Plug-in Evohome seems to work but after about 30seconds it stops working
Mirko
Post by Mirko »
Hi!
I have installed the Evohome plug-in.
My Evohome system has 3 locations in the same building.
I made devices with the ID's according to the numbers appearing in the log.
When I hit the button 'Initialise Evohome devices' the devices turn from red to black, show their temperature and after ±30 sec turn red again.
I cannot get them working
Can you help me out? Thanks a lot.
Regards
Mirko
Enabling plugin "Evohome 2023.0.2" using API v3.0
Starting plugin "Evohome 2023.0.2" (pid 15416)
Started plugin "Evohome 2023.0.2"
Evohome [Tue Sep 3 14:53:57 2024] Processed plugin preferences.
Evohome Debug Starting Evohome......
Evohome Debug Refresh token expires [2024-09-03 15:23:57.326059]
Evohome [Tue Sep 3 14:54:10 2024] Authenticated to Evohome API (Initial Call).
Evohome Initializing thermostat device: EVO Loc: 0 Bgg Ateliers
Evohome Debug [Tue Sep 3 14:54:17 2024] Authenticated to Evohome API (refresh call) with token expiring 2024-09-03 15:23:57.326059.
Evohome Initializing thermostat device: Evohome Controller
Evohome Debug [Tue Sep 3 14:54:23 2024] Authenticated to Evohome API (refresh call) with token expiring 2024-09-03 15:23:57.326059.
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome Schilderatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome Schilderatelier, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome Werkplaats, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome Werkplaats, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome TuinhuisBinnen, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome TuinhuisBinnen, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome TuinhuisBuiten, field: setpointHeat
Evohome Debug Updating Device: Evohome TuinhuisBuiten, State: setpointMode, Value: TemporaryOverride
Evohome Debug Updating Device: Evohome TuinhuisBuiten, State: hvacOperationMode, Value: Heat
Evohome Debug Updating Device: Evohome TuinhuisBuiten, State: setpointUntil, Value: 14:22
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome TuinhuisBuiten, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome VSE, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome VSE, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome VSE gang, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome VSE gang, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome Keramiekatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:24 2024] No value found for device: Evohome Keramiekatelier, field: temperatureStatus
Evohome Debug Starting device: EVO Con: 0 Bgg Ateliers [1670868]
Evohome Debug Starting device: EVO Loc: 0 Bgg Ateliers
Evohome Debug Starting device: Evohome Controller
Evohome Debug Starting device: Evohome Keramiekatelier
Evohome Debug Starting device: Evohome Schilderatelier
Evohome Debug Starting device: Evohome TuinhuisBinnen
Evohome Debug Starting device: Evohome TuinhuisBuiten
Evohome Debug Starting device: Evohome VSE
Evohome Debug Starting device: Evohome VSE gang
Evohome Debug Starting device: Evohome Werkplaats
Evohome Debug Method: runConcurrentThread
Evohome Debug Running Concurrent Thread
Evohome Debug [Tue Sep 3 14:54:27 2024] Authenticated to Evohome API (refresh call) with token expiring 2024-09-03 15:23:57.326059.
