Info on Home Window Header?
Thu Aug 03, 2023 3:07 pm
ckeyes888 offline
Haven’t noticed the info on the Home window header to be anything like this.
Is that the database that’s somehow in use now?
I don’t see a database in the folder with a name like that.
If not what is it?
Edit: The database I assumed I’ve been using is dated July 2022. Shouldn’t the modify date update every 15 mins or so?
Carl
Fri Aug 04, 2023 4:59 am
durosity offline
Re: Info on Home Window Header?
If you command-click the file name at the top of the window it’ll give you the path to exactly where the file is!
Fri Aug 04, 2023 7:49 am
ryanbuckner offline
Can the database name be changed? Somehow a "2" was added to my house name.
Fri Aug 04, 2023 8:34 am
durosity offline
Yeah just shut down your Indigo Server, rename the file, Double Click on it, should work nicely. :)
Fri Aug 04, 2023 8:48 am
This can happen when there is a problem writing to your filesystem (it's the name of a temp file Indigo creates). I'd be a little concerned that there may be an issue with your disk.
Fri Aug 04, 2023 8:58 am
ckeyes888 offline
Uh oh. Thought I’d just save a New Database from what I’m currently running and lost everything.
Hope I can find that temp database. and reload it or I’m rather screwed.
Any way to search for it? I did right click it in the header and it was was in a cache folder called sessions.
Edit: Found the temp database, renamed it and it’s running now but am getting these errors in the log:
WebServer no image URL found for page control 1
WebServer no image URL found for page control 25
Any idea how to correct?
Carl
Fri Aug 04, 2023 5:08 pm
It would be helpful if Indigo's error message there was more verbose... but it isn't.
Try opening different Control Pages to see when the error occurs. Once you find the right CP you can enable the checkbox to edit the Z-order of the controls, which should render ID numbers next to each control. The ones with numbers around 1 or 25 (plus or minus 1 maybe) should be the ones that have have an empty or missing image URL.
Sat Aug 05, 2023 12:17 pm
ryanbuckner offline
Pretty simple. Thanks
Sat Aug 05, 2023 4:03 pm
ckeyes888 offline
Fixed. Thanks a bunch.
Carl
