Help needed converting this AppleScript to an action
Tue Feb 07, 2023 2:15 am
pxzel offline
Use to have this AppleScript run and it would have my Insteon outlet to emit a beep 3 times
send Insteon raw cmd1 48 cmd2 5 to address “1A.84.1F”
Recreated three actions each with Insteon send raw cmd to the outlet
CMD 1 byte 0x48
CMD 2 byte 0x05
And it doesn’t emit any beeps. Have I translated it correctly?
Tue Feb 07, 2023 7:36 am
whmoorejr offline
Re: Help needed converting this AppleScript to an action
Untested, but might work....
dev = indigo.devices[someDevIdHere]
devAddr = dev.address
indigo.insteon.sendRaw (devAddr, [0x30, 0x02], waitUntilAck=True) # 2 is duration of the beep
I read somewhere else on the forum that due to an NDA with insteon, some of the stuff they can't disclose. I stole the above from nssheldon https://forums.indigodomo.com/viewtopic.php?t=10226&p=66827
Bill
My Plugin: My People
Tue Feb 07, 2023 10:13 am
pxzel offline
Thanks so much. Works perfectly now.
Yeah, I saw that one thread regarding the command tables and the NDA. Couldn't find any command tables to refer to looking through the forum.
Appreciate your help. I had the beep function work fine for years and after upgrading Indigo last year lost that functionality without Applescript support .
Tue Feb 07, 2023 10:27 am
pxzel offline
Just curious…. Can the volume of the beep be increased any?
Tue Feb 07, 2023 11:39 am
whmoorejr offline
I'm pretty sure no, which is one of the reasons I never used it... In my experience, the beep was always to quiet and my hearing to crappy to notice it.
...I just found this which might be a simpler way to beep the device without sending a raw command. I've never messed with sending raw commands nor have I ever bothered to beep a device beyond just seeing if it works.
indigo.device.beep(123)
indigo.device.beep(devAddr)
In my previous post, however, the code has duration.... so I guess you could arrange quick and long beeps then brush up on your Morris Code :D
Bill
Tue Feb 07, 2023 12:34 pm
pxzel offline
Ha ha! Love the Morse code!
Again, thanks for the info. Glad I’m learning something everyday