Evohome Debug Updating Device: Evohome Schilderatelier, State: maxHeatSetpoint, Value: 35.0
Evohome Debug Updating Device: Evohome Schilderatelier, State: minHeatSetpoint, Value: 5.0
Evohome Debug Updating Device: Evohome Werkplaats, State: maxHeatSetpoint, Value: 35.0
Evohome Debug Updating Device: Evohome Werkplaats, State: minHeatSetpoint, Value: 5.0
Evohome Debug Updating Device: Evohome TuinhuisBinnen, State: maxHeatSetpoint, Value: 35.0
Evohome Debug Updating Device: Evohome TuinhuisBinnen, State: minHeatSetpoint, Value: 5.0
Evohome Debug Updating Device: Evohome TuinhuisBuiten, State: maxHeatSetpoint, Value: 35.0
Evohome Debug Updating Device: Evohome TuinhuisBuiten, State: minHeatSetpoint, Value: 5.0
Evohome Debug Updating Device: Evohome VSE, State: maxHeatSetpoint, Value: 35.0
Evohome Debug Updating Device: Evohome VSE, State: minHeatSetpoint, Value: 5.0
Evohome Debug Updating Device: Evohome VSE gang, State: maxHeatSetpoint, Value: 35.0
Evohome Debug Updating Device: Evohome VSE gang, State: minHeatSetpoint, Value: 5.0
Evohome Debug Updating Device: Evohome Keramiekatelier, State: maxHeatSetpoint, Value: 35.0
Evohome Debug Updating Device: Evohome Keramiekatelier, State: minHeatSetpoint, Value: 5.0
Evohome Debug [Tue Sep 3 14:54:57 2024] Authenticated to Evohome API (refresh call) with token expiring 2024-09-03 15:23:57.326059.
Evohome Debug Updating Device: Evohome Schilderatelier, State: temperatureInput1, Value: 25.0
Evohome Error [Tue Sep 3 14:54:57 2024] No value found for device: Evohome Schilderatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:57 2024] No value found for device: Evohome Schilderatelier, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:57 2024] No value found for device: Evohome Werkplaats, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:57 2024] No value found for device: Evohome Werkplaats, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:57 2024] No value found for device: Evohome TuinhuisBinnen, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:57 2024] No value found for device: Evohome TuinhuisBinnen, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:57 2024] No value found for device: Evohome TuinhuisBuiten, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:57 2024] No value found for device: Evohome TuinhuisBuiten, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome VSE, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome VSE, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome VSE gang, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome VSE gang, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome Keramiekatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome Keramiekatelier, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome Schilderatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome Schilderatelier, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome Werkplaats, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome Werkplaats, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome TuinhuisBinnen, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome TuinhuisBinnen, field: temperatureStatus
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome TuinhuisBuiten, field: setpointHeat
Evohome Error [Tue Sep 3 14:54:58 2024] No value found for device: Evohome TuinhuisBuiten, field: temperatureStatus
Evohome Debug [Tue Sep 3 14:55:31 2024] Authenticated to Evohome API (refresh call) with token expiring 2024-09-03 15:23:57.326059.
Evohome Debug Updating Device: Evohome Schilderatelier, State: temperatureInput1, Value: 25.5
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome Schilderatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome Schilderatelier, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome Werkplaats, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome Werkplaats, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome TuinhuisBinnen, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome TuinhuisBinnen, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome TuinhuisBuiten, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome TuinhuisBuiten, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome VSE, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome VSE, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome VSE gang, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome VSE gang, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome Keramiekatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:31 2024] No value found for device: Evohome Keramiekatelier, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome Schilderatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome Schilderatelier, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome Werkplaats, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome Werkplaats, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome TuinhuisBinnen, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome TuinhuisBinnen, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome TuinhuisBuiten, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome TuinhuisBuiten, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome VSE, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome VSE, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome VSE gang, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome VSE gang, field: temperatureStatus
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome Keramiekatelier, field: setpointHeat
Evohome Error [Tue Sep 3 14:55:32 2024] No value found for device: Evohome Keramiekatelier, field: temperatureStatus
Mirko
Re: Plug-in Evohome seems to work but after about 30seconds it stops working
Post by Mirko »
Tonight I got this log file:
Evohome Error Error in plugin execution MenuAction:
File "plugin.py", line 79, in createEvohomeDevices
File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/Honeywell_Evohome.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 718, in createEvohomeDevices
File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/Honeywell_Evohome.indigoPlugin/Contents/Server Plugin/evohomeclient2/__init__.py", line 310, in temperatures
File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/Honeywell_Evohome.indigoPlugin/Contents/Server Plugin/evohomeclient2/__init__.py", line 212, in _get_single_heating_system
type: More (or less) than one location available
Return to “Honeywell Evohome”
