Announcing GivEnergy Cloud Controller
mwoodage
Re: Announcing GivEnergy Cloud Controller
Post by mwoodage »
No worries, we'll get there eventually :D
neilk
Post by neilk »
Martin,
Somebody kindly on the GivEnergy forum used the same options in the payload I am trying and it worked which is actually even more of a head scratcher. Lets change tack and try the following
Create a new action group for execute a script
Screenshot 2022-11-16 at 21.40.03.png (270.12 KiB) Viewed 2786 times
Choose embedded python, and paste the code below in the window (adding in your API key and Inverter serial number)
Screenshot 2022-11-16 at 21.43.53.png (68.88 KiB) Viewed 2786 times
and click run. You should see the output in the event log, and hopefully we will see something like
{"data":{"0":{"start_time":"2022-11-16 00:00","end_time":"2022-11-16 00:30","data":{"0":0,"1":0,"2":0,"3":1.85,"4":1.13,"5":0}}}}
Which is the response the givenergy user got.
That will rule out my code at least. If you get errors you could try adjusting the dates.
If this doesn't work then maybe a zoom call and setting up postman so we can run it live (postman is a tool for testing API's and Givenergy have a collection which is a way of running all of the calls)
Fingers crossed.
Neil
import requests
import json
import indigo
url = "https://api.givenergy.cloud/v1/inverter/{serial_num}/energy-flows"
payload = json.dumps({
  "start_time": "2022-11-01",
  "end_time": "2022-11-01",
  "grouping": 0,
  "types": [
    0,
    1,
    2,
    5
headers = {
  'Content-Type': 'application/json',
  'Accept': 'application/json',
  'Authorization': 'Bearer {your_api_ley}'
response = requests.request("POST", url, headers=headers, data=payload)
indigo.server.log(response.text)
mwoodage
Post by mwoodage »
Ok, that works, I'm getting the following result :D
 Action Group                    Energy Flow TEST Script
   Script                          {"data":{"0":{"start_time":"2022-11-01 00:00","end_time":"2022-11-01 00:30","data":{"0":0,"1":0,"2":0,"5":0.14}}}}
I ran it twice just to make sure
M
neilk
Post by neilk »
Brilliant - progress at last, I just need to find out what is different when I build the call in the plugin. Thanks for your patience on this.
Actually could you try the following :-
1) Add the other flows in 3 (grid to home) 4 (grid to battery) and 6 (Battery to grid) as lines in the types list
2) Try it for the other groupings (change the 0 to 1, 2 and 3) and re run it
If I see the results then I can check the responses and build the updates at the same time I "hopefully" fix the call itself !
neilk
Post by neilk »
Martin,
I did find a difference in the two code blocks, and it looks like I may have found a bug in the API as I use the same authorisation approach for the Inverter Data call, but it doesn't work with the energy flows call (even though it is exactly in their sample code). The code I posted yesterday was generated by postman and works.
I have made the change, and this should now work (but just dumping the data in the log for now, bit it is easy to add once the call works)
https://github.com/neilkplugins/GivEner ... .0.6-Alpha
Neil
mwoodage
Post by mwoodage »
I think we should do a Zoom call as I'm not sure I;m setting this up right!
I've upgraded to the new plugin which seams to work fine. But when configuring the Edit Device Settings I'm not sure I'm setting it up right.
With the code below I just had the Energy Flow Daily switched on.
GivEnergy Debug                 URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/system-data/latest
   GivEnergy Debug                 Headers are:
   GivEnergy Debug                 {'Authorization': 'Bearer .eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT', 'Content-Type': 'application/json', 'Accept': 'application/json'}
   GivEnergy Debug                 API Response was:
   GivEnergy Debug                 {'data': {'time': '2022-11-17T10:45:02Z', 'solar': {'power': 1957, 'arrays': [{'array': 1, 'voltage': 226.5, 'current': 4.4, 'power': 995}, {'array': 2, 'voltage': 220.2, 'current': 4.3, 'power': 962}]}, 'grid': {'voltage': 246.1, 'current': 7.6, 'power': 312, 'frequency': 50.08}, 'battery': {'percent': 100, 'power': 0, 'temperature': 13}, 'inverter': {'temperature': 32.2, 'power': 1856, 'output_voltage': 247.5, 'output_frequency': 50.07, 'eps_power': 0}, 'consumption': 1523}}
   GivEnergy Debug                 Updating Flow device: Energy Flow Daily with aggregation 1
   GivEnergy Debug                 Which is linked to Inverter  xxxxxxxxxx
   GivEnergy Debug                 xxxxxxxxxx
   GivEnergy Debug                 Daily Reporting
   GivEnergy Debug                 Start Time is 2022-11-17
   GivEnergy Debug                 End Time is 2022-11-17
   GivEnergy Debug                 URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
   GivEnergy Debug                 Payload is:
   GivEnergy Debug                 {"start_time": "2022-11-17", "end_time": "2022-11-17", "grouping": 1, "types": [0, 1, 2, 3, 4, 5]}
   GivEnergy Debug                 {'Authorization': 'eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT, 'Content-Type': 'application/json', 'Accept': 'application/json'}
   GivEnergy Error                 HTTP error getting Energy Flow Daily xxxxxxxxxx data: 401 Client Error: Unauthorized for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
   GivEnergy Debug                 Updating Flow device: Energy Flow Yearly with aggregation 3
   GivEnergy Debug                 Yearly Reporting
   GivEnergy Debug                 Start Time is 2022-01-01
   GivEnergy Debug                 URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxxenergy-flows
   GivEnergy Debug                 {"start_time": "2022-01-01", "end_time": "2022-11-17", "grouping": 3, "types": [0, 1, 2, 3, 4, 5]}
   GivEnergy Debug                 {'Authorization': 'eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT_k6EwCKSF', 'Content-Type': 'application/json', 'Accept': 'application/json'}
Screenshot 2022-11-17 at 10.52.20.png (144.62 KiB) Viewed 2786 times
mwoodage
Post by mwoodage »
Hi Neil, I've had another play with this today, responding to your message for adding in the other flows (3,4,&6)
I've tried this, but it gives me the same result every time,
This is what I've tried,
import requests
import json
import indigo
url = "https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows"
  "grouping": 3,
  "types": [
    0,
    1,
    2,
	3,
	4,
    5,
	6
headers = {
  'Authorization': 'Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT_k6EwCKSF'
This is the result
 Script                          {"data":{"0":{"start_time":"2022-01-01 00:00","end_time":"2023-01-01 00:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.14,"6":0}}}}
   Schedule                        Inverter Data - Battery Percentage
   Z-Wave                          received "Landing Illuminance" sensor update to 94 lux
   Script                          {"data":{"0":{"start_time":"2022-11-01 00:00","end_time":"2022-11-01 00:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.14,"6":0}}}}
I'm not sure if this is right, but if I change the grouping from 0 to either 1,2,3,4,5 or 6 I get the same result :wink:
neilk
Post by neilk »
I think that is probably just the data returned for that date, so nothing different to show (and it may not be real if that was before your comissioning. You could try changing the dates to today, 1st of the month for monthly aggregation for example with grouping of 2, and then 1st of the month as start time, and today as end time (my code in the plugin already does this )
I am confused because the snippet works, but when in the plugin it doesn't (and gives the error I would expect) but it works when run as a script.
Maybe a zoom session is the best bet, we could run stuff in Postman and see what we get. I may have some time this evening, otherwise I am going to be offline most of the weekend.
Neil
mwoodage
Post by mwoodage »
Hi Neil,
I've got something!! I tried changing the date and then got loads of data back!!
Below is what I got back for grouping at 0 - I get similar results for 1, but 2,3,4 have a small amount of data (see below).
