Event log errors for Smart Thermostat Enhanced model
Wed Mar 13, 2024 4:44 pm
SMUSEBY offline
Every 3 minutes, the event log shows:
Error device "2 uHall Thermostat" state key latestEventType not defined (ignoring update request)
Error device "2 uHall Thermostat" state key climate not defined (ignoring update request)
Error device "2 uHall Thermostat" state key hvacMode not defined (ignoring update request)
Error device "2 uHall Thermostat" state key fanMinOnTime not defined (ignoring update request)
Error device "2 uHall Thermostat" state key equipmentStatus not defined (ignoring update request)
Error device "2 uHall Thermostat" state key device_type not defined (ignoring update request)
Related, I'm writing a script to set a mode (in an AG) and would like to test the temperature.
The script fails at the fist line below - because of the errors above and/or the code itself.:
dev = indigo.devices[1105581528] #uHall stat
uHallTemp = int(dev.states["temperature"])
Wed Mar 13, 2024 4:50 pm
Re: Event log errors for Smart Thermostat Enhanced model
Delete and re-create the thermostat that's causing the errors.
"temperature" is not a state of a thermostat. It's either "temperatureInput1" or "temperatureInput2" depending on which value you want. Right click on the device and print the device details to the log. Then you can see all the states and properties.
Wed Mar 13, 2024 5:09 pm
SMUSEBY offline
I'll delete it - but when I first mentioned this new model to you, I did delete it and reinstall it - and it fixed those error messages. I have no idea why or when they restarted. I'll keep an eye out.
Wed Mar 13, 2024 5:16 pm
SMUSEBY offline
Reinstalled - same errors:
Mar 13, 2024 at 4:16:08 PM
Error device "Ecobee Upstairs" state key latestEventType not defined (ignoring update request)
Error device "Ecobee Upstairs" state key climate not defined (ignoring update request)
Error device "Ecobee Upstairs" state key hvacMode not defined (ignoring update request)
Error device "Ecobee Upstairs" state key fanMinOnTime not defined (ignoring update request)
Error device "Ecobee Upstairs" state key equipmentStatus not defined (ignoring update request)
Error device "Ecobee Upstairs" state key device_type not defined (ignoring update request)
Wed Mar 13, 2024 5:58 pm
Right click on that device and post the device details.
Wed Mar 13, 2024 6:00 pm
Also post the device data from the plugin menu.
Wed Mar 13, 2024 6:17 pm
SMUSEBY offline
I have two: the troublesome one is 560770749; the other is 1716992129. The account is '519.
The troublesome one has climates 2 AMa, 2 AMb, 2 PMa and 2 PMb
Mar 13, 2024 at 5:10:58 PM
   Ecobee 2                        {
    "421862696561": {
        "actualHumidity": 47,
        "actualTemperature": 698,
        "brand": "ecobee",
        "climates": {
            "away": "Away",
            "home": "Home",
            "sleep": "Sleep",
            "smart1": "2 AMa",
            "smart2": "2 PMa",
            "smart3": "2 AMb",
            "smart4": "2 PMb"
        "currentClimate": "home",
        "desiredCool": 716,
        "desiredFanMode": "auto",
        "desiredHeat": 662,
        "equipmentStatus": "",
        "fanMinOnTime": 5,
        "features": "Home,HomeKit",
        "hvacMode": "heat",
        "internal": {
            "airPressure": "unknown",
            "humidity": "47",
            "occupancy": "true",
            "temperature": "698"
        "latestEventType": "hold",
        "modelNumber": "artemisSmart",
        "name": "Upstairs",
        "remotes": {}
    "521703550260": {
        "actualHumidity": 43,
        "actualTemperature": 682,
        "brand": "ecobee",
        "climates": {
            "away": "Away",
            "home": "Home",
            "sleep": "Sleep",
            "smart1": "1 PMb",
