Login Credentials for myQ
tkgiii
Post by tkgiii »
I am having difficulty figuring out what credentials to use for the MyQ server (see attached log)
I am trying to use the credentials for myQ.com, which I have verified, but get that error message. It appears that the plugin is working correctly, as it it trying to create a new device of type myQ
Any advice would be appreciated
Thank you
Screenshot 2023-01-23 at 1.03.39 PM.png (472.97 KiB) Viewed 1656 times
Re: Login Credentials for myQ
Honestly, if you're 100% sure that you have the correct username and password in there, then it's probably MyQ screwing with the API again.
Just be sure you installed the correct version of the pymyq library. It should be 3.1.5.
Locked
Return to “MyQ”