2022-11-17 17:00:02.938	Script	{"data":{"0":{"start_time":"2022-11-01 00:00","end_time":"2022-12-01 00:00","data":{"0":53.90000000000001,"1":22.970000000000002,"2":7.699999999999996,"3":71.19999999999999,"4":96.10999999999999,"5":109.53000000000003,"6":0.9600000000000005}}}}
2022-11-17 17:00:10.448	Script	{"data":{"0":{"start_time":"2022-11-01 00:00","end_time":"2022-11-02 00:00","data":{"0":5.34,"1":2.67,"2":0.8300000000000001,"3":3.889999999999998,"4":7.789999999999998,"5":8.21,"6":0.03}},"1":{"start_time":"2022-11-02 00:00","end_time":"2022-11-03 00:00","data":{"0":2.2399999999999993,"1":0.35,"2":0.03,"3":3.1399999999999983,"4":5.749999999999999,"5":8.22,"6":0.02}},"2":{"start_time":"2022-11-03 00:00","end_time":"2022-11-04 00:00","data":{"0":4.9399999999999995,"1":1.58,"2":0.73,"3":4.089999999999999,"4":8.29,"5":5.31,"6":0.15000000000000002}},"3":{"start_time":"2022-11-04 00:00","end_time":"2022-11-05 00:00","data":{"0":8.229999999999999,"1":2.61,"2":0.7600000000000002,"3":3.5999999999999988,"4":4.6499999999999995,"5":9.4,"6":0.18000000000000002}},"4":{"start_time":"2022-11-05 00:00","end_time":"2022-11-06 00:00","data":{"0":0.79,"1":0,"2":0,"3":5.169999999999998,"4":7.409999999999999,"5":9.229999999999999,"6":0}},"5":{"start_time":"2022-11-06 00:00","end_time":"2022-11-07 00:00","data":{"0":3.33,"1":2.0300000000000002,"2":0.28,"3":5.0299999999999985,"4":9.35,"5":10.339999999999998,"6":0.09}},"6":{"start_time":"2022-11-07 00:00","end_time":"2022-11-08 00:00","data":{"0":1.7400000000000004,"1":0.04,"2":0,"3":5.159999999999998,"4":8.9,"5":8.979999999999999,"6":0.05}},"7":{"start_time":"2022-11-08 00:00","end_time":"2022-11-09 00:00","data":{"0":6.13,"1":0.81,"2":1.0100000000000002,"3":3.759999999999997,"4":9.59,"5":6.13,"6":0.04}},"8":{"start_time":"2022-11-09 00:00","end_time":"2022-11-10 00:00","data":{"0":3.5100000000000007,"1":6.709999999999999,"2":0.04,"3":0.19,"4":0.03,"5":7.799999999999999,"6":0}},"9":{"start_time":"2022-11-10 00:00","end_time":"2022-11-11 00:00","data":{"0":1.5800000000000005,"1":0,"2":0.03,"3":14.74,"4":5.33,"5":3.21,"6":0.05}},"10":{"start_time":"2022-11-11 00:00","end_time":"2022-11-12 00:00","data":{"0":3.85,"1":0,"2":0.71,"3":3.0399999999999983,"4":9.29,"5":5.879999999999999,"6":0.16000000000000003}},"11":{"start_time":"2022-11-12 00:00","end_time":"2022-11-13 00:00","data":{"0":3.23,"1":0.81,"2":0.42000000000000004,"3":5.249999999999998,"4":5.23,"5":9.61,"6":0.060000000000000005}},"12":{"start_time":"2022-11-13 00:00","end_time":"2022-11-14 00:00","data":{"0":4.529999999999999,"1":2.41,"2":2.8399999999999994,"3":4.119999999999999,"4":6.460000000000001,"5":10.210000000000003,"6":0.11999999999999997}},"13":{"start_time":"2022-11-14 00:00","end_time":"2022-11-15 00:00","data":{"0":2.7800000000000002,"1":1.09,"2":0,"3":8.14,"4":4.14,"5":1.77,"6":0}},"14":{"start_time":"2022-11-15 00:00","end_time":"2022-11-16 00:00","data":{"0":1.68,"1":1.8600000000000003,"2":0.02,"3":1.63,"4":2.71,"5":5.23,"6":0.01}},"15":{"start_time":"2022-11-16 00:00","end_time":"2022-11-17 00:00","data":{"0":0,"1":0,"2":0,"3":0.25,"4":1.19,"5":0,"6":0}}}}
2022-11-17 17:00:25.164	Script	{"data":{"0":{"start_time":"2022-11-01 00:00","end_time":"2022-11-01 00:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.14,"6":0}},"1":{"start_time":"2022-11-01 00:30","end_time":"2022-11-01 01:00","data":{"0":0,"1":0,"2":0,"3":0.19,"4":1.08,"5":0,"6":0}},"2":{"start_time":"2022-11-01 01:00","end_time":"2022-11-01 01:30","data":{"0":0,"1":0,"2":0,"3":0.21,"4":1.18,"5":0,"6":0}},"3":{"start_time":"2022-11-01 01:30","end_time":"2022-11-01 02:00","data":{"0":0,"1":0,"2":0,"3":0.24,"4":1.18,"5":0,"6":0}},"4":{"start_time":"2022-11-01 02:00","end_time":"2022-11-01 02:30","data":{"0":0,"1":0,"2":0,"3":0.2,"4":1.18,"5":0,"6":0}},"5":{"start_time":"2022-11-01 02:30","end_time":"2022-11-01 03:00","data":{"0":0,"1":0,"2":0,"3":0.21,"4":1.18,"5":0,"6":0}},"6":{"start_time":"2022-11-01 03:00","end_time":"2022-11-01 03:30","data":{"0":0,"1":0,"2":0,"3":0.24,"4":1.18,"5":0,"6":0}},"7":{"start_time":"2022-11-01 03:30","end_time":"2022-11-01 04:00","data":{"0":0,"1":0,"2":0,"3":0.14,"4":0.79,"5":0,"6":0}},"8":{"start_time":"2022-11-01 04:00","end_time":"2022-11-01 04:30","data":{"0":0,"1":0,"2":0,"3":0.11,"4":0.01,"5":0,"6":0}},"9":{"start_time":"2022-11-01 04:30","end_time":"2022-11-01 05:00","data":{"0":0,"1":0,"2":0,"3":0.14,"4":0,"5":0,"6":0}},"10":{"start_time":"2022-11-01 05:00","end_time":"2022-11-01 05:30","data":{"0":0,"1":0,"2":0,"3":0.1,"4":0,"5":0,"6":0}},"11":{"start_time":"2022-11-01 05:30","end_time":"2022-11-01 06:00","data":{"0":0,"1":0,"2":0,"3":0.14,"4":0,"5":0,"6":0}},"12":{"start_time":"2022-11-01 06:00","end_time":"2022-11-01 06:30","data":{"0":0,"1":0,"2":0,"3":0.17,"4":0,"5":0,"6":0}},"13":{"start_time":"2022-11-01 06:30","end_time":"2022-11-01 07:00","data":{"0":0,"1":0,"2":0,"3":0.15,"4":0,"5":0,"6":0}},"14":{"start_time":"2022-11-01 07:00","end_time":"2022-11-01 07:30","data":{"0":0,"1":0,"2":0,"3":0.63,"4":0,"5":0.92,"6":0}},"15":{"start_time":"2022-11-01 07:30","end_time":"2022-11-01 08:00","data":{"0":0.02,"1":0,"2":0,"3":0.47,"4":0,"5":1.12,"6":0}},"16":{"start_time":"2022-11-01 08:00","end_time":"2022-11-01 08:30","data":{"0":0.09,"1":0,"2":0,"3":0,"4":0,"5":0.07,"6":0}},"17":{"start_time":"2022-11-01 08:30","end_time":"2022-11-01 09:00","data":{"0":0.15,"1":0.03,"2":0.01,"3":0,"4":0,"5":0.01,"6":0}},"18":{"start_time":"2022-11-01 09:00","end_time":"2022-11-01 09:30","data":{"0":0.17,"1":0.03,"2":0.01,"3":0,"4":0,"5":0.02,"6":0}},"19":{"start_time":"2022-11-01 09:30","end_time":"2022-11-01 10:00","data":{"0":0.14,"1":0.07,"2":0,"3":0.1,"4":0,"5":0.34,"6":0}},"20":{"start_time":"2022-11-01 10:00","end_time":"2022-11-01 10:30","data":{"0":0.17,"1":0,"2":0,"3":0,"4":0,"5":0.03,"6":0}},"21":{"start_time":"2022-11-01 10:30","end_time":"2022-11-01 11:00","data":{"0":0.13,"1":0.13,"2":0,"3":0.01,"4":0,"5":0.08,"6":0}},"22":{"start_time":"2022-11-01 11:00","end_time":"2022-11-01 11:30","data":{"0":0.32,"1":0.89,"2":0,"3":0,"4":0.01,"5":0,"6":0}},"23":{"start_time":"2022-11-01 11:30","end_time":"2022-11-01 