escapes me - something like "Unlink any Orphaned devices"
Here:
That will enable you to transfer those devices to another bridge - removing the link to current manually deleted bridge.
Alternatively you could transfer them all to a new bridge - that would simply slightly - but they still would be new in the Home app.
If you have NOT deleted anything from the Home App (on iOS) you could potentially recover by using a backup of your Indigo Database and running again. (thus restoring the deleted HomeKitLink Bridge device)
Although thinking on it you will need the Home security key exchange pairs for a going connection. I believe they are in plugin Prefs folder.
So for good measure would restore the whole Indigo directory.
I'll double check file locations when can - as away from any installs currently and can't check
Glenn
BenHM4590 wrote: Tue Sep 10, 2024 4:07 pm Thank you Glenn, installing the Xcode command line tools fixed the problem.
Regards,
Ben
Return to “HomeKitLink Siri”
