I used to rely on this functionality, but it looks like it might be dead.
For example, I used to have an app (Locative) fire off http://USER:PWD@ADDRESS:8176/variables/ ... value=true
I read throught he new HTTP instructions, and I cannot tell if this approach can be approximated.
2022.2.2 how to update a variable value in a URL
- jay (support)
- Site Admin
- Contact:
Re: 2022.2.2 how to update a variable value in a URL
Does the Locative app support doing HTTP POST requests? That's what you'll need to use along with the new HTTP API.
- FlyingDiver
Or use the GeoFence plugin, which supports Locative.
Thanks Jay- It DOES have a POST option, I am just uncertain how i package this in a URL encoded line... something maybe like this, but I am in the weeds here:
Hey Joe- I just installed your plugin and took a look at it. Am I correct that I need an account with the GeoFancy web service to use Locative (as opposed to just sending geofencing info directly to my reflector? I looked at the subforum but still wasn't clear on it.
Thanks all
https://mundmc.indigodomo.net//v2/api/indigo.variables.updateValue/VARIABLE_ID?api-key=MY_API_KEY
Thanks all
- FlyingDiver
I don't think so. You just put the URL into the mobile app. Something like:Hey Joe- I just installed your plugin and took a look at it. Am I correct that I need an account with the GeoFancy web service to use Locative (as opposed to just sending geofencing info directly to my reflector? I looked at the subforum but still wasn't clear on it.
https://mmdc.indigodomo.net/message/se.furtenbach.indigo.plugin.beacon/webhook?api_key=<your reflector token>
- jay (support)
- Site Admin
- Contact:
HTTP POST requests can't be completely specified on a URL line, so I'm unclear what you need exactly. Can you post a screenshot from the POST configuration screen in Locative?jay (support) wrote:mundmc wrote:Thanks Jay- It DOES have a POST option, I am just uncertain how i package this in a URL encoded line... something maybe like this, but I am in the weeds here:Code: Select all
When doing a POST, you specify the URL, headers (though that's optional), and a payload that gets posted to the URL.
I think that was what I needed to understand, thank you. I will play with Joe's plugin and see if I can figure this out with his tips.jay (support) wrote:HTTP POST requests can't be completely specified on a URL line, so I'm unclear what you need exactly. Can you post a screenshot from the POST configuration screen in Locative?