12:00","data":{"0":0.21,"1":1.02,"2":0.04,"3":0,"4":0,"5":0,"6":0}},"24":{"start_time":"2022-11-01 12:00","end_time":"2022-11-01 12:30","data":{"0":0.58,"1":0.5,"2":0.09,"3":0,"4":0,"5":0,"6":0}},"25":{"start_time":"2022-11-01 12:30","end_time":"2022-11-01 13:00","data":{"0":0.92,"1":0,"2":0.12,"3":0,"4":0,"5":0,"6":0}},"26":{"start_time":"2022-11-01 13:00","end_time":"2022-11-01 13:30","data":{"0":0.83,"1":0,"2":0.15,"3":0,"4":0,"5":0,"6":0}},"27":{"start_time":"2022-11-01 13:30","end_time":"2022-11-01 14:00","data":{"0":0.65,"1":0,"2":0.14,"3":0,"4":0,"5":0,"6":0}},"28":{"start_time":"2022-11-01 14:00","end_time":"2022-11-01 14:30","data":{"0":0.44,"1":0,"2":0.15,"3":0,"4":0,"5":0,"6":0}},"29":{"start_time":"2022-11-01 14:30","end_time":"2022-11-01 15:00","data":{"0":0.09,"1":0,"2":0.01,"3":0.07,"4":0,"5":0.27,"6":0}},"30":{"start_time":"2022-11-01 15:00","end_time":"2022-11-01 15:30","data":{"0":0.28,"1":0,"2":0.08,"3":0,"4":0,"5":0,"6":0}},"31":{"start_time":"2022-11-01 15:30","end_time":"2022-11-01 16:00","data":{"0":0.14,"1":0,"2":0.03,"3":0,"4":0,"5":0.05,"6":0}},"32":{"start_time":"2022-11-01 16:00","end_time":"2022-11-01 16:30","data":{"0":0.01,"1":0,"2":0,"3":0,"4":0,"5":0.14,"6":0.01}},"33":{"start_time":"2022-11-01 16:30","end_time":"2022-11-01 17:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.19,"6":0.01}},"34":{"start_time":"2022-11-01 17:00","end_time":"2022-11-01 17:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.24,"6":0.01}},"35":{"start_time":"2022-11-01 17:30","end_time":"2022-11-01 18:00","data":{"0":0,"1":0,"2":0,"3":0.15,"4":0,"5":0.55,"6":0}},"36":{"start_time":"2022-11-01 18:00","end_time":"2022-11-01 18:30","data":{"0":0,"1":0,"2":0,"3":0.03,"4":0,"5":0.52,"6":0}},"37":{"start_time":"2022-11-01 18:30","end_time":"2022-11-01 19:00","data":{"0":0,"1":0,"2":0,"3":0.12,"4":0,"5":0.57,"6":0}},"38":{"start_time":"2022-11-01 19:00","end_time":"2022-11-01 19:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.37,"6":0}},"39":{"start_time":"2022-11-01 19:30","end_time":"2022-11-01 20:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.35,"6":0}},"40":{"start_time":"2022-11-01 20:00","end_time":"2022-11-01 20:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.41,"6":0}},"41":{"start_time":"2022-11-01 20:30","end_time":"2022-11-01 21:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.34,"6":0}},"42":{"start_time":"2022-11-01 21:00","end_time":"2022-11-01 21:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.43,"6":0}},"43":{"start_time":"2022-11-01 21:30","end_time":"2022-11-01 22:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.39,"6":0}},"44":{"start_time":"2022-11-01 22:00","end_time":"2022-11-01 22:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.24,"6":0}},"45":{"start_time":"2022-11-01 22:30","end_time":"2022-11-01 23:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.15,"6":0}},"46":{"start_time":"2022-11-01 23:00","end_time":"2022-11-01 23:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.14,"6":0}},"47":{"start_time":"2022-11-01 23:30","end_time":"2022-11-02 00:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.13,"6":0}},"48":{"start_time":"2022-11-02 00:00","end_time":"2022-11-02 00:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.13,"6":0}},"49":{"start_time":"2022-11-02 00:30","end_time":"2022-11-02 01:00","data":{"0":0,"1":0,"2":0,"3":0.22,"4":1.13,"5":0,"6":0}},"50":{"start_time":"2022-11-02 01:00","end_time":"2022-11-02 01:30","data":{"0":0,"1":0,"2":0,"3":0.23,"4":1.2,"5":0,"6":0}},"51":{"start_time":"2022-11-02 01:30","end_time":"2022-11-02 02:00","data":{"0":0,"1":0,"2":0,"3":0.23,"4":1.2,"5":0,"6":0}},"52":{"start_time":"2022-11-02 02:00","end_time":"2022-11-02 02:30","data":{"0":0,"1":0,"2":0,"3":0.2,"4":1.2,"5":0,"6":0}},"53":{"start_time":"2022-11-02 02:30","end_time":"2022-11-02 03:00","data":{"0":0,"1":0,"2":0,"3":0.2,"4":0.97,"5":0,"6":0}},"54":{"start_time":"2022-11-02 03:00","end_time":"2022-11-02 03:30","data":{"0":0,"1":0,"2":0,"3":0.14,"4":0.02,"5":0,"6":0}},"55":{"start_time":"2022-11-02 03:30","end_time":"2022-11-02 04:00","data":{"0":0,"1":0,"2":0,"3":0.1,"4":0,"5":0,"6":0}},"56":{"start_time":"2022-11-02 04:00","end_time":"2022-11-02 04:30","data":{"0":0,"1":0,"2":0,"3":0.12,"4":0,"5":0,"6":0}},"57":{"start_time":"2022-11-02 04:30","end_time":"2022-11-02 05:00","data":{"0":0,"1":0,"2":0,"3":0.13,"4":0,"5":0,"6":0}},"58":{"start_time":"2022-11-02 05:00","end_time":"2022-11-02 05:30","data":{"0":0,"1":0,"2":0,"3":0.1,"4":0,"5":0,"6":0}},"59":{"start_time":"2022-11-02 05:30","end_time":"2022-11-02 06:00","data":{"0":0,"1":0,"2":0,"3":0.16,"4":0,"5":0,"6":0}},"60":{"start_time":"2022-11-02 06:00","end_time":"2022-11-02 06:30","data":{"0":0,"1":0,"2":0,"3":0.16,"4":0,"5":0,"6":0}},"61":{"start_time":"2022-11-02 06:30","end_time":"2022-11-02 07:00","data":{"0":0,"1":0,"2":0,"3":0.56,"4":0,"5":0,"6":0}},"62":{"start_time":"2022-11-02 07:00","end_time":"2022-11-02 07:30","data":{"0":0.01,"1":0,"2":0,"3":0.09,"4":0,"5":0.16,"6":0}},"63":{"start_time":"2022-11-02 07:30","end_time":"2022-11-02 08:00","data":{"0":0.07,"1":0,"2":0,"3":0,"4":0,"5":0.32,"6":0}},"64":{"start_time":"2022-11-02 08:00","end_time":"2022-11-02 08:30","data":{"0":0.11,"1":0,"2":0,"3":0.01,"4":0,"5":0.14,"6":0}},"65":{"start_time":"2022-11-02 08:30","end_time":"2022-11-02 09:00","data":{"0":0.21,"1":0.05,"2":0.01,"3":0,"4":0,"5":0.01,"6":0}},"66":{"start_time":"2022-11-02 09:00","end_time":"2022-11-02 09:30","data":{"0":0.19,"1":0.03,"2":0,"3":0,"4":0,"5":0.04,"6":0}},"67":{"start_time":"2022-11-02 09:30","end_time":"2022-11-02 10:00","data":{"0":0.21,"1":0,"2":0.01,"3":0,"4":0,"5":0.01,"6":0}},"68":{"start_time":"2022-11-02 10:00","end_time":"2022-11-02 10:30","data":{"0":0.22,"1":0.11,"2":0,"3":0,"4":0.01,"5":0,"6":0}},"69":{"start_time":"2022-11-02 10:30","end_time":"2022-11-02 11:00","data":{"0":0.2,"1":0.03,"2":0,"3":0,"4":0.01,"5":0.01,"6":0}},"70":{"start_time":"2022-11-02 11:00","end_time":"2022-11-02 11:30","data":{"0":0.11,"1":0,"2":0,"3":0,"4":0,"5":0.09,"6":0}},"71":{"start_time":"2022-11-02 11:30","end_time":"2022-11-02 12:00","data":{"0":0.23,"1":0.03,"2":0,"3":0.04,"4":0.01,"5":0.21,"6":0}},"72":{"start_time":"2022-11-02 