            "smart2": "1 AMa",
            "smart3": "1 PMa",
            "smart4": "1 AMb"
        "currentClimate": "sleep",
        "desiredCool": 716,
        "desiredHeat": 662,
        "fanMinOnTime": 0,
        "hvacMode": "heat",
        "internal": {
            "humidity": "43",
            "occupancy": "false",
            "temperature": "682"
        "modelNumber": "vulcanSmart",
        "name": "Main Floor",
        "remotes": {}
    "521781046633": {
        "actualHumidity": 50,
        "actualTemperature": 470,
        "brand": "ecobee",
        "climates": {
            "away": "Away",
            "home": "Home",
            "sleep": "Sleep",
            "smart1": "EcobeeMin 7C",
            "smart10": "22C",
            "smart11": "WARMUP 18C",
            "smart12": "WARMUP 20C",
            "smart13": "7C",
            "smart2": "10C",
            "smart3": "15C",
            "smart4": "16C",
            "smart5": "17C",
            "smart6": "18C",
            "smart7": "19C",
            "smart8": "20C",
            "smart9": "21C"
        "desiredCool": 790,
        "desiredHeat": 450,
        "fanMinOnTime": 0,
        "hvacMode": "off",
        "internal": {
            "humidity": "50",
            "temperature": "470"
        "name": "Stairs",
        "remotes": {
            "C49X": {
                "name": "Office",
                "temperature": "436",
                "thermostat": "521781046633"
   Ecobee 2                        {
    "C49X": {
        "name": "Office",
Wed Mar 13, 2024 6:30 pm
I don't know what those numbers are. They're not the Ecobee serial numbers, which is what's shown in the device dump you provided. You did NOT provide the device data for either of the Indigo devices you refer to.
Wed Mar 13, 2024 7:17 pm
SMUSEBY offline
The device status request for the first thermostat (the Indigo name is "Ecobee Main Floor":
The device status request for the new thermostat (the indigo name is:Ecobee upstairs"):
Mar 13, 2024 at 6:05:59 PM
From the plug-in menu, I selected "write thermostat data to log. That produced the strange device-like numbers. What item in the plug-in menu should I have selected?
Wed Mar 13, 2024 7:19 pm
Wed Mar 13, 2024 8:32 pm
SMUSEBY offline
I hope this is what you need.
Original device:
Mar 13, 2024 at 7:29:44 PM
   Script                          address : 521703550260
batteryLevel : None
buttonGroupCount : 0
configured : True
coolIsOn : False
coolSetpoint : 23.5
dehumidifierIsOn : False
description :
deviceTypeId : EcobeeThermostat
displayStateId : temperatureInputsAll
displayStateImageSel : HvacOff
displayStateValRaw : 20.1, 20.1
displayStateValUi : 20.1, 20.1
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
fanIsOn : False
fanMode : Auto
folderId : 668415659
     com.flyingdiver.indigoplugin.ecobee : (dict)
          NumHumidityInputs : 1 (integer)
          NumTemperatureInputs : 2 (integer)
          ShowCoolHeatEquipmentStateUI : true (bool)
          account : 1305453519 (integer)
          address : 521703550260 (string)
          device_type : vulcanSmart (string)
          holdType : nextTransition (string)
          occupancy : 30249619 (integer)
heatIsOn : False
heatSetpoint : 20.0
humidities : [46.0]
humiditySensorCount : 1
hvacMode : Off
lastChanged : 2024-03-13 19:27:34
lastSuccessfulComm : 2024-03-13 19:27:34
model : Ecobee Thermostat
name : Ecobee Main Floor
ownerProps : com.flyingdiver.indigoplugin.ecobee : (dict)
pluginId : com.flyingdiver.indigoplugin.ecobee
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     autoAway : no (yes/no bool)
     autoHome : no (yes/no bool)
     climate : sleep (string)
     equipmentStatus :  (string)
     fanMinOnTime : 0 (integer)
     humidityInput1 : 46 (real)
     humidityInputsAll : 46 (string)
     hvacCoolerIsOn : off (on/off bool)
     hvacDehumidifierIsOn : off (on/off bool)
     hvacFanIsOn : off (on/off bool)
     hvacFanMode : 0 (integer)
     hvacFanMode.ui : auto on (string)
     hvacFanModeIsAlwaysOn : false (bool)
     hvacFanModeIsAuto : true (bool)
     hvacHeaterIsOn : off (on/off bool)
     hvacHumidifierIsOn : off (on/off bool)
     hvacMode : off (string)
     hvacOperationMode : 0 (integer)
     hvacOperationMode.ui : all off (string)
     hvacOperationModeIsAuto : false (bool)
     hvacOperationModeIsCool : false (bool)
     hvacOperationModeIsHeat : false (bool)
     hvacOperationModeIsOff : true (bool)
     hvacOperationModeIsProgramAuto : false (bool)
     hvacOperationModeIsProgramCool : false (bool)
     hvacOperationModeIsProgramHeat : false (bool)
     latestEventType : hold (string)
     occupied : no (yes/no bool)
     setpointCool : 23.5 (real)
     setpointCool.ui : 23.5°C (string)
     setpointHeat : 20 (real)
     setpointHeat.ui : 20.0°C (string)
     temperatureInput1 : 20.1 (real)
     temperatureInput1.ui : 20.1°C (string)
     temperatureInput2 : 20.1 (real)
     temperatureInput2.ui : 20.1°C (string)
     temperatureInputsAll : 20.1, 20.1 (string)
subModel : ecobee Smart w/ Voice Control
subType : ecobee Smart w/ Voice Control
supportsAllOff : False
supportsCoolSetpoint : True
supportsHeatSetpoint : True
supportsHvacFanMode : True
supportsHvacOperationMode : True
supportsOnState : False
supportsStatusRequest : True
temperatureSensorCount : 2
temperatures : [20.1, 20.1]
version : None
New Device:
Mar 13, 2024 at 7:30:59 PM
   Script                          address : 421862696561
batteryLevel : None
configured : True
coolIsOn : False
coolSetpoint : 22.0
description :
displayStateValRaw : 20.9
displayStateValUi : 20.9
enabled : True
errorState :
fanIsOn : False
fanMode : Auto
folderId : 751464431
          address : 421862696561 (string)
          device_type : artemisSmart (string)
          holdType : indefinite (string)
heatIsOn : False
heatSetpoint : 19.0
humidities : [47.0]
hvacMode : Off
lastChanged : 2024-03-13 19:30:34
lastSuccessfulComm : 2024-03-13 19:30:34
protocol : Plugin
     humidityInput1 : 47 (real)
     humidityInputsAll : 47 (string)
     setpointCool : 22 (real)
     setpointCool.ui : 22.0°C (string)
     setpointHeat : 19 (real)
     setpointHeat.ui : 19.0°C (string)
     temperatureInput1 : 20.9 (real)
     temperatureInput1.ui : 20.9°C (string)
     temperatureInputsAll : 20.9 (string)
subModel : Unknown
subType : Unknown
temperatureSensorCount : 1
temperatures : [20.9]
version : None
Thu Mar 14, 2024 5:52 am
This looks like you restored from a backup or somehow otherwise regressed to an older version of the plugin and database. Confirm you're running version 2024.1.0 of the plugin.
Thu Mar 14, 2024 3:01 pm
SMUSEBY offline
That's a good catch. I did for a database restore for an unrelated issue (I'm still working on installing the Cedalo Docker for the generic MQTT broker).
I cannot update to the latest version of Indigo without disabling my keyless access system - (I'm working on finding someone to help with that issue).
So in the meantime, I will have to live with the error log issue, and an inability to capture data from the thermostat.
Thank you.
Wed May 29, 2024 2:25 pm
patrick0brien offline
I'm getting the same errors on my new Ecobee Enhanced as well. You mention above to be running the latest. I'm running v2022.1.0, but you mention a "2024.1.0" version. Is there one of that version, or was that a typo?
In the mean time, I can live with the errors (they log every time the the plugin polls the thermostat - 3minutes), I felt my input might be useful if you are doing RCA.
- Never Settle
Wed May 29, 2024 2:50 pm
2024.1.0 is now available in the store.
