Using Zooz dimmers in virtual 3-way setup
Sat Nov 11, 2023 10:35 pm
epounds offline
Going through a remodel and using Zooz dimmer switches in 3 and 4-way configurations. I would like to use 2 or more Zooz dimmers to control a single set of lights, so all switches look and behave the same. Zooz has documentation for doing this, but I cannot figure out how to configure this setup in Indigo. Ideally, I could configure “direct association”, where the dimmers communicate outside of Indigo, but Indigo is aware of what’s going on.
https://www.support.getzooz.com/kb/arti ... lar-bulbs/
Any advise on how to do this would be much appreciated. Thanks!
Sun Nov 12, 2023 1:22 pm
Re: Using Zooz dimmers in virtual 3-way setup
I'm not sure if it will work or not from Indigo, but when trying to do the Direct Associations, what specific steps have you tried? I've always used "regular" switches for secondary switch locations with my Zooz modules, so I don't have experience with the techniques described on that article.
Note to change parameter #7 to value 11, you can use the Interfaces->Z-Wave->Modify Configuration Parameter... menu item.
Likewise, to set the direct associations you should be able to use the Interfaces->Z-Wave->Manage Associations... menu item.
Another approach would be to use the Virtual Interfaces device groups, although there will be some lag especially when manually controlling the brightness at the switches.
Sun Nov 12, 2023 11:08 pm
epounds offline
Thanks Matt. This worked!!! And responsiveness from using the virtual devices is fairly good. Switching is great. Dimming has a little delay.
Then, in the UI, I'm just hiding the virtual devices from the remote display.