12:00","end_time":"2022-11-02 12:30","data":{"0":0.2,"1":0,"2":0,"3":0,"4":0,"5":0.26,"6":0.01}},"73":{"start_time":"2022-11-02 12:30","end_time":"2022-11-02 13:00","data":{"0":0.21,"1":0.1,"2":0.01,"3":0,"4":0,"5":0,"6":0}},"74":{"start_time":"2022-11-02 13:00","end_time":"2022-11-02 13:30","data":{"0":0.13,"1":0,"2":0,"3":0,"4":0,"5":0.07,"6":0}},"75":{"start_time":"2022-11-02 13:30","end_time":"2022-11-02 14:00","data":{"0":0.05,"1":0,"2":0,"3":0.01,"4":0,"5":0.16,"6":0}},"76":{"start_time":"2022-11-02 14:00","end_time":"2022-11-02 14:30","data":{"0":0.02,"1":0,"2":0,"3":0.01,"4":0,"5":0.14,"6":0}},"77":{"start_time":"2022-11-02 14:30","end_time":"2022-11-02 15:00","data":{"0":0.03,"1":0,"2":0,"3":0.01,"4":0,"5":0.09,"6":0}},"78":{"start_time":"2022-11-02 15:00","end_time":"2022-11-02 15:30","data":{"0":0.02,"1":0,"2":0,"3":0,"4":0,"5":0.15,"6":0}},"79":{"start_time":"2022-11-02 15:30","end_time":"2022-11-02 16:00","data":{"0":0.01,"1":0,"2":0,"3":0,"4":0,"5":0.14,"6":0}},"80":{"start_time":"2022-11-02 16:00","end_time":"2022-11-02 16:30","data":{"0":0.01,"1":0,"2":0,"3":0.01,"4":0,"5":0.16,"6":0}},"81":{"start_time":"2022-11-02 16:30","end_time":"2022-11-02 17:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.24,"6":0}},"82":{"start_time":"2022-11-02 17:00","end_time":"2022-11-02 17:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.3,"6":0}},"83":{"start_time":"2022-11-02 17:30","end_time":"2022-11-02 18:00","data":{"0":0,"1":0,"2":0,"3":0.1,"4":0,"5":0.58,"6":0}},"84":{"start_time":"2022-11-02 18:00","end_time":"2022-11-02 18:30","data":{"0":0,"1":0,"2":0,"3":0.21,"4":0,"5":0.93,"6":0}},"85":{"start_time":"2022-11-02 18:30","end_time":"2022-11-02 19:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.39,"6":0}},"86":{"start_time":"2022-11-02 19:00","end_time":"2022-11-02 19:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.38,"6":0.01}},"87":{"start_time":"2022-11-02 19:30","end_time":"2022-11-02 20:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.28,"6":0}},"88":{"start_time":"2022-11-02 20:00","end_time":"2022-11-02 20:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.31,"6":0}},"89":{"start_time":"2022-11-02 20:30","end_time":"2022-11-02 21:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.32,"6":0}},"90":{"start_time":"2022-11-02 21:00","end_time":"2022-11-02 21:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.38,"6":0}},"91":{"start_time":"2022-11-02 21:30","end_time":"2022-11-02 22:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.28,"6":0}},"92":{"start_time":"2022-11-02 22:00","end_time":"2022-11-02 22:30","data":{"0":0,"1":0,"2":0,"3":0.02,"4":0,"5":0.7,"6":0}},"93":{"start_time":"2022-11-02 22:30","end_time":"2022-11-02 23:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.16,"6":0}},"94":{"start_time":"2022-11-02 23:00","end_time":"2022-11-02 23:30","data":{"0":0,"1":0,"2":0,"3":0.02,"4":0,"5":0.36,"6":0}},"95":{"start_time":"2022-11-02 23:30","end_time":"2022-11-03 00:00","data":{"0":0,"1":0,"2":0,"3":0.02,"4":0,"5":0.32,"6":0}},"96":{"start_time":"2022-11-03 00:00","end_time":"2022-11-03 00:30","data":{"0":0,"1":0,"2":0,"3":0.02,"4":0.01,"5":0.12,"6":0}},"97":{"start_time":"2022-11-03 00:30","end_time":"2022-11-03 01:00","data":{"0":0,"1":0,"2":0,"3":0.25,"4":1.16,"5":0,"6":0}},"98":{"start_time":"2022-11-03 01:00","end_time":"2022-11-03 01:30","data":{"0":0,"1":0,"2":0,"3":0.25,"4":1.19,"5":0,"6":0}},"99":{"start_time":"2022-11-03 01:30","end_time":"2022-11-03 02:00","data":{"0":0,"1":0,"2":0,"3":0.24,"4":1.19,"5":0,"6":0}},"100":{"start_time":"2022-11-03 02:00","end_time":"2022-11-03 02:30","data":{"0":0,"1":0,"2":0,"3":0.23,"4":1.19,"5":0,"6":0}},"101":{"start_time":"2022-11-03 02:30","end_time":"2022-11-03 03:00","data":{"0":0,"1":0,"2":0,"3":0.22,"4":1.19,"5":0,"6":0}},"102":{"start_time":"2022-11-03 03:00","end_time":"2022-11-03 03:30","data":{"0":0,"1":0,"2":0,"3":0.25,"4":1.19,"5":0,"6":0}},"103":{"start_time":"2022-11-03 03:30","end_time":"2022-11-03 04:00","data":{"0":0,"1":0,"2":0,"3":0.22,"4":1.07,"5":0,"6":0}},"104":{"start_time":"2022-11-03 04:00","end_time":"2022-11-03 04:30","data":{"0":0,"1":0,"2":0,"3":0.11,"4":0.1,"5":0,"6":0}},"105":{"start_time":"2022-11-03 04:30","end_time":"2022-11-03 05:00","data":{"0":0,"1":0,"2":0,"3":0.15,"4":0,"5":0,"6":0}},"106":{"start_time":"2022-11-03 05:00","end_time":"2022-11-03 05:30","data":{"0":0,"1":0,"2":0,"3":0.16,"4":0,"5":0,"6":0}},"107":{"start_time":"2022-11-03 05:30","end_time":"2022-11-03 06:00","data":{"0":0,"1":0,"2":0,"3":0.21,"4":0,"5":0,"6":0}},"108":{"start_time":"2022-11-03 06:00","end_time":"2022-11-03 06:30","data":{"0":0,"1":0,"2":0,"3":0.17,"4":0,"5":0,"6":0}},"109":{"start_time":"2022-11-03 06:30","end_time":"2022-11-03 07:00","data":{"0":0,"1":0,"2":0,"3":0.2,"4":0,"5":0,"6":0}},"110":{"start_time":"2022-11-03 07:00","end_time":"2022-11-03 07:30","data":{"0":0,"1":0,"2":0,"3":0.97,"4":0,"5":0.92,"6":0}},"111":{"start_time":"2022-11-03 07:30","end_time":"2022-11-03 08:00","data":{"0":0.01,"1":0,"2":0,"3":0.06,"4":0,"5":0.25,"6":0.01}},"112":{"start_time":"2022-11-03 08:00","end_time":"2022-11-03 08:30","data":{"0":0.02,"1":0,"2":0,"3":0.01,"4":0,"5":0.13,"6":0}},"113":{"start_time":"2022-11-03 08:30","end_time":"2022-11-03 09:00","data":{"0":0.04,"1":0,"2":0,"3":0,"4":0,"5":0.09,"6":0.01}},"114":{"start_time":"2022-11-03 09:00","end_time":"2022-11-03 09:30","data":{"0":0.16,"1":0,"2":0,"3":0.24,"4":0,"5":1.35,"6":0.01}},"548":{"start_time":"2022-11-12 10:00","end_time":"2022-11-12 10:30","data":{"0":0.13,"1":0,"2":0,"3":0.9,"4":0,"5":1.55,"6":0}},"549":{"start_time":"2022-11-12 10:30","end_time":"2022-11-12 11:00","data":{"0":0.21,"1":0,"2":0,"3":0.18,"4":0,"5":0.61,"6":0}},"550":{"start_time":"2022-11-12 11:00","end_time":"2022-11-12 11:30","data":{"0":0.5,"1":0,"2":0.01,"3":0,"4":0,"5":0.66,"6":0.01}},"551":{"start_time":"2022-11-12 11:30","end_time":"2022-11-12 12:00","data":{"0":0.19,"1":0,"2":0.01,"3":0,"4":0,"5":0.08,"6":0}},"552":{"start_time":"2022-11-12 12:00","end_time":"2022-11-12 12:30","data":{"0":0.17,"1":0,"2":0.03,"3":0,"4":0,"5":0.01,"6":0.01}},"553":{"start_time":"2022-11-12 12:30","end_time":"2022-11-12 13:00","data":{"0":0.4,"1":0,"2":0.1,"3":0,"4":0,"5":0,"6":0}},"554":{"start_time":"2022-11-12 13:00","end_time":"2022-11-12 13:30","data":{"0":0.22,"1":0,"2":0.06,"3":0,"4":0,"5":0,"6":0}},"555":{"start_time":"2022-11-12 13:30","end_time":"2022-11-12 14:00","data":{"0":0.77,"1":0,"2":0.09,"3":0,"4":0,"5":0,"6":0}},"556":{"start_time":"2022-11-12 14:00","end_time":"2022-11-12 14:30","data":{"0":0.24,"1":0.26,"2":0.12,"3":0,"4":0,"5":0,"6":0}},"557":{"start_time":"2022-11-12 14:30","end_time":"2022-11-12 15:00","data":{"0":0.02,"1":0.28,"2":0,"3":0,"4":0,"5":0,"6":0}},"558":{"start_time":"2022-11-12 15:00","end_time":"2022-11-12 15:30","data":{"0":0.01,"1":0.2,"2":0,"3":0,"4":0,"5":0,"6":0}},"559":{"start_time":"2022-11-12 15:30","end_time":"2022-11-12 16:00","data":{"0":0,"1":0.07,"2":0,"3":0,"4":0,"5":0,"6":0}},"560":{"start_time":"2022-11-12 16:00","end_time":"2022-11-12 16:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0,"6":0}},"561":{"start_time":"2022-11-12 16:30","end_time":"2022-11-12 17:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"562":{"start_time":"2022-11-12 17:00","end_time":"2022-11-12 17:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"563":{"start_time":"2022-11-12 17:30","end_time":"2022-11-12 18:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"564":{"start_time":"2022-11-12 18:00","end_time":"2022-11-12 18:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"565":{"start_time":"2022-11-12 18:30","end_time":"2022-11-12 19:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"566":{"start_time":"2022-11-12 19:00","end_time":"2022-11-12 19:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"567":{"start_time":"2022-11-12 19:30","end_time":"2022-11-12 20:00","data":{"0":0,"1":0,"2":0,"3":0.17,"4":0,"5":0.25,"6":0}},"568":{"start_time":"2022-11-12 20:00","end_time":"2022-11-12 20:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.36,"6":0}},"569":{"start_time":"2022-11-12 20:30","end_time":"2022-11-12 21:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.29,"6":0}},"570":{"start_time":"2022-11-12 21:00","end_time":"2022-11-12 21:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.35,"6":0.01}},"571":{"start_time":"2022-11-12 21:30","end_time":"2022-11-12 22:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.39,"6":0}},"572":{"start_time":"2022-11-12 22:00","end_time":"2022-11-12 22:30","data":{"0":0,"1":0,"2":0,"3":0.12,"4":0,"5":1.15,"6":0}},"573":{"start_time":"2022-11-12 22:30","end_time":"2022-11-12 23:00","data":{"0":0,"1":0,"2":0,"3":0.24,"4":0.85,"5":0.32,"6":0}},"574":{"start_time":"2022-11-12 23:00","end_time":"2022-11-12 23:30","data":{"0":0,"1":0,"2":0,"3":0.39,"4":1.7,"5":0,"6":0}},"575":{"start_time":"2022-11-12 23:30","end_time":"2022-11-13 00:00","data":{"0":0,"1":0,"2":0,"3":0.39,"4":1.5699999999999998,"5":0,"6":0}},"576":{"start_time":"2022-11-13 00:00","end_time":"2022-11-13 00:30","data":{"0":0,"1":0,"2":0,"3":0.28,"4":1.1400000000000001,"5":0,"6":0}},"577":{"start_time":"2022-11-13 00:30","end_time":"2022-11-13 01:00","data":{"0":0,"1":0,"2":0,"3":0.28,"4":1.1400000000000001,"5":0,"6":0}},"578":{"start_time":"2022-11-13 01:00","end_time":"2022-11-13 01:30","data":{"0":0,"1":0,"2":0,"3":0.23,"4":1.1400000000000001,"5":0,"6":0}},"579":{"start_time":"2022-11-13 01:30","end_time":"2022-11-13 02:00","data":{"0":0,"1":0,"2":0,"3":0.21,"4":1.1400000000000001,"5":0,"6":0}},"580":{"start_time":"2022-11-13 02:00","end_time":"2022-11-13 02:30","data":{"0":0,"1":0,"2":0,"3":0.2,"4":1.1400000000000001,"5":0,"6":0}},"581":{"start_time":"2022-11-13 02:30","end_time":"2022-11-13 03:00","data":{"0":0,"1":0,"2":0,"3":0.19,"4":0.73,"5":0,"6":0}},"582":{"start_time":"2022-11-13 03:00","end_time":"2022-11-13 03:30","data":{"0":0,"1":0,"2":0,"3":0.11,"4":0,"5":0,"6":0}},"583":{"start_time":"2022-11-13 03:30","end_time":"2022-11-13 04:00","data":{"0":0,"1":0,"2":0,"3":0.09,"4":0,"5":0,"6":0}},"584":{"start_time":"2022-11-13 04:00","end_time":"2022-11-13 04:30","data":{"0":0,"1":0,"2":0,"3":0.13,"4":0,"5":0,"6":0}},"585":{"start_time":"2022-11-13 04:30","end_time":"2022-11-13 05:00","data":{"0":0,"1":0,"2":0,"3":0.09,"4":0,"5":0,"6":0}},"586":{"start_time":"2022-11-13 05:00","end_time":"2022-11-13 05:30","data":{"0":0,"1":0,"2":0,"3":0.1,"4":0,"5":0,"6":0}},"587":{"start_time":"2022-11-13 05:30","end_time":"2022-11-13 06:00","data":{"0":0,"1":0,"2":0,"3":0.14,"4":0,"5":0,"6":0}},"588":{"start_time":"2022-11-13 06:00","end_time":"2022-11-13 06:30","data":{"0":0,"1":0,"2":0,"3":0.13,"4":0,"5":0,"6":0}},"589":{"start_time":"2022-11-13 06:30","end_time":"2022-11-13 07:00","data":{"0":0,"1":0,"2":0,"3":0.08,"4":0,"5":0.05,"6":0}},"590":{"start_time":"2022-11-13 07:00","end_time":"2022-11-13 07:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.19,"6":0.01}},"591":{"start_time":"2022-11-13 07:30","end_time":"2022-11-13 08:00","data":{"0":0.01,"1":0,"2":0,"3":0.01,"4":0,"5":0.15,"6":0}},"592":{"start_time":"2022-11-13 08:00","end_time":"2022-11-13 08:30","data":{"0":0.05,"1":0,"2":0,"3":0.08,"4":0,"5":0.33,"6":0}},"593":{"start_time":"2022-11-13 08:30","end_time":"2022-11-13 09:00","data":{"0":0.08,"1":0,"2":0,"3":0,"4":0,"5":0.07,"6":0.01}},"594":{"start_time":"2022-11-13 09:00","end_time":"2022-11-13 09:30","data":{"0":0.13,"1":0,"2":0.05,"3":0,"4":0,"5":0,"6":0}},"595":{"start_time":"2022-11-13 09:30","end_time":"2022-11-13 10:00","data":{"0":0.35,"1":0,"2":0.03,"3":0.13,"4":0,"5":0.52,"6":0.01}},"596":{"start_time":"2022-11-13 10:00","end_time":"2022-11-13 10:30","data":{"0":0.29,"1":0,"2":0.4,"3":0,"4":0,"5":0.08,"6":0.03}},"597":{"start_time":"2022-11-13 10:30","end_time":"2022-11-13 11:00","data":{"0":0.21,"1":0,"2":0.63,"3":0,"4":0,"5":0,"6":0.01}},"598":{"start_time":"2022-11-13 11:00","end_time":"2022-11-13 11:30","data":{"0":0.15,"1":0,"2":0.84,"3":0,"4":0,"5":0,"6":0.01}},"599":{"start_time":"2022-11-13 11:30","end_time":"2022-11-13 12:00","data":{"0":0.19,"1":0,"2":0.83,"3":0,"4":0,"5":0,"6":0.01}},"600":{"start_time":"2022-11-13 12:00","end_time":"2022-11-13 12:30","data":{"0":0.3,"1":0.69,"2":0.01,"3":0,"4":0,"5":0,"6":0}},"601":{"start_time":"2022-11-13 12:30","end_time":"2022-11-13 13:00","data":{"0":0.27,"1":0.81,"2":0.03,"3":0,"4":0,"5":0,"6":0}},"602":{"start_time":"2022-11-13 13:00","end_time":"2022-11-13 13:30","data":{"0":0.94,"1":0.02,"2":0.01,"3":0.1,"4":0.01,"5":0.5,"6":0}},"603":{"start_time":"2022-11-13 13:30","end_time":"2022-11-13 14:00","data":{"0":0.54,"1":0.41,"2":0,"3":0,"4":0.01,"5":0.28,"6":0}},"604":{"start_time":"2022-11-13 14:00","end_time":"2022-11-13 14:30","data":{"0":0.28,"1":0.3,"2":0,"3":0.03,"4":0,"5":0.3,"6":0}},"605":{"start_time":"2022-11-13 14:30","end_time":"2022-11-13 15:00","data":{"0":0.53,"1":0.06,"2":0,"3":0,"4":0,"5":0.87,"6":0}},"606":{"start_time":"2022-11-13 15:00","end_time":"2022-11-13 15:30","data":{"0":0.13,"1":0.12,"2":0.01,"3":0,"4":0.01,"5":0,"6":0}},"607":{"start_time":"2022-11-13 15:30","end_time":"2022-11-13 16:00","data":{"0":0.06,"1":0,"2":0,"3":0.34,"4":0,"5":0.78,"6":0}},"608":{"start_time":"2022-11-13 16:00","end_time":"2022-11-13 16:30","data":{"0":0.02,"1":0,"2":0,"3":0.18,"4":0,"5":0.85,"6":0}},"609":{"start_time":"2022-11-13 16:30","end_time":"2022-11-13 17:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.16,"6":0}},"610":{"start_time":"2022-11-13 17:00","end_time":"2022-11-13 17:30","data":{"0":0,"1":0,"2":0,"3":0.44,"4":0,"5":0.97,"6":0}},"611":{"start_time":"2022-11-13 17:30","end_time":"2022-11-13 18:00","data":{"0":0,"1":0,"2":0,"3":0.1,"4":0,"5":0.57,"6":0}},"612":{"start_time":"2022-11-13 18:00","end_time":"2022-11-13 18:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.29,"6":0}},"613":{"start_time":"2022-11-13 18:30","end_time":"2022-11-13 19:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.27,"6":0}},"614":{"start_time":"2022-11-13 19:00","end_time":"2022-11-13 19:30","data":{"0":0,"1":0,"2":0,"3":0.02,"4":0,"5":0.31,"6":0}},"615":{"start_time":"2022-11-13 19:30","end_time":"2022-11-13 20:00","data":{"0":0,"1":0,"2":0,"3":0.38,"4":0,"5":0.84,"6":0}},"616":{"start_time":"2022-11-13 20:00","end_time":"2022-11-13 20:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.32,"6":0}},"617":{"start_time":"2022-11-13 20:30","end_time":"2022-11-13 21:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.27,"6":0}},"618":{"start_time":"2022-11-13 21:00","end_time":"2022-11-13 21:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.27,"6":0.01}},"619":{"start_time":"2022-11-13 21:30","end_time":"2022-11-13 22:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.31,"6":0}},"620":{"start_time":"2022-11-13 22:00","end_time":"2022-11-13 22:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.25,"6":0}},"621":{"start_time":"2022-11-13 22:30","end_time":"2022-11-13 23:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.14,"6":0.01}},"622":{"start_time":"2022-11-13 23:00","end_time":"2022-11-13 23:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.14,"6":0.01}},"623":{"start_time":"2022-11-13 23:30","end_time":"2022-11-14 00:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.13,"6":0}},"624":{"start_time":"2022-11-14 00:00","end_time":"2022-11-14 00:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.14,"6":0}},"625":{"start_time":"2022-11-14 00:30","end_time":"2022-11-14 01:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.11,"6":0}},"626":{"start_time":"2022-11-14 01:00","end_time":"2022-11-14 01:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.11,"6":0}},"627":{"start_time":"2022-11-14 01:30","end_time":"2022-11-14 02:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.16,"6":0}},"628":{"start_time":"2022-11-14 02:00","end_time":"2022-11-14 02:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.15,"6":0}},"629":{"start_time":"2022-11-14 02:30","end_time":"2022-11-14 03:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.13,"6":0}},"630":{"start_time":"2022-11-14 03:00","end_time":"2022-11-14 03:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.12,"6":0}},"631":{"start_time":"2022-11-14 03:30","end_time":"2022-11-14 04:00","data":{"0":0,"1":0,"2":0,"3":0.13,"4":0,"5":0.01,"6":0}},"632":{"start_time":"2022-11-14 04:00","end_time":"2022-11-14 04:30","data":{"0":0,"1":0,"2":0,"3":0.12,"4":0,"5":0,"6":0}},"633":{"start_time":"2022-11-14 04:30","end_time":"2022-11-14 05:00","data":{"0":0,"1":0,"2":0,"3":0.1,"4":0,"5":0,"6":0}},"634":{"start_time":"2022-11-14 05:00","end_time":"2022-11-14 05:30","data":{"0":0,"1":0,"2":0,"3":0.1,"4":0,"5":0,"6":0}},"635":{"start_time":"2022-11-14 05:30","end_time":"2022-11-14 06:00","data":{"0":0,"1":0,"2":0,"3":0.16,"4":0,"5":0,"6":0}},"636":{"start_time":"2022-11-14 06:00","end_time":"2022-11-14 06:30","data":{"0":0,"1":0,"2":0,"3":0.2,"4":0,"5":0,"6":0}},"637":{"start_time":"2022-11-14 06:30","end_time":"2022-11-14 07:00","data":{"0":0,"1":0,"2":0,"3":0.2,"4":0,"5":0,"6":0}},"638":{"start_time":"2022-11-14 07:00","end_time":"2022-11-14 07:30","data":{"0":0,"1":0,"2":0,"3":0.49,"4":0,"5":0,"6":0}},"639":{"start_time":"2022-11-14 07:30","end_time":"2022-11-14 08:00","data":{"0":0,"1":0,"2":0,"3":0.26,"4":0,"5":0,"6":0}},"640":{"start_time":"2022-11-14 08:00","end_time":"2022-11-14 08:30","data":{"0":0.01,"1":0,"2":0,"3":0.16,"4":0,"5":0,"6":0}},"641":{"start_time":"2022-11-14 08:30","end_time":"2022-11-14 09:00","data":{"0":0.06,"1":0,"2":0,"3":0.1,"4":0,"5":0,"6":0}},"642":{"start_time":"2022-11-14 09:00","end_time":"2022-11-14 09:30","data":{"0":0.12,"1":0,"2":0,"3":0.08,"4":0,"5":0,"6":0}},"643":{"start_time":"2022-11-14 09:30","end_time":"2022-11-14 10:00","data":{"0":0.19,"1":0.09,"2":0,"3":0,"4":0.01,"5":0,"6":0}},"644":{"start_time":"2022-11-14 10:00","end_time":"2022-11-14 10:30","data":{"0":0.15,"1":0.01,"2":0,"3":0,"4":0,"5":0,"6":0}},"645":{"start_time":"2022-11-14 10:30","end_time":"2022-11-14 11:00","data":{"0":0.17,"1":0.03,"2":0,"3":0.04,"4":0,"5":0,"6":0}},"646":{"start_time":"2022-11-14 11:00","end_time":"2022-11-14 11:30","data":{"0":0.1,"1":0,"2":0,"3":0.08,"4":0,"5":0,"6":0}},"647":{"start_time":"2022-11-14 11:30","end_time":"2022-11-14 12:00","data":{"0":0.08,"1":0,"2":0,"3":0.07,"4":0,"5":0,"6":0}},"648":{"start_time":"2022-11-14 12:00","end_time":"2022-11-14 12:30","data":{"0":0.34,"1":0.01,"2":0,"3":0.22,"4":0.01,"5":0,"6":0}},"649":{"start_time":"2022-11-14 12:30","end_time":"2022-11-14 13:00","data":{"0":0.27,"1":0.07,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"650":{"start_time":"2022-11-14 13:00","end_time":"2022-11-14 13:30","data":{"0":0.22,"1":0.05,"2":0,"3":0,"4":0,"5":0,"6":0}},"651":{"start_time":"2022-11-14 13:30","end_time":"2022-11-14 14:00","data":{"0":0.19,"1":0.24,"2":0,"3":0,"4":0,"5":0,"6":0}},"652":{"start_time":"2022-11-14 14:00","end_time":"2022-11-14 14:30","data":{"0":0.22,"1":0.25,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"653":{"start_time":"2022-11-14 14:30","end_time":"2022-11-14 15:00","data":{"0":0.23,"1":0.08,"2":0,"3":0,"4":0,"5":0.16,"6":0}},"654":{"start_time":"2022-11-14 15:00","end_time":"2022-11-14 15:30","data":{"0":0.23,"1":0.18,"2":0,"3":0,"4":0.01,"5":0,"6":0}},"655":{"start_time":"2022-11-14 15:30","end_time":"2022-11-14 16:00","data":{"0":0.18,"1":0.08,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"656":{"start_time":"2022-11-14 16:00","end_time":"2022-11-14 16:30","data":{"0":0.02,"1":0,"2":0,"3":0.01,"4":0,"5":0.25,"6":0}},"657":{"start_time":"2022-11-14 16:30","end_time":"2022-11-14 17:00","data":{"0":0,"1":0,"2":0,"3":0.02,"4":0,"5":0.27,"6":0}},"658":{"start_time":"2022-11-14 17:00","end_time":"2022-11-14 17:30","data":{"0":0,"1":0,"2":0,"3":0.15,"4":0,"5":0.13,"6":0}},"659":{"start_time":"2022-11-14 17:30","end_time":"2022-11-14 18:00","data":{"0":0,"1":0,"2":0,"3":0.79,"4":0,"5":0,"6":0}},"660":{"start_time":"2022-11-14 18:00","end_time":"2022-11-14 18:30","data":{"0":0,"1":0,"2":0,"3":0.91,"4":0,"5":0,"6":0}},"661":{"start_time":"2022-11-14 18:30","end_time":"2022-11-14 19:00","data":{"0":0,"1":0,"2":0,"3":0.32,"4":0,"5":0,"6":0}},"662":{"start_time":"2022-11-14 19:00","end_time":"2022-11-14 19:30","data":{"0":0,"1":0,"2":0,"3":0.27,"4":0,"5":0,"6":0}},"663":{"start_time":"2022-11-14 19:30","end_time":"2022-11-14 20:00","data":{"0":0,"1":0,"2":0,"3":0.28,"4":0,"5":0,"6":0}},"664":{"start_time":"2022-11-14 20:00","end_time":"2022-11-14 20:30","data":{"0":0,"1":0,"2":0,"3":0.32,"4":0,"5":0,"6":0}},"665":{"start_time":"2022-11-14 20:30","end_time":"2022-11-14 21:00","data":{"0":0,"1":0,"2":0,"3":0.25,"4":0,"5":0,"6":0}},"666":{"start_time":"2022-11-14 21:00","end_time":"2022-11-14 21:30","data":{"0":0,"1":0,"2":0,"3":0.27,"4":0,"5":0,"6":0}},"667":{"start_time":"2022-11-14 21:30","end_time":"2022-11-14 22:00","data":{"0":0,"1":0,"2":0,"3":0.25,"4":0,"5":0,"6":0}},"668":{"start_time":"2022-11-14 22:00","end_time":"2022-11-14 22:30","data":{"0":0,"1":0,"2":0,"3":0.25,"4":0.6,"5":0,"6":0}},"669":{"start_time":"2022-11-14 22:30","end_time":"2022-11-14 23:00","data":{"0":0,"1":0,"2":0,"3":0.27,"4":1.21,"5":0,"6":0}},"670":{"start_time":"2022-11-14 23:00","end_time":"2022-11-14 23:30","data":{"0":0,"1":0,"2":0,"3":0.78,"4":1.21,"5":0,"6":0}},"671":{"start_time":"2022-11-14 23:30","end_time":"2022-11-15 00:00","data":{"0":0,"1":0,"2":0,"3":0.44,"4":1.09,"5":0,"6":0}},"672":{"start_time":"2022-11-15 00:00","end_time":"2022-11-15 00:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.19,"6":0}},"673":{"start_time":"2022-11-15 00:30","end_time":"2022-11-15 01:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.1,"6":0}},"674":{"start_time":"2022-11-15 01:00","end_time":"2022-11-15 01:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.14,"6":0}},"675":{"start_time":"2022-11-15 01:30","end_time":"2022-11-15 02:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.1,"6":0}},"676":{"start_time":"2022-11-15 02:00","end_time":"2022-11-15 02:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.11,"6":0}},"677":{"start_time":"2022-11-15 02:30","end_time":"2022-11-15 03:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.13,"6":0}},"678":{"start_time":"2022-11-15 03:00","end_time":"2022-11-15 03:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.09,"6":0}},"679":{"start_time":"2022-11-15 03:30","end_time":"2022-11-15 04:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.13,"6":0}},"680":{"start_time":"2022-11-15 04:00","end_time":"2022-11-15 04:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.11,"6":0}},"681":{"start_time":"2022-11-15 04:30","end_time":"2022-11-15 05:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.09,"6":0}},"682":{"start_time":"2022-11-15 05:00","end_time":"2022-11-15 05:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.13,"6":0}},"683":{"start_time":"2022-11-15 05:30","end_time":"2022-11-15 06:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.17,"6":0}},"684":{"start_time":"2022-11-15 06:00","end_time":"2022-11-15 06:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.14,"6":0}},"685":{"start_time":"2022-11-15 06:30","end_time":"2022-11-15 07:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.19,"6":0}},"686":{"start_time":"2022-11-15 07:00","end_time":"2022-11-15 07:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.22,"6":0}},"687":{"start_time":"2022-11-15 07:30","end_time":"2022-11-15 08:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.22,"6":0}},"688":{"start_time":"2022-11-15 08:00","end_time":"2022-11-15 08:30","data":{"0":0.01,"1":0,"2":0,"3":0,"4":0,"5":0.19,"6":0}},"689":{"start_time":"2022-11-15 08:30","end_time":"2022-11-15 09:00","data":{"0":0.02,"1":0,"2":0,"3":0.01,"4":0,"5":0.12,"6":0}},"690":{"start_time":"2022-11-15 09:00","end_time":"2022-11-15 09:30","data":{"0":0.06,"1":0,"2":0,"3":0,"4":0,"5":0.1,"6":0.01}},"691":{"start_time":"2022-11-15 09:30","end_time":"2022-11-15 10:00","data":{"0":0.13,"1":0,"2":0,"3":0,"4":0,"5":0.06,"6":0}},"692":{"start_time":"2022-11-15 10:00","end_time":"2022-11-15 10:30","data":{"0":0.14,"1":0.03,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"693":{"start_time":"2022-11-15 10:30","end_time":"2022-11-15 11:00","data":{"0":0.16,"1":0.02,"2":0.01,"3":0,"4":0,"5":0.01,"6":0}},"694":{"start_time":"2022-11-15 11:00","end_time":"2022-11-15 11:30","data":{"0":0.31,"1":0.66,"2":0,"3":0,"4":0.02,"5":0.01,"6":0}},"695":{"start_time":"2022-11-15 11:30","end_time":"2022-11-15 12:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0,"6":0}},"696":{"start_time":"2022-11-15 12:00","end_time":"2022-11-15 12:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0,"6":0}},"697":{"start_time":"2022-11-15 12:30","end_time":"2022-11-15 13:00","data":{"0":0.25,"1":0.36,"2":0,"3":0,"4":0.01,"5":0,"6":0}},"698":{"start_time":"2022-11-15 13:00","end_time":"2022-11-15 13:30","data":{"0":0.15,"1":0.09,"2":0,"3":0,"4":0.01,"5":0.08,"6":0}},"699":{"start_time":"2022-11-15 13:30","end_time":"2022-11-15 14:00","data":{"0":0.07,"1":0.07,"2":0,"3":0,"4":0,"5":0.13,"6":0}},"700":{"start_time":"2022-11-15 14:00","end_time":"2022-11-15 14:30","data":{"0":0.14,"1":0.3,"2":0,"3":0,"4":0,"5":0.01,"6":0}},"701":{"start_time":"2022-11-15 14:30","end_time":"2022-11-15 15:00","data":{"0":0.16,"1":0.29,"2":0.01,"3":0,"4":0,"5":0,"6":0}},"702":{"start_time":"2022-11-15 15:00","end_time":"2022-11-15 15:30","data":{"0":0.06,"1":0.04,"2":0,"3":0,"4":0,"5":0.1,"6":0}},"703":{"start_time":"2022-11-15 15:30","end_time":"2022-11-15 16:00","data":{"0":0.02,"1":0,"2":0,"3":0,"4":0,"5":0.1,"6":0}},"704":{"start_time":"2022-11-15 16:00","end_time":"2022-11-15 16:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.18,"6":0}},"705":{"start_time":"2022-11-15 16:30","end_time":"2022-11-15 17:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.18,"6":0}},"706":{"start_time":"2022-11-15 17:00","end_time":"2022-11-15 17:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.21,"6":0}},"707":{"start_time":"2022-11-15 17:30","end_time":"2022-11-15 18:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.23,"6":0}},"708":{"start_time":"2022-11-15 18:00","end_time":"2022-11-15 18:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.35,"6":0}},"709":{"start_time":"2022-11-15 18:30","end_time":"2022-11-15 19:00","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.23,"6":0}},"710":{"start_time":"2022-11-15 19:00","end_time":"2022-11-15 19:30","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.22,"6":0}},"711":{"start_time":"2022-11-15 19:30","end_time":"2022-11-15 20:00","data":{"0":0,"1":0,"2":0,"3":0,"4":0,"5":0.21,"6":0}},"712":{"start_time":"2022-11-15 20:00","end_time":"2022-11-15 20:30","data":{"0":0,"1":0,"2":0,"3":0.01,"4":0,"5":0.2,"6":0}},"713":{"start_time":"2022-11-15 20:30","end_time":"2022-11-15 21:00","data":{"0":0,"1":0,"2":0,"3":0.19,"4":0,"5":0.04,"6":0}},"714":{"start_time":"2022-11-15 21:00","end_time":"2022-11-15 21:30","data":{"0":0,"1":0,"2":0,"3":0.4,"4":0,"5":0,"6":0}},"715":{"start_time":"2022-11-15 21:30","end_time":"2022-11-15 22:00","data":{"0":0,"1":0,"2":0,"3":0.21,"4":0,"5":0,"6":0}},"716":{"start_time":"2022-11-15 22:00","end_time":"2022-11-15 22:30","data":{"0":0,"1":0,"2":0,"3":0.19,"4":0,"5":0,"6":0}},"717":{"start_time":"2022-11-15 22:30","end_time":"2022-11-15 23:00","data":{"0":0,"1":0,"2":0,"3":0.18,"4":0.57,"5":0,"6":0}},"718":{"start_time":"2022-11-15 23:00","end_time":"2022-11-15 23:30","data":{"0":0,"1":0,"2":0,"3":0.21,"4":1.1,"5":0,"6":0}},"719":{"start_time":"2022-11-15 23:30","end_time":"2022-11-16 00:00","data":{"0":0,"1":0,"2":0,"3":0.17,"4":1,"5":0,"6":0}},"720":{"start_time":"2022-11-16 00:00","end_time":"2022-11-16 00:30","data":{"0":0,"1":0,"2":0,"3":0.25,"4":1.19,"5":0,"6":0}}}}
2022-11-17 17:00:30.972	Schedule	Inverter Data - Battery Percentage
Interestingly
5 returns server error
2022-11-17 16:59:21.378	Script	{
    "message": "Server Error"
and 6 returns this
2022-11-17 16:59:11.223	Script	{"message":"The given data was invalid.","errors":{"grouping":["The value you have entered is invalid."]}}
All others return this
2022-11-17 16:58:46.942	Script	{"data":{"0":{"start_time":"2022-01-01 00:00","end_time":"2023-01-01 00:00","data":{"0":53.90000000000001,"1":22.970000000000002,"2":7.699999999999996,"3":71.19999999999999,"4":96.10999999999999,"5":109.53000000000003,"6":0.9600000000000005}}}}
Unfortunately I'm out this evening for a call, but maybe we can Zoom after the weekend - there's no rush :D
Martin
neilk
Post by neilk »
Martin,
I am going to spend a little time adding the code to update the states (as we have some real responses) and also to go in line by line through the code making the calls again before we plan a call. That way we should be able to make the most progress. I will keep you posted as progress.
Neil
mwoodage
Post by mwoodage »
Hi Neil, thanks for the update, looking forward to the next instalment
mwoodage
Post by mwoodage »
Hi Neil,
The GivEnergy plugin has been working very well until yesterday when it started producing the following in the log,
HTTP error getting Inverter sa2230****data: 401 Client Error: Unauthorized for url: https://api.givenergy.cloud/v1/inverter ... ata/latest
Any ideas what this could be, i've tried resetting the plugin and also got the below from turning on Debug,
GivEnergy Debug Updating Inverter device: Inverter
GivEnergy Debug URL is: https://api.givenergy.cloud/v1/inverter ... ata/latest
GivEnergy Debug {'Authorization': 'Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZTkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT_k6EwCKSF-ePu5LQI8wJ8v9tNkBzNeG4yc5jB88QQRPWLdHwcQ', 'Content-Type': 'application/json', 'Accept': 'application/json'}
GivEnergy Error HTTP error getting Inverter sa2230****data: 401 Client Error: Unauthorized for url: https://api.givenergy.cloud/v1/inverter ... ata/latest
From a quick google search i can't see that GivEnergy have changed anything, but maybe?
Martin
neilk
Post by neilk »
Sorry I missed this - I will take a look tomorrow.
Neil
mwoodage
Post by mwoodage »
Thanks Neil, no rush
M
neilk
Post by neilk »
Hi Martin,
It looks like an issue with your API key, but is also seems they have been increasing their security posture recently and it may be related. Some things to check -
1) does the script you originally tried still work (with your current API key) ? If that works then we know the key is fine
2) how recent is your operating system?
We can then figure out what is going on. Some chatter on the API forum about issues with API keys and the Octopus integration also failing but nothing definitive.
Neil
Return to “GivEnergy Cloud Controller”